After a 1000+mile trip found this piece of loose trim on my front drivers side door.
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by charge556, Jul 3, 2022.
  1. Jul 3, 2022 at 10:27 AM
    charge556
    charge556 [OP] New Member
    2017 Inferno 4x4
    From factory TRD off road package with 275/65/r18 TRD wheels;
    what is this adhesive (in pic), where do I get it, and how do I apply it for a factory finish. thanks.
  2. Jul 3, 2022 at 11:36 AM
    BlueRidgeTon
    BlueRidgeTon New Member
    WNC
    2021 Cavalry Blue SR5 Crewmax
    Toytec/Eibach 2.5 lift kit. JBA UCA's. Toytec Shackles. Icon vector 5s BFG KO2's 285/75/17
    You can get 3M double sided trim tape at any auto parts store that will suffice. I had the same issue and used the 3M tape with some clamps for a couple hours and it has held.
  3. Jul 3, 2022 at 12:35 PM
    Kung
    KG, VA
    Literally just noticed this earlier this morning; and I log on to find this. Not happy you're dealing with the same; but happy there's a 'fix' for it. :)
  4. Jul 3, 2022 at 6:07 PM
    charge556
    2017 Inferno 4x4
    Should I remove the pad shown, scrape underside surface clean, and then apply 3m or apply 3m to it as is?
  5. Jul 3, 2022 at 6:08 PM
    THORYOTA
    THORYOTA God of Thunder
    Thor
    Asgard
    2021 MGM TRD CM "Mjölnir"
    Did the same to mine a few months ago.
  6. Jul 3, 2022 at 7:33 PM
    BlueRidgeTon
    WNC
    I'd try to clean it as much as possible before applying.
