Who’s tired of “will it fit?” threads?
Discussion in 'Wheels & Tires' started by TM1107, Jun 29, 2022.
  1. Jun 29, 2022 at 9:36 PM
    TM1107
    TM1107 [OP] New Member
    Raise you’re hand if you’re tired of “will it fit?” threads. There’s so many posts now about almost EVERY combination of what will work/won’t work. SEARCH BUTTON!!! That being said…
    I have a 2016 4x4 limited and I’m looking to do 3.5” front lift with 35x12.5” tires on stock 20x9 +60 wheels. I’m willing to do CB bumper shims, wheel spacers, and mild plastic trimming. So it begs the question… will it fit? Lol
  2. Jun 29, 2022 at 9:38 PM
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    no. keep it stock.
  3. Jun 30, 2022 at 4:12 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Probably with the spacers. Min clearance seems to be 3 inch + trimming. Happy offset seems to be 0 to +25.
  4. Jun 30, 2022 at 5:48 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    uh, no, that will not fit. your tire will rub the upper control arms.
    BlueRibbon4x4 likes this.
  5. Jun 30, 2022 at 6:00 AM
    BuzzardsGottaEat
    BuzzardsGottaEat New Member
    '16 Tundra DCLB
    Round Tires
    Only annoying threads are the whiners . . . :wave:
  6. Jun 30, 2022 at 9:19 AM
    TM1107
    Even with spacers?
  7. Jun 30, 2022 at 9:24 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Need spacers or lower offset wheels. Or go with a narrower tire.
  8. Jun 30, 2022 at 9:34 AM
    TM1107
    Yeah I figured spacers would be necessary. I was thinking 1.5” or so. Which puts me around +20
  9. Jun 30, 2022 at 9:36 AM
    Netmonkey
    Georgetown, TX
    yes, if you use wheel spacers, then you can fit that tire and wheel combination. +18 to +25mm offset for the wheels is the sweet spot.
  10. Jun 30, 2022 at 10:25 AM
    Zolander
    Zolander New Member
    Zorro
    OffRoad
    With spacers yes or correct wheel offset
