Continuous Failure of Spark Plug in Cylinder06 - Leads to Misfire
Discussion in '2nd Gen Tundras (2007-2013)' started by AHR, Jul 1, 2022.
  1. Jul 1, 2022 at 1:44 AM
    AHR
    AHR [OP] New Member
    Hello Everyone,
    I have a misfire in Cylinder06 with CEL flashing and the code is P0306. My car is Tundra 2008 5.7 L with 186,xxx Miles
    Here is the list of things already done:
    1- Swapping the Coils (Misfire Stays in Cylinder 6)
    2- Swapping the Injectors (Misfire Stays in Cylinder 6)
    3- Compression Test, Cylinder 06 is 150 PSI (Wet Test)
    4- Installing New Spark Plugs every time the spark plug fails after 20 miles of driving and the car starts misfire again.
    5- No Signs of Oil or Coolant at the Spark Plug, The car has new valve cover gaskets + Spark Plugs seals
    What could be the issue that damage the spark plugs, I'm testing the spark plug with the same coil used in cylinder 6 and the spark is blue and clean and Tested again after 20 miles driving the spark is yellow and misfiring !!
    Now I'm on the process of checking the ECU and Wiring. what things shall I consider ?
  2. Jul 1, 2022 at 3:45 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Can you post a picture of the damaged plug?
  3. Jul 1, 2022 at 4:04 AM
    Uncle_Charlie
    Uncle_Charlie New Member
    2018 Tundra- Work truck package
    You might consider looking at connectors in the wiring harness. There could be some green crusties hiding in the sockets and on the pins, considering the age of the truck and the miles.
