Shaking when braking
Discussion in '1st Gen Tundras (2000-2006)' started by Shalan66, May 11, 2019.
  1. May 16, 2022 at 7:30 AM
    I don’t think Autozone sells OEM parts. Only “OEM equivalent”, which are anything but.
    Aerindel, bmf4069 and FirstGenVol like this.
  2. Jul 1, 2022 at 4:04 PM
    NomadicFrog
    NomadicFrog Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    I think I am chasing the same problem as the OP, and I'm interested in the idea that it's actually the rear causing the problem. I'd like to test the e-brake method, but your reply leaves me slightly confused: did you mean "out of round drums" instead of rotors?
  3. Jul 1, 2022 at 6:37 PM
    Is it possible the rear brake cylinder is getting stuck and causing the brake pad to drag on the drum?
