I have a 2004 Tundra that starts 90% of the time, but will not start on occasion.
Discussion in 'General Tundra Discussion' started by Chuck55, Jul 2, 2022.
  1. Jul 2, 2022 at 3:33 PM
    Chuck55
    Chuck55 [OP] New Member
    Chuck
    2004 Tndra
    I have taken into my mechanic as well as the dealer and they can't reproduce the issue. Sometimes it starts and sometimes it doesn't. Have to turn through ignition repeatedly and it will finally start and work great for weeks, then it's same old story. Replaced neutral safety switch and ignition switch. Ideas?
  2. Jul 2, 2022 at 5:34 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    When you say not starting, I assume you mean it does not crank, correct? Perhaps the starter - next time this happens, check the voltage on the battery as you are trying to start it. If the voltage is dropping when you turn the key, the starter is getting juice but not turning. If that is happening, replace the starter. If the voltage is not dropping, it is upstream of the starter.
    YardBird likes this.
  3. Jul 2, 2022 at 7:53 PM
    Radarninja
    Radarninja New Member
    Ca
    Starter solenoid?
    You can rebuild it for $30 ish.
    Aftermarket starters haven’t been any good to me.
    Rebuilt oem and works great. Returned the aftermarket.
  4. Jul 2, 2022 at 7:53 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Your issue could be caused by just about anything. On our aging Lexus it was the burned up contacts in the starter solenoid.
    The Toyota starters are typically quite durable but the contacts, not so much.
    Easy to remove a starter on a V-6 Lexus ~ on a Tundra V8 it's a different story.
    Good luck and keep us posted with your results.
    Chuck55
    MS22 and Radarninja like this.
  5. Jul 2, 2022 at 10:18 PM
    Chuck55
    Chuck
    2004 Tndra
    It just clicks. Same behavior when the battery is dead. But after repeatedly turning the ignition it will start and work for weeks, then starts all over again!
  6. Jul 2, 2022 at 11:33 PM
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    I had similar issues with a 1990 4Runner. Completely random start/no start. I replaced the starter, starter relay, ignition switch, neutral switch. The only thing that worked was bypassing the starter relay. After doing that had no issues at all :notsure:
  7. Jul 3, 2022 at 6:41 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Then 100% chance it is a worn starter contact, get the correct kit and get er' fixed.
    Oh and if you don't and decide to delay, it will get worse, your current 90% will steadily drop to 0%. Just an fyi, luck.
    Radarninja likes this.
