  1. Jun 27, 2022 at 4:35 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I gotta say - they are legit and look really nice. I consider White Knuckle the benchmark after my research. I think these are likely as good - you can lift half the truck using them, and I opted for welded on with bolted tabs which is actually stronger. They can be unbolted for finish if one likes. Billy also doesn't charge enough, so if you can handle the wait...
  2. Jun 27, 2022 at 4:36 PM
    Openbaffle
    Openbaffle New Member
    I’d love a pair of those sliders as well. Other side of the country however.
    alb1k likes this.
  3. Jun 27, 2022 at 4:38 PM
    alb1k
    Left Coast
    It's good
    Shipping to me would have been $200 for 8 footers. I paid that much in gas, but I realized without a lift and rad weld skills, I wanted those guys to install them.
  4. Jun 27, 2022 at 4:42 PM
    alb1k
    Left Coast
    It's good
    :yes:
    abcinv likes this.
  5. Jun 27, 2022 at 4:46 PM
    alb1k
    Left Coast
    It's good
    I gotta say - those grilles do look pretty rad.
    jerryallday[QUOTED] likes this.
  6. Jun 27, 2022 at 4:59 PM
    I've lifted my truck from the sliders before just for kicks. I will say, I think you should have had them powder coated first. Are you taking them off to get that done? Also, I think Billy's prices are a lot more reasonable. White Knuckle raised their prices and they are a bit outrageous now.
    805Tundra likes this.
  7. Jun 27, 2022 at 5:04 PM
    alb1k
    Left Coast
    It's good
    I don't plan to powder coat them. I know that's the go-to, but I'm more of a spray shit on there and touch up or respray as needed kinda guy for this. I'll probably POR-15/and rattle something else.
  8. Jun 27, 2022 at 5:29 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Took the Taco to the new property. Sequoia did the hard work here though, Tundra got a weekend off from moving.
    NUDRAT, Voss, bmf4069 and 4 others like this.
  9. Jun 27, 2022 at 5:53 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    :woot:
    I have been leaning towards these for awhile, nice to know they are good quality and of course the price tag on these things are great! definitely want to get some soon. how long did you wait?
    alb1k[QUOTED] likes this.
  10. Jun 27, 2022 at 5:57 PM
    alb1k
    Left Coast
    It's good
    A lot longer than the advertised 20 weeks. I think it was late November when I made the order. Some things go faster than others, but nothing is fast - they can't keep up. However, from the 805, no better deal. So...
  11. Jun 27, 2022 at 5:59 PM
    alb1k
    Left Coast
    It's good
    Here's the weld tabs / bolt setup. +130 currently, but I like it a lot.IMG_2413.jpg
  12. Jun 27, 2022 at 6:05 PM
    That was my plan too. I followed the steps White Knuckle recommend and had horrible results when I spray painted my sliders. The paint just scraped right off with my fingernail.
    Discussed here and here.
    If you move forward with painting, don't do what I did. It ended up costing me more in the long run than if I had just powder coated them to begin with because I had to pay them to sandblast them.
    Also, when this was happening @Casper421 told me he ended up dealing with similar headaches with painting his sliders on his 4Runner(I think).
    oscardog86 likes this.
  13. Jun 27, 2022 at 6:23 PM
    alb1k
    Left Coast
    It's good
    I'm 100% with you - Powder Coat is the gold standard. My current plan is POR-15 everywhere. I need to do the frame anyway and it's a really good base and rust killer. It does not like UV, so it's not a sun side finish for looks anyway. After that, I was going to Raptor spray the top/visible parts. I have that on both bumpers and it's awesome. It better be at $30-45 a can. However, after I fuck this all up, I will admit it and triple my expense by doing PC after the fact.
    I know for sure I can't rattle a decent paint finish - I won't try. A textured finish is another story. And the durability I've seen. But, it's also a preference thing. If my plan was a semi or gloss painted look - powder coat is the only choice, IMO.
  14. Jun 27, 2022 at 6:26 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Powder coat is great if you live somewhere without salt. Even then it's great until it isn't. Once it gets a scrape the rust grows under the coating and it just flakes off in big sheets.
    Siebler, alb1k[QUOTED] and shifty` like this.
  15. Jun 27, 2022 at 6:26 PM
    Yup. Powdercoat is a bad idea, you're just encapsulating the steel with a coating. Any perforation, scratch, or similar, and you've got a water entry point, and that water can never get out. Powdercoat doesn't bond to metal, it just encapsulates it. Actually, POR-15 is similar, but closer to a hybrid between paint and powdercoat.
    A good self-etching primer will physically bond with metal, then applying paint topcoat that bonds with the primer, you've got a great seal. Have issues, dent, scratch? Sand, re-etch prime, re-paint. No problemo. If it's chunky, debride, treat, prime, paint, or fill.
    OTOH, hit a rock on your trip, and flake off the coating? It's not like you can just powdercoat over the spot. Nope, gotta remove the PC, which isn't totally difficult with acetone, but not as easy as paint.
    I'll never understand how powdercoat got such a high durability reputation, it's too damn fallible. I get it, it's a fraction of the cost of a proper paint job when measured pro vs. pro application, but it's nowhere near as bulletproof.
    Quick edit: Looks like Fester and I posted at the same time basically saying the same thing :D
    oscardog86, Siebler and alb1k[QUOTED] like this.
  16. Jun 27, 2022 at 6:34 PM
    Can't say that I agree with much of this. In my case, the self etching primer and paint literally came off with my fingernail. I'll never try to paint bare metal again. Maybe it's like doing a garage floor in that it has to be scuffed first?
    My powder coat has held up great for two years now. When it's gotten a chip I've touched up with a rattle can. Certainly no need to remove the PC like you said.
    I would have been perfectly fine using spray paint or truck bed in a can but it just wasn't bonding to the metal.
    alb1k likes this.
  17. Jun 27, 2022 at 6:34 PM
    alb1k
    Left Coast
    It's good
    I guess my thinking has been, if the sliders ever get used, and they will, a proper chroming would be fuct. So, go with protecting the metal and touch it up as needed. For aesthetics and functionality, and touch-up, That raptor stuff is pretty hard to beat. As long as you are good with orange-peel texture.
  18. Jun 27, 2022 at 6:43 PM
    alb1k
    Left Coast
    It's good
    It comes down to abrasion resistance, IMO. And I agree, PC is more resistant than any other semi-gloss finish you can put on a part, except maybe? factory car paint? That has it's whole process and it's not coming out of a can either. IMO, do whatever works for you in the areas that are visible, used as steps, etc. The bottoms could be raw for the most part, on some dude's trucks they get that way every trip, to a point...I haven't done anything to them yet or tested the results, so don't hold me to anything. I'm going for looks good and easy to touch up.
  19. Jun 27, 2022 at 6:45 PM
    The key to a bulletproof paintjob is prep, prep, prep. Yes, mechanical etching is probably critical, or at least chemically etching with steel/concrete prep, you can't just lay paint on bare steel that's had seen even 24-48 hours of humidity we have here on the east coast. Edit: And I know some guys who'll hit their bare steel w/WD40 for example, just to keep humidity rust at bay, and paint won't stick to it. Unless you know the person who did it, their steel source, or their practices, you always need to treat. I recommend steel/concrete prep in a spray bottle, followed by a paint prep spray.
    Outside of that, the most difficult concepts for me to get through my thick ass skull were recoat windows and, more importantly, cure time. Your average enamel, if not baked, typically takes weeks and can take months to fully cure depending on the ambient temperature. My experience has been, I get the best paint if I follow the full cure time on the self-etch primer can after laying down necessary recoats, then sand as needed, then topcoat assuming your primer calls for it. Some primers I've used give you specific topcoat instructions for the final paint, to ensure bond between topcoat and primer, and primer to substrate.
    But at the end of the day, it's all about prep. Seriously. If you were scraping shit off with your nail, you either didn't surface prep, or didn't allow enough bond/cure time.
    I wouldn't chrome, but it's more durable than PC because chrome is a forcibly-bonded coating. Unfortunately, it's porous. And it flakes if water gets under it.
    I also have beef with bedcoatings I've aired here, but I can't tell you the last time I saw someone with a raptor-lined truck with panels rotting off, or the liner chipping. I've seen plenty of rhino-liner balding, and had issues with line-x flaking off an aluminum tank I installed in one of my LS-swaps, and seen shit jobs with other brands. I don't have a gauge with raptor products.
    oscardog86 and alb1k[QUOTED] like this.
  20. Jun 27, 2022 at 6:49 PM
    Shameless plug: This is my favorite stuff to use on surface rust, bare metal, kinda like what you'd have gotten with your sliders. You can buy it all day long at your favorite big-box hardware store. This in a spray bottle, sprayed on and brushed in every nook and cranny with a little bronze wool or steel wool for more chunky surface rust will get your steel gleaming and ready to go again.
    oscardog86, Siebler and alb1k like this.
  21. Jun 27, 2022 at 6:52 PM
    alb1k
    Left Coast
    It's good
    I got no time for that stinking cure! Lol. Without a doubt, cures and bakes when indicated are essential.
    As a newly trained listener - here's what I got without listing the lessons:
    The last several posts offered options that are based on knowledge and experience. Any dude off the street could read back an hour and weigh the pros and cons of most available options, including chrome dip (you're welcome) and make an informed choice. Pretty cool. :101010:
  22. Jun 27, 2022 at 6:56 PM
    alb1k
    Left Coast
    It's good
    Yea, but it's harmful if swallowed :rofl:
    bmf4069 likes this.
  23. Jun 27, 2022 at 6:57 PM
    Any idea how this compares to acetone? That's what I used to clean the metal before applying primer when I attempted to paint mine. Pretty sure I got that suggestion from a video on YouTube from FristGenOffroad.
  24. Jun 27, 2022 at 7:01 PM
    alb1k
    Left Coast
    It's good
    I can tell you from my knife making days, acetone leaves a film. I bought it by the gallon and chased it after dry with denatured alcohol. I learned that from some pretty critical dudes. Now, I was using that as prep for 2 part structural adhesive, but, acetone leaves a film.
  25. Jun 27, 2022 at 7:11 PM
    Yup, but I've seen people recommend it or mineral spirits as a prep. Acetone will dissolve PC though, that's a plus. It's good for cleaning/thinning/sealing edges of PC.
    But yeah, denatured alcohol. That's basically what's in the paint prep spray cans aka 'wax and grease remover'.
    Acetone will dissolve contaminants and remove old paint. It won't do shit to surface rust. It can leave a film behind. Clean panels with paint prep spray. But always, always always use an etch like I posted when working with bare steel unless you sand it first, then rinse, blow off, and use heat to dry. Then follow with paint prep spray, then self-etch primer.
    https://www.youtube.com/watch?v=Sumb3GYuAT8
  26. Jun 27, 2022 at 7:13 PM
    Just a friendly reminder: I'm not a pro. But I've painted a shitload of bike frames in my lifetime and learned the hard way far too many times.
    KK6PD and alb1k like this.
  27. Jun 27, 2022 at 7:20 PM
    alb1k
    Left Coast
    It's good
    Now, with the technical stuff out of the way - Orchard Supply Hardware used to have some professional enamel rattle can that beat the shit out of anything out there. I guess Lowe's closed them. But I had a 77 Jimmy and used it on the tie-rod (long bar connecting both hubs). No real prep but a hand sand, that thing took all road crap, and the paint pretty much said "no problem". Definitely an undercarriage use, but I miss that stuff.
  28. Jun 27, 2022 at 7:28 PM
    alb1k
    Left Coast
    It's good
    I found out that you tube is pretty easy so I'm trying to use it more. Here's a sense of the BFF sliders from the rear.
    https://youtu.be/CdHgK_yhmZA
    sportbike37, 805Tundra, Voss and 4 others like this.
  29. Jun 28, 2022 at 6:38 AM
    Openbaffle
    Got the other tires and wheels in the garage in preparation for selling them (Let me know if you know anyone that is interested in the Raleigh area!). Sitting nice now this morning.IMG_0552.jpg
  30. Jun 28, 2022 at 7:58 AM
    snoope
    snoope The Old Man
    Still "making it my own" :thumbsup:
    Noises and rattles :annoyed:
    Purchased a body fastener/bolt kit and started "chasing loose/worn" parts :monocle:
    Both front inner fenders needed attention , WTF o_O Tundra is 20 years old...should be built better :rofl::rofl: and the fender flares needed upgrades to the bolts.
    Local Auto Store said 3M double side tape was on national back order;Amazon delivered the next day :confused::rolleyes: Now the Window shades are quiet :cool:
    And being in Florida , the latest addition, SunPass installed....
    Next upgrade will be window tint for the front doors ; Factory keeps back cool BUT now to decide between Good film or Ceramic...:anonymous:
    bmf4069 likes this.
