  1. Jun 29, 2022 at 5:35 AM
    EmergencyMaximum
    EmergencyMaximum New Member
    There is. I had what I thought was faulty sensor somewhere until friend suggested filling up a spare. After doing that, no more light.
    omgboost[QUOTED] likes this.
  2. Jun 29, 2022 at 6:15 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Lotta info out there. The real rub lies in filtration. I've heard that we DO have sensors in the spare....
    I need to change oil today, so I'll try to shimmy down to the spare and see what kind of valvestem it has.
    Hoping the shop didn't install one or all backwards, as I've read can be an issue.
    I really despise tire time as it's one of the only maintenance items I can't do myself in the garage.
    Not only did the shop try to charge an extra $300 over what we discussed, but they can't even do the damn job correctly... At a certain point, it saves me to invest in tire balancing gear
  3. Jun 29, 2022 at 6:48 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    What year is your car? I do not believe my spare has one although it could be different spare on a Sequoia :monocle:
  4. Jun 29, 2022 at 10:18 AM
    EmergencyMaximum
    She's 2010
    omgboost likes this.
  5. Jun 29, 2022 at 1:51 PM
    omgboost
    East Coast
    Toyota may have changed it in the later years as I have seen a few posts from people who have the later years with no TPMS in the spare.
  6. Jun 29, 2022 at 2:57 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    Yeah, I’ve seen both. I definitely saw a big red X on his scanner tool.
    Is there a way to disable that so the computer knows not to look for it? It wasn’t throwing the TPMS light until I replaced the one. And again, they’re tool showed that one communicating.
  7. Jun 29, 2022 at 3:21 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    Is there a way to easily tell if the spare on my 2012 has a TPMS transmitter?
  8. Jun 29, 2022 at 3:24 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Metal valve stem. Also helps if the spare is mounted with the stem facing down, I didn't do that so I can't tell if mine has a TPMS or not without dropping it. :facepalm:
    WVI and Randy Morton[QUOTED] like this.
  9. Jun 29, 2022 at 3:30 PM
    EmergencyMaximum
    Try letting air out, check dash and then resuck it back in.
    Randy Morton[QUOTED] likes this.
  10. Jun 29, 2022 at 5:00 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Well crap. Another flat tire. 2 in 2 weeks.
    EmergencyMaximum likes this.
  11. Jun 29, 2022 at 5:57 PM
    omgboost
    East Coast
    Here's a few excerpts from the owners manual:
    Wynnded likes this.
  12. Jun 29, 2022 at 6:19 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    Hey this is dumb but I used to keep a bunch of stray bungees in the bed to tie stuff down. I found these and they're the right length so two span the tie-downs rather than flopping around. They have connections every few inches so they're always the right length.
    Had them for a couple of months and love them so wanted to share.
    The Perfect Bungee by BihlerFlex,... https://www.amazon.com/dp/B07FNNS1NQ?ref=ppx_pop_mob_ap_share
    D4x4TRD, MTRock, WVI and 4 others like this.
  13. Jun 29, 2022 at 7:24 PM
    Retroboy1989
    Northern Utah
    Got my KO2s balanced. Running on 20" TRD sport wheels and 275/60R20s 8 plys. The shop that did them before used a static balance. The new balance is dynamic. It took a ton of weight, but it is so much smoother.
    WVI and Mountun Goat like this.
  14. Jun 29, 2022 at 8:16 PM
    EmergencyMaximum
    Perhaps they love me so much that they included a tpms into my spare:humble:
    in all seriousness though, I've been having intermittent(very often) pressure warning go off for no particular reason that I was almost ready to start replacing sensors. One day I lamented to a friend my problem and he doesn't even have a totota, but he said try checking the spare. And I did! When I took it out and filled it up, warning went out and I have yet to see it come back. It's been like half a year now!:notsure:
  15. Jun 30, 2022 at 2:44 AM
    BoysandHisToys
    Central Virginia
    When I got my new set of tires put on, I noticed a lot weights were needed to balance them.
    On my previous tires, I kept two as back up just in case, I found beads in the tire that I assume were to help balance them without having to use as many weights.
    I’ll probably ask next time if they carry those beads.
  16. Jun 30, 2022 at 6:55 AM
    tunpunch
    tunpunch New Member
    Cord
    2007 TRD DC 4X4
    Do you have a lift or any rubbing issues? Looking to get the same tires on my OEM 20s with 5110s on mid level. Can you post some pictures too?
  17. Jun 30, 2022 at 1:33 PM
    Retroboy1989
    Northern Utah
    Stock suspension
    Oem 20" wheels no spacers
    275/60r20
    No rubbing at all - it's only around an inch taller than factory tires
    Peeeheeuuu, D4x4TRD, MTRock and 8 others like this.
  18. Jun 30, 2022 at 10:21 PM
    frankforttrdpro
    frankforttrdpro New Member
    Bala
    Frankfort
    2007 5.7L RCSB 2x4
    Did this couple of weeks back just took pictures yesterday. Added a 2- 4 drop with assist airbag spring and added Mangnaflow muffler with Dual pipe exhaust. Lowered.jpg
  19. Jul 1, 2022 at 4:03 PM
    Windsor
    Homeless in Oregon
    Some.
    Almost lost her at work. A 70ft log snapped two cables and rocketed down the hill. About 3/4 the way down, it smacked a tree and changed it's trajectory 45* and aimed right for me. It snapped a couple small trees at the end which scraped my bumper. Thankfully, the big bastard stopped 10ft short.
    It was aimed directly at my front tire. If it had hit at speed, it would have wiped out my front end and sent my truck about 15ft down the hill.
    For some reason, my mind wasn't on my own safety. When I saw it change direction, I thought "don't hit my truck, don't hit my truck".
    wv00097, TheBrit, D4x4TRD and 11 others like this.
  20. Jul 1, 2022 at 4:07 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Man what a great story with an even better ending! Get that lotto ticket today my friend.
  21. Jul 1, 2022 at 8:37 PM
    Pnoy_toy
    Pnoy_toy New Member
    Finally got around to installing my 40inch light bar hidden behind the bumper and chase lights…this project was sitting in my garage for over a year. Excuse all the junk in my garage
    D4x4TRD, joseph_womack, WVI and 7 others like this.
  22. Jul 2, 2022 at 5:26 AM
    Kiddnapped Tundra
    Kiddnapped Tundra New Member
    Grand Island, NY
    2010 Tundra DC
    IMG_20200801_181357_406.jpg IMG_20220701_171406985_HDR~2.jpg Over the winter I added a Demello Bumper and Warm Zeon Platinum 12S Winch.
  23. Jul 2, 2022 at 6:48 AM
    Shanet421
    San Diego,CA
    That is a beautiful bumper. I am currently waiting on sliders from Jay and can hardly wait!
  24. Jul 2, 2022 at 3:34 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    In the middle of a valley plate reseal
    D4x4TRD, joseph_womack, WVI and 4 others like this.
  25. Jul 2, 2022 at 3:47 PM
    EmergencyMaximum
    Pix incomplete, where's that toyomafia lady with a blanket in front of those headlights?
    joseph_womack likes this.
  26. Jul 3, 2022 at 5:35 AM
    Pnoy_toy
    Pnoy_toy New Member
    If you are talking about this lady, please let me know when she is available so I can redo the photo
  27. Jul 3, 2022 at 10:34 AM
    PhotoNerd
    Tony
    Waterford, CT
    Reupholstered my center console... For the 2nd time.
    Before, it shows creases from them shipping it to me folded up (steam didn't help), and you can see the outline of the heater:
    During, me gluing the edges in after adding 1/4" foam over the heater to pad it a little.
    And after:
    I'm going to steam all the leather soon so it should tighten up.
    I've now done this project twice and it's one of my least favorite DIYs. It's messy and imperfect and nobody will ever notice it... But at least they won't notice it because it's jacked up.
    Here's the part that worked:
    DSparts Center Console Lid... https://www.amazon.com/dp/B07KS86FBT?ref=ppx_pop_mob_ap_share
  28. Jul 3, 2022 at 2:55 PM
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    Installed an oil cooler on the Tundra. Wasn't too expensive, spend a little less than $400. Took about a day or so and then I dropped it off to the mechanic to change the Trans fluid and refill.
  29. Jul 3, 2022 at 5:10 PM
    05TacomaCO
    05TacomaCO t800_tundra
    Paul
    Pueblo West, CO
    2010 CM Platinum 4x4
    Toytec Boss 3" coilovers, AAL in rear with Eibach pro shocks, RCI skid, Method 701 Falken WIldpeak 285/75 R18. C4 Hybrid front bumper. SS3 fogs, Auxbeam 7” round off-road lights. Black Oak ditch lights. Smittybilt 10k winch. RCI Sliders. Toytec Shackles, Timbren Bumpstops.
    72100EC7-D8A8-42D5-90EF-DBAEB6837AAE.jpg Upgraded the JBL sub with a infinity 10” shallow mount. And built a box with some plywood I had. Big improvement.
    Peeeheeuuu, WVI, MTRock and 5 others like this.
  30. Jul 4, 2022 at 8:40 AM
    PhotoNerd
    Tony
    Waterford, CT
    Old exhaust tip.
    New exhaust tip. Nobody but me will ever notice.
