Moisture in drivers side of double cab door step panel.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Oregon 1 Toyo, Jun 18, 2022.
  1. Jun 18, 2022 at 8:06 PM
    Oregon 1 Toyo
    Oregon 1 Toyo [OP] New Member
    2014 Tundra sr5 double cab 4x4
    Has anyone had moisture collection under the plastic step piece or threshold. I was getting a little mold appearing near the trim then popped the step panel off and found moisture in the channel under it. I do have air lines for my air bags running through there. Anyone else had this problem? I have a 2014 double cab 4x4.
  2. Jun 29, 2022 at 2:57 PM
    fmscott2
    fmscott2 New Member
    I’ve heard this can occur due to loose screws on your top rear brake light housing. Water gets into the top brake light lens and trickles down into the cab.
