Can I swap electric seats into a base SR5 with manual seats?
Discussion in '2nd Gen Tundras (2007-2013)' started by mda185, Jun 28, 2022.
  1. Jun 28, 2022 at 8:38 PM
    mda185
    mda185 [OP] New Member
    Mark
    2013 Red Tundra Rock Warrior
    I have a 2013 Rock Warrior with the basic SR5 manual cloth seats. I am wondering if the wiring is there under the carpet to enable me to swap in some electric heated seats from a Limited model. I would look myself but my Tundra is currently in the body shop. I was rear ended in a Home Depot parking lot by hit and run driver. I was inside picking up lumber and came out to find my bumper and hitch pushed in and up which also screwed up my tailgate.
  2. Jun 28, 2022 at 9:06 PM
    kanger328
    kanger328 New Member
    Anchorage, Alaska
    2012 DC 4x4
    Should be able to if using donor seat from another Tundra.
    I have a Tundra Grade trim and was able to directly fit Limited powered seats from a Sequoia on driver side. Passenger side was not direct fit for wiring though. The wiring is in the floor under the carpet. Another Tundra seat should fit wiring. I’d still check before actually buying donor seats.
    I would disconnect battery before plugging in donor seat though. For some reason, my fuses kept blew when hooking up seat wiring.
  3. Jun 29, 2022 at 4:59 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Yes they will bolt in. If you stay with 07-13 limited seats you have a much better chance of wiring being plug and play. Passenger side occupant detection ecu might be the hardest thing to wire in.
    Mine did not have the wiring for power seats unfortunately. My new seats are driver side power only, I added in a power wire to the factory body control module to power my seat and works like factory.
    If you buy 2014+ seats, seatbelts will be different fyi
