DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Jun 28, 2022 at 9:50 AM
    #2161
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Figured I'd be able to help here. In short, approximately 3.25-3.5" lift up front. Rear has ADS triple bypasses, air bumps, and CB +3 shackles on the stock leaf for now. 17x9 et 0. 37x12.50r17.
    So I had a local fab shop knock out a body mount relocate to clear in the front. He is planning on making a kit whenever they get a new website going, but he cut he pinch weld and was able to keep the fender liner which is great. I BARELY rub in the front and that's at full compression. I do rub in front and behind the rear tire on the fender liner at full stuff. Going to have to figure that out, but with this TX heat I've been lazy lol.
  2. Jun 28, 2022 at 11:45 AM
    #2162
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Looks damn good!
    khooiii[QUOTED] likes this.
  3. Jun 30, 2022 at 8:23 PM
    #2163
    900exdriver
    900exdriver New Member
    finally joined the club. Still have some chopping to do. Don’t worry, used my next door neighbor’s truck to pull the camper in the back. That said got 5.29 nitro’s and a Eaton e locker in the rear. It’s pretty loud on decel. I’m hoping it quiets down a tad. Between the mud terrains, deeds exhaust, and kids I can still hear it back there.
  4. Jun 30, 2022 at 8:32 PM
    #2164
    starfish.pat
    starfish.pat New Member
    Patrick
    2008 Grey SR5 TRD Double Cab Short Bed
    My gear noise has mostly gone away. As they break in, I think they start to roll smoother. Just change the diff oil soon to get all the metal shavings out!
  5. Jun 30, 2022 at 8:41 PM
    #2165
    TheBeast
    TheBeast The Beach
    just minor trimming.
  6. Jul 1, 2022 at 6:41 AM
    #2166
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Such a sick setup. I say it a lot but OG Rock Warriors are some of the best looking trucks Toyota has made.
  7. Jul 3, 2022 at 7:20 PM
    #2167
    Kur
    Kur New Member
    Mesa, AZ
    08, 5.7, Double Cab Tundra, White
    So i got the lift and new UCAs installed and an alignment done. With the stock wheels and tires i can clearly see that the UCA would be buried into the side of a taller tire.
    This is with the stock +60 offset and my new wheels are +35 which would help, but with a 12.5in wide tire, that only gives an extra 1/8in of space between the tire and the UCA according to this calculator...
    Which makes me think i am going to need to run a wheel spacer. But if i were to run a half inch spacer, i would need to install longer wheel studs, which i can't find anywhere except for a set on ebay that are like a full inch longer than stock. And if i run a thicker spacer that has its own installed studs, now I'm getting into the realm of 0 or negative offset which causes other clearance issues.
    So I'm not sure what to do. I haven't ordered the tires yet so i can't say for sure what's going to fit or not. But right now it isn't looking good.
    Mountun Goat likes this.
  8. Jul 3, 2022 at 7:37 PM
    #2168
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    It’ll all just depend on how much you want to trim.
    Best bet is to get the tires, mount them, see how it’ll fit then go from there.
    reywcms likes this.
  9. Jul 4, 2022 at 5:46 AM
    #2169
    starfish.pat
    Patrick
    Most people on here say the sweet spot is about +25 offset. I have +12 offset with 17x9 wheels. There's not too much poke and me clearance issues are minimal. I'm running a 13.5 wide tire and the only thing I rub is the sway bar at full lock. I still need to realign a second time, though. Last time I aligned it was on 35s.
    pvn.beluga and Hightide like this.
  10. Jul 6, 2022 at 5:20 AM
    #2170
    900exdriver
    I know I’ve seen a few pictures out there but can’t find anymore. Any running this type of setup to carry the spare? Thought a couple guys had a DIY setup. Just trying to get some ideas [​IMG]
    Deaner and Mountun Goat like this.
  11. Jul 6, 2022 at 7:41 PM
    #2171
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Wilco makes a tire carrier that will run the spare up against the bed rail.
    I personally don’t run one around town. But this is how I secure my spare. 37” spare, bed rug mat I cut to fit between US Cargo L track. Rivnut straight into the bed. Super handy to have and it’s been jump tested. Ignore the mess I just installed the bed lights lol
    J&ATundra, Deaner, pvn.beluga and 6 others like this.
  12. Jul 7, 2022 at 7:41 AM
    #2172
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    That’s sweet I like that. I use my bed a lot and didn’t wanna Lose it for a tire
    reywcms likes this.
  13. Jul 7, 2022 at 8:02 AM
    #2173
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    Post more 37s :benchpress:
    GriffDawg, Helo, pvn.beluga and 6 others like this.
  14. Jul 7, 2022 at 8:07 AM
    #2174
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Yup. Work truck play truck. Haven’t found the perfect solution and trust me I’ve tried. Bed covers, camper shell, bed rack, decked drawers. Now I’m considering buying a work truck LOL
  15. Jul 7, 2022 at 8:10 AM
    #2175
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
  16. Jul 7, 2022 at 8:28 AM
    #2176
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Added some more pics of mine and the old mans dirty sevens.
  17. Jul 7, 2022 at 8:39 AM
    #2177
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
  18. Jul 7, 2022 at 11:06 AM
    #2178
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
  19. Jul 7, 2022 at 12:38 PM
    #2179
    Millwood21
    Millwood21 New Member
    Jade
    2017 Platinum
    I got an email saying front shocks are delayed now until sometime in September. I can’t look at these 37s that long off the truck! What the chances a cheap leveling kit will give me enough clearance until they show up?
    eccracer104 likes this.
  20. Jul 7, 2022 at 1:11 PM
    #2180
    eccracer104
    San Diego, CA
    Lol :sawzall: It’ll work :burp:
  21. Jul 7, 2022 at 1:35 PM
    #2181
    Knox_Tundy
    Knox_Tundy New Member
    Knoxville, TN
    Looks awesome
  22. Jul 7, 2022 at 1:36 PM
    #2182
    Knox_Tundy
    Knoxville, TN
    Those 37’s just hit right.
  23. Jul 9, 2022 at 6:07 AM
    #2183
    900exdriver
    Someday I’ll find dirt. [​IMG]
  24. Jul 9, 2022 at 7:21 AM
    #2184
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    So sexy!
    Can you tell us about your truck and what you did to make them fit without rubbing?
  25. Jul 9, 2022 at 7:35 AM
    #2185
    900exdriver
    Did all the chopping everyone in this group recommends. I’m on Dobinsons twin tubes. 778 springs up front. Two shims driver. One pax side. 129r rear leaf springs with cb 3+ shackles.
  26. Jul 10, 2022 at 4:25 PM
    #2186
    Shanet421
    San Diego,CA
    1/2” aluminum bumper shims courtesy of @SAGE63
    5A5A3745-6B5B-4A45-A7CE-8BA45EAC9092.jpg 3BADE4B6-1A30-4932-9636-5AE56D3B4C41.jpg
    Baby steps in the right direction
  27. Jul 10, 2022 at 5:32 PM
    #2187
    Trdwillie14
    Billy
    2014 trd off road
    :sawzall::sawzall::sawzall:it’s time
    pvn.beluga and tundra_20 like this.
  28. Jul 10, 2022 at 5:53 PM
    #2188
    Shanet421
    San Diego,CA
    I’ve been cutting and trimming and cutting some more. I’m ready for a test fit! These 295/70/18 looking kinda small in there now62A3B356-4D8D-48C7-AE8A-3F503B82FBA3.jpg
  29. Jul 10, 2022 at 7:12 PM
    #2189
    SAGE63
    San Diego County
    Awesome glad they worked for you too. courtesy of @eccracer104 to me. pass them on when you are finished with them!!! how are the UCAs...
    pvn.beluga, eccracer104 and tundra_20 like this.
  30. Jul 10, 2022 at 7:13 PM
    #2190
    SAGE63
    San Diego County
    yup ready for the jump to 37s
