Radiator conversion
Discussion in '1st Gen Tundras (2000-2006)' started by ROBSTAS1981, Jun 25, 2022.
  1. Jun 25, 2022 at 7:49 AM
    ROBSTAS1981
    ROBSTAS1981 [OP] New Member
    Rob
    2001 Toyota Tundra TRD 4.7LV8 4WD
    TRD LIMITED 4.7L V8 4WD CAMMED ENGINE NEW HEADS. 250K ON TRUCK BUT 50K ON REBUILT ENGINE. SELLING MY OLD 00 TUNRDRA 3.4V6 4WD NEEDS BODY WORK LEAF SPRIND AND TRANS BRACKET INSTALLED WHIXHBI HAVE. NEW 13K CRATE ENGINE FROM JAPAN 40K REBUILD TRANS AND TRANSFER CASE SAME TIME. FRAME RECALL DONE JUST LOST HEAT 1K RUNS DRIVES AWESOME JUST COLD WITHOUT HEAT. 1K TAKES IT OUT MY GARGAGE ASAP. THANK YOU.
    Hello, juat wondering if a radiator form a 3.4L T100 will bolt in my 00 Tundra 3.4L??? Any help would be greatly appreciated thank you
  2. Jun 25, 2022 at 3:19 PM
    bfunke
    bfunke Tundra Curmudgeon
    It should. Do you already have this radiator? If not buy the Denso from RockAuto
  3. Jun 25, 2022 at 3:46 PM
    Just curious, how do you know a T100 radiator will bolt right to a first gen Tundra? We've never had a member do this and it's a completely different truck.
  4. Jun 26, 2022 at 2:36 PM
    ROBSTAS1981
    Rob
    I do not have it yet but I can found one 4100 a lot cheaper than the tundra and they looked identical I was wondering if they both of them I don't even know if I need one I take my radiator cap off and pretty like Rusty crusty and s*** around there and the guy that had it before me took the red Toyota Corolla oil and put regular corn in which is a big No-No in these Toyota I work for Toyota 47 years and they swear that you want to run their Toyota right any fries or it will screw up your heater head and heater cores and radiators so I don't know if I should just do it rain in Flushing for the red stuff back in and see if I can get lucky or if I actually need a new radiator thank you for replying I like this form I love these 1st Gen Toyota Tundras if you. I don't know if I need a new radiator exactly I open up the cap and it's all like red Rusty crusty stuff on the table and I think that if I do a drain and fill it might be all right I'm not running hot or cold or anything like that seems to run fine but it just doesn't look very healthy I like to flush it out put the Toyota right stuff back in but if I do that I don't want to have this ready and everybody jump so I'm thinking about is a T100 radiator I found $40 free shipping and it's a Denso so I think that would be my best bet but I just didn't know if they both in the same I thought they use the same cross members in the same radiators but I'm not 100% sure I missed a few 100 I wish they didn't rust out in Maine where I live LOL any other advice would be awesome thank you very much for applying
  5. Jun 27, 2022 at 2:10 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  6. Jun 27, 2022 at 4:39 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    The specs listed for the two radiators above:
    Tundra:
    Core Height 21.6250 in.
    Core Thickness 1.2500 in.
    Core Width 27.1870 in.
    Inlet Diameter 1.3750 in.
    Outlet Diameter 1.5620 in.
    T100:
    Core Height 17.8120 in.
    Core Width 27.0620 in.
    Outlet Diameter 1.3750 in.
  7. Jun 27, 2022 at 5:46 AM
    ROBSTAS1981
    Rob
    Thank you to the ones that lent their advice. I think I'll try a clean flush and refill with red Toyota coolant, where I'm nit having any issues besides it looks like shit around the cap. If I have money I'll just buy either a Performance aluminum or denso. Than u all again much appreciated.
  8. Jun 27, 2022 at 5:47 AM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    From what I've read around the aluminum "performance upgrade" radiators still aren't as good as Denso. Leaks around the welds or the corners.
  9. Jun 27, 2022 at 7:28 AM
    tvpierce
    Maine
    Do you have a manual or automatic transmission?
