Clicking sound from brakes
Discussion in '2nd Gen Tundras (2007-2013)' started by SeaBass, Jul 2, 2022.
  1. Jul 2, 2022 at 6:23 PM
    SeaBass
    SeaBass [OP] New Member
    Jon
    2008 Sequioa SR5
    I just put brand new calipers, pads and rotors on my 08 Sequioa. Left side is quiet, right side makes a clicking/ticking sound that corresponds with vehicle speed. It makes the same sound regardless of brake pressure, the same noise continues whether applying brakes or not.
    I jacked the wheel up and spun it by hand, it isn’t touching the heat shield at all. The pads make a very slight noise sometimes when I spin by hand but I can’t imagine it is the clicking I hear, and I would think it would go away when applying brakes.
    Any ideas would be greatly appreciated, thank you!
  2. Jul 2, 2022 at 11:55 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    1.) Jack up the front spin the wheel by hand. (No noise check for rocks in tread)
    2.) take tire off, put lugs back on spin rotor by hand. (No noise tire interference)
    3.) while spinning by rotor by hand stick finger carefully on upper pad ears of both inner and outer. (No noise pad slap/rattle i.e poor part fitment)
    4.) remove caliper and hang it with slack on the line, remove rotor inspect for foreign derbies in the inner hat. Rotate hub by hand. (No noise was foreign derby or poor fitment of rotor on hub)
    5. Inspect wheel bearing for smooth turning or if it feels gritty inside while turning, if not could be a CV axel. Reinstall all and tug inward and out ward on tire at 12 n 6 to check play.
    if after step one the noise went away but there is no rocks or derby stuck in tire could be a few things like strut top hat bushing or another type of bushing in suspension but normally the other type of bushings would cause a vibration or shake of some sort. Also check front drive shaft U joints for slop (assuming its a 4wd model)
    if you can a video of the sound would help.
    Also milage and is it stock or modified suspension and tires?
    TheBeast likes this.
  3. Jul 3, 2022 at 6:58 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Not just a rock stuck in the tire treads, or something unrelated to the brake?
  4. Jul 3, 2022 at 8:09 AM
    SeaBass
    Jon
    2008 Sequioa SR5
    Thanks for the responses! It’s an 08 SR5 4wd with 5.7 and 119k. I had to replace the caliper since the brake pad pins were welded with rust into the old one. I beat the pins pretty hard with a 3lb sledge but I can’t imagine I damaged the CV or wheel bearing, plus they make no noise when I spin the tire by hand.
    I’m going to take the rotor off and check the hub surface when I get home, but I even wire brushed the hub before installing the new rotor. I thought for sure the heat shield was hitting the rotor when I first heard it, but it’s all clear.
  5. Jul 3, 2022 at 8:13 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Another thought, make sure there aren’t any stick-on wheel weights rubbing on the new caliper.
  6. Jul 3, 2022 at 9:12 AM
    SeaBass
    Jon
    2008 Sequioa SR5
    Funny you say that, I was just thinking that could be the issue, there is pretty tight clearance on the caliper inside the wheel, great thought!
    landphil likes this.
