SRS warning light 2007 tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by Graniteplan, Jul 7, 2022.
  1. Jul 7, 2022 at 6:24 AM
    Graniteplan
    Graniteplan [OP] New Member
    2007 Toyota Tundra
    Hi, folks. Anyone know any trouble shooting tips to get rid of this warning light. There should be no issue as the truck has never been in an accident so wondering if it is something simple to avoid a trip to the dealer$hip. Thanks
  2. Jul 7, 2022 at 9:00 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Try looking under the front seats, ensure nothing is making contact with cables and push in all wire clips... sometimes they come loose, cheap way to start, if that doesn't work then take it to autozone or similar and have them run diagnoatics with their OBD2
    Graniteplan[OP] likes this.
  3. Jul 7, 2022 at 9:45 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    A copy of the Techstream software is the best way. It is the easiest way to see the trigger for the code and to clear it. Most OBD2 readers will not clear Airbag Codes. The high dollar name brand ones most likely can but I am not 100% on that.
    If you cant find a friend with a copy a quick trip to the dealer might be required.
