  1. Jul 1, 2022 at 3:37 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    That little graphic shoulda had an image of you Dukes of Hazarding out of that $hit!
  2. Jul 1, 2022 at 3:53 PM
    TommyTundra
    TommyTundra Oh God the anger’s changing me
    Long Island NY
    2019 PRO
    Saw this on the marketplace today. Its gonna look great in the garage/ workshop right above my snap on box3E63C120-BD77-4762-A8C2-0FCC83C62C68.jpg
  3. Jul 1, 2022 at 3:54 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    here are a couple more showing the NEX Home Screen. It’s easy to switch back and forth.
    7AC1CC82-4862-4AD6-9343-32A9DB0981AA.jpg 71C11FC5-E027-479D-B5BA-77093A8688E7.jpg 8F4658A1-F7E8-46D7-A5FF-72944890BABD.jpg
  4. Jul 1, 2022 at 6:21 PM
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    New set of shoes! Nokian Outposts were to be available to order today, tire place said they were on backorder from Nokian, so they PXL_20220701_225329162.jpg hunted me down a set...Nokian Outpost 275/70 R18s. I'll take better pictures tomorrow. First impressions...just a little louder than OE Michelins, ride smoother, look MUCH better, and definitely fill the wheel wells better (OE were 275/60). No rubbing.
  5. Jul 1, 2022 at 6:45 PM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    Feeling better about my cats. Got the Cat Security shield with the extensions put on this week. Ordered the heavier one. Figment was really good.
    Nbab23, nhw544, Booney and 11 others like this.
  6. Jul 1, 2022 at 7:50 PM
    NyteRyder3
    NyteRyder3 New Member
    Birmingham, AL
    Finally got rid of the last bit of chrome on the outside! New Vision Tactical wheels and 275/60/20 BFG Trail Terrain T/A tires.
  7. Jul 2, 2022 at 4:41 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Are you happy with these mirrors?
    I'm thinking about buying the ones with the turn signals in them..
  8. Jul 2, 2022 at 5:48 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Packed up and playing on the Hiawatha this weekend
  9. Jul 2, 2022 at 7:16 AM
    Flying Gorilla
    Flying Gorilla New Member
    Austin, TX
    2018 SR5 TSS Blazing Blue Pearl
    Factory Lift 35” Tires Black Rims
    Finally installed my under seat storage. Got a deal from someone local and picked the ESP Up pretty cheap.
  10. Jul 2, 2022 at 10:14 AM
    (Hopefully,) better pictures of the Nokians. Completely inside the wheel wells, my preference. Filling up front wheelwell and close up...PXL_20220702_103358902.jpg PXL_20220702_103334957.jpg PXL_20220702_103351949.jpg
  11. Jul 2, 2022 at 1:00 PM
    SwitchThrottle
    2021 Barcelona CrewMax
  12. Jul 2, 2022 at 1:04 PM
    SwitchThrottle
    Anyone removed the Decals? Tips on safe removal?
  13. Jul 2, 2022 at 1:08 PM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    1lowlife and RainMan_PNW like this.
  14. Jul 2, 2022 at 1:10 PM
    SwitchThrottle
    The same wheel I used on the emblem glue?
    I was thinking I need to heat and peel.
    Pillslinger likes this.
  15. Jul 2, 2022 at 1:13 PM
    Pillslinger
    Rollin
    SWMO
    I used the same for both, although in reverse order. I used a heat gun (hair dryer would work) to heat the vinyl up and most of it peeled off with my fingers. The left over junk including adhesive I used the wheel.
    Edit: when I peeled my black door pillar vinyl I did discover there is this magic spot with heat where the adhesive comes up with the vinyl. Most of the time there is some adhesive left behind.
  16. Jul 2, 2022 at 1:23 PM
    SwitchThrottle
    Excellent, thanks!
    Pillslinger[QUOTED] likes this.
  17. Jul 2, 2022 at 1:34 PM
    Wixo
    Wixo The Best Member
    Mawr
    RGV
    5.7L 4x4 CrewMax SB
    Tint
    I cumfilmed the entire truck. Went through a whole pack of cans. Its definitely better to buy buckets and either spread it on with sponges or get the air spray adapter funning from the bucket. The spray can leak and waste aboug 10%.
  18. Jul 2, 2022 at 1:34 PM
    Pillslinger
    Rollin
    SWMO
    You bet. You won't miss it once it's gone
  19. Jul 2, 2022 at 1:47 PM
    SwitchThrottle
    Heated a corner so I could lift it easy, then did the rest without heat. Came off beautifully with almost zero residue.
  20. Jul 2, 2022 at 1:51 PM
    SwitchThrottle
    I haven't even wheeled or washed it yet.
  21. Jul 2, 2022 at 1:53 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Next: the B-pillars. You may as well go full Brazilian
  22. Jul 2, 2022 at 1:54 PM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    I sprayed my exhaust bolts with PB Blaster... getting ready for my Dirty Deeds exhaust that "SHOULD" be here Thursday.
  23. Jul 2, 2022 at 2:34 PM
    AZTundra
    Paul
    Phoenix, AZ
    Installed some Trail Ridge tow mirrors from @sportbikenut this afternoon. They fit great and are electric, heated, and have the blind spot indicators. Side smoked lenses with turn signals which was an upgrade to the stock mirrors.
  24. Jul 2, 2022 at 2:41 PM
    Kung
    KG, VA
    Damn man; had a 6mm x 9mm kidney stone in 2020, and had it blown up - not by sharks with frickin' laser beams, but by doctors with frickin' laser beams. The recovery was almost worse than the kidney stone was. :eek2: Best wishes for a speedy recovery.
    If they haven't already done this (and I'm sure they have, but still), make sure they analyze your urine in a 24 hour test to see what's causing them. In my case, thankfully, it was down to not drinking enough water. That's easily rectifiable...but I'm not kidding even a little bit when I say I'd go 100% vegetarian to avoid them suckers.
    Wallygator and NewImprovedRon like this.
  25. Jul 2, 2022 at 2:42 PM
    SwitchThrottle
    Bare is beautiful, but the B-pillars are staying. The only red Tundras I've seen B-pillared were DCs, and I'm not a fan. Besides, when she gets tints, it will all tie together better if they are black.
  26. Jul 2, 2022 at 2:43 PM
    Kung
    KG, VA
    I know that feeling! Got mine put on in March, I think. Wife all along has said "...do you SERIOUSLY think this is necessary?"
    Just yesterday she saw a post on FB about an attempted cat theft @ the movie theater we went to at the end of May (to see Top Gun: Maverick). She sent me a message saying "You were right."
    I cherish that message. :D
  27. Jul 2, 2022 at 2:45 PM
    Pillslinger
    Rollin
    SWMO
    Do it.
  28. Jul 2, 2022 at 3:33 PM
    Blue USB (to match the floorboard lighting/control lights) and console organizer in...it's the little things in life...1656801189928827852092810771311.jpg
    mgm16trdpro, Jcmf52, Wixo and 3 others like this.
  29. Jul 2, 2022 at 5:15 PM
    Tripleconpanna
    Went to take the PRO out for a quick spin; it's been sitting for a few days, and it was covered w/green tree pollen. So, I had to rinse it off real quick...
    ... now I can see out of the windshield!!!!
    :burnrubber:
  30. Jul 2, 2022 at 5:29 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Any issues since installation? I bought one and it contacts the sway bar, oil everywhere, luckily I didn't ruin the engine...and before anyone asks, all paved roads, some potholes...I drove from Cypress to Surfside after installation/oil change on Monday morning, and no issues all week, noticed the puddle under the truck when I got back to Cypress on Friday.
    Dent from sway bar (hard to see, but it made contact enough to lose seal around the filter)
    Better view of damage to filter, sway bar rubbed paint off
    bulldog93 likes this.
