Diagnostic Scanner Tool
Discussion in 'General Tundra Discussion' started by Bergie4449, Jun 17, 2022.
  1. Jun 17, 2022 at 10:33 AM
    Bergie4449
    Bergie4449 [OP] New Member
    Fred
    Auburn, CA
    2006 Tundra DC Limited 4wd
    Greetings! I’m looking to buy a diagnostic scanner and willing to spend up to $1,000. I have a basic Obd2 which gives me the code. My vehicles vary from 06 tundra to 2017 Audi. Recommendations please.
  2. Jun 17, 2022 at 8:34 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    so what are you trying to do exactly? are you looking for ABS/SRS, TPMS programming...or just want to display pegs to do some advance diagnosis?
    Take a look at this one.. but only comes with 3 years or support.. BTW Ancel makes some great OBD2 readers... also you may look on fbmp.. most people may be willing to sell you one for half off..
    Bergie4449[OP] likes this.
  3. Jun 18, 2022 at 3:55 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    Autel Maxicom MK808 (MK808BT if you want cordless version) would be my recommendation its right at $550, great for at home or small garage application's it will give you a lot of control over different modules that others won't and the full module sets.
    The only thing I'm not sure on is if it will support added scopes. So I guess that would be my next question is "Do you want to be able to use scope functions on the device?"
  4. Jun 24, 2022 at 6:06 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    A step up from your basic OBDII scanner is a Bluedriver which provides the ability to not only read the engine OBDII codes but also HVAC, SRS, ABS and Trans codes depending on your vehicle. It does not program keys or TPMS sensors. It's what I have and is only around $120.
    https://us.bluedriver.com/pages/bluedriver
    I work on a wide range of cars (but primarily Toyota) and have been considering stepping up to a scanner having bi-directional control and ECM Flashing capability for 5+ years but have avoided the need so far. I don't want to make that purchase until I have to because of the continuing update costs and advancing technology. If I had to pull the trigger today, I would get a Toyota specific Mongoose and a 2 day TIS/Techstream subscription only when I needed to use it. They have a VW/Audi version but I don't know the specifics. For most purposes and other manufacturers, I would continue to use the Bluedriver.
    https://www.aeswave.com/Mongoose-Plus-Toyota-3-p10052.html
    https://www.aeswave.com/Mongoose-Plus-VW-Audi-2-p10079.html
