(Solved) Any electric motor gurus on here? (Antique)
Discussion in 'Off-Topic Discussion' started by Sumo91, Jul 2, 2022.
  1. Jul 2, 2022 at 8:05 PM
    Sumo91
    Sumo91 [OP] Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    So I have am early 1940s Leland electric motor. 1/2hp 110/220v. 7 wires coming out of the case. I completely stripped down the motor for restoration for a project I'm working on. New bushings, oil wicking material, paint, soldered all new wires to everything (while keeping them labeled correctly, they were all the same color)
    I'm not an electrician, I can hook up simple 110v stuff like ceiling fans, outlets, etc. And I'm good with 12v systems. This motor is out of my range of knowledge. I'll explain below
    This motor is 110/220v. It has 7 wires coming off of the motor (no ground wire attached to the motor anywhere). They are all numbered, and I kept all the numbers intact when re wiring, and put new labels on the new wires. It was wired for 110v when I removed it from service on my old attic fan in the house I sold. The numbers are as follows
    T1-T2-T3-T4-T5-T8-T11
    T3-T5-T11 were hooked up to one wire
    T2-T3-T8 were hooked up to the other wire
    T1 was disconnected entirely
    The motor ran this way, and I plan on hooking it up the same way, but I wanted some opinions or advice before doing so. I'll post some pictures tomorrow of what every wire goes too if it will help. Should I check the ohms on anything? Etc? I'm not great with a multi meter, but I own a decent one and can use it correctly when I have an idea of what I'm supposed to be checking for.
    Oh and the wires are all different colors now (but labeled correctly) I stripped down a new dryer cord for the wiring inside of it (way overkill om the gauge). I bought it on sale years ago for $2, and finally found a use for it.
    20220623_140445.jpg 20220623_152904.jpg 20220623_154922.jpg 20220624_152848.jpg 20220624_154307.jpg 20220630_110432.jpg
  2. Jul 5, 2022 at 8:37 PM
    Sumo91
    TN
    Ended up taking it to a motor shop up the road. He got me squared away with the wiring, and sold me a new capacitor for $4. Can't beat that. So with that said, restoration complete! This motor is the most silent motor I've ever heard run. It's a reverse induction motor and doesn't have brushes, no ball bearings, just bronze bushings with wool roving for the oil wick, and oiling gits for both bushings. I already knicked the new paint in a couple spots, but not concerned with it. Really happy to bring this nearly 80 year old motor back to life for another 80+ years.
    20220705_182244.jpg 20220705_182249.jpg 20220705_182255.jpg 20220705_182305.jpg
  3. Jul 5, 2022 at 9:04 PM
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    Ignorant question...what is this motor for?
    Sumo91[OP] likes this.
  4. Jul 5, 2022 at 9:20 PM
    Bad ass! That lathe will run like a top.
    Sumo91[QUOTED][OP] likes this.
  5. Jul 5, 2022 at 9:28 PM
    Sumo91
    TN
    It can be used for a wide variety of applications, but I removed it from an old attic fan/whole house fan from my old house. I couldn't get the actual fan down from the attic, so I just took the motor. I bought another attic fan for $50 with no motor (which out of sheer luck happened to be the exact model attic fan that was in my attic)
    I'll be making a shop fan with it. Attic fans move more air, and operate much quieter than any shop fan you can buy from the store. Most store bought shop fans have large, skinny blades that "cut" the air, and it makes alot of noise, attic fans have huge, wide blades, angled in a way that they move air quietly. Here is the fan I'm about to restore and build a nice wooden frame for, which will also double as small table/horizontal surface to clutter up with random stuff.20220630_154619.jpg
  6. Jul 5, 2022 at 9:30 PM
    Oh crap. I thought that was for your lathe. Lmao. Too much 10W-40
  7. Jul 5, 2022 at 9:30 PM
    Sumo91
    TN
    This is a little 1/2 hp motor, my lathe has a 5hp Robbins & Myers motor :eek:
    I'm ready to start restoring it though. Hopefully I can have it done by the end of the year.
  8. Jul 5, 2022 at 9:32 PM
    Sumo91
    TN
    That's pretty damn funny. Maybe I can take those beer cans and turn them into cool little oiler cans :monocle:
    If I do, I'll send you one :thumbsup:
  9. Jul 5, 2022 at 9:32 PM
    Isn’t the lathe from WWII era as well?
  10. Jul 5, 2022 at 9:34 PM
    I couldn’t gut the rest of them man. They went down the sink. Probably better oiler cans for sure. :cool:
  11. Jul 5, 2022 at 9:38 PM
    Sumo91
    TN
    Yes sir, ordered in 1942, completed and delivered in July 1943. De greasing and paint stripping is going to be the worst part. 20220303_114251.jpg
    Lemoyne40, KK6PD, Blang805 and 3 others like this.
  12. Jul 17, 2022 at 5:08 PM
    Sumo91
    TN
    Got the fan 99% finished, just need a handle and some kind of guard to keep stuff out of the blades (wheels are on but I took these photos beforehand). But it works great, and puts out more air than any shop fan I've ever come across. Extremely quiet when running too. Only downside is how damn heavy it is. Probably gonna get a fold down handle like what's on my generator to get some leverage on it.
