Looking at this guy tomorrow, any thoughts?
Discussion in '1st Gen Tundras (2000-2006)' started by singher, Jun 23, 2022.
  1. Jun 23, 2022 at 6:12 PM
    singher
    singher [OP] New Member
  2. Jun 23, 2022 at 6:17 PM
    shifty` Ten EV 12's so you know I raise hell
    Don't get me wrong, loaded up that's a lot of stuff for $20k in California, for a Limited 4WD w/only 130k.
    But seriously. Check that frame. Seeing how much orange is inside that rear hub and is visible on the rear framerail in the same pic, I'm skeptical about the truck's history. But I always lean toward the worst.
    Also, make sure that timing belt was changed within the last 30-40k or past 3-5 years as it should've been. Change interval is 9yr/90k miles, but can fudge out to 10yr/10k.
    1lowlife likes this.
  3. Jun 23, 2022 at 6:21 PM
    This pic. And also, note the passenger step is bent downward.
  4. Jun 23, 2022 at 7:36 PM
    singher
    Belt was changed at 86 K in 2018. I was gonna try to negotiate for just the truck Im not really interested in all the extras. I noticed the rust there but wasn't sure if it was just on the actual wheel itself but will definitely look underneath. Ill take a look at the passenger step thanks I didn't catch that one. Will update after I lay eyes on it
    1lowlife and shifty`[QUOTED] like this.
  5. Jun 23, 2022 at 7:46 PM
    Can't help but think the other stuff he's got on there would be worth at least 25-50% more than the extra cost. Could be a good possible resale to another CA member, but I dunno.
    If you got a small ball peen, tap around with the ball end. Look deep above the spare tire and where its "X" crossmember hooks into the main framerails. He's not showing any under-hood shots, look for rust on the heads of things under the hood, signs of rust on bolts high up under the hood, like at the top of the radiator support, I've typically only seen on salt-belt trucks.
    Pop the oil filler cap and shoot a light down inside. You want to see silver to golden. Anything that looks more like lacquer or shellac could be signs of short-trip syndrome like mine.
    Otherwise, no BS, I think it's a pretty solid price.
    WBW and 1lowlife like this.
  6. Jun 23, 2022 at 10:08 PM
    singher
    Probably true but id rather not have to deal with reselling all of that honesty. You talking about tapping around the frame of it? I got the vin and it looks like its been in the bay area its whole life. Ive been seeing some comparable 2wd trucks up for like 12.5 or 13, would 4wd be worth the extra 5 or you think I could offer him down some?
  7. Jun 24, 2022 at 5:39 AM
    Is it really 9 years? I've seen 7, 8, and 9 years listed. Since I'm only driving ~100 miles a month I'm going to be due based on time before miles. My current belt is 5 years old.
  8. Jun 24, 2022 at 6:20 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    The Toyota Maintenance schedule speaks of months/miles concerning timing belt change.
    For instance for your 2002 they suggest 90K miles/72 months. For my 2004 they bumped it up a bit months wise....90K miles/108 months.
    2002....https://assets.sia.toyota.com/publications/en/omms-s/MSTOY02-MS0003/pdf/MSTOY02-MS0003.pdf
    2004....https://assets.sia.toyota.com/publications/en/omms-s/MSTOYALL04_MS0016/pdf/0411smt.pdf
  9. Jun 24, 2022 at 6:46 AM
    Ouch. That means I would be due next spring. My timing belt only has 38k miles on it.
    I might extend it to 108 months. I bet Toyota realized that 6 years was too soon. Can't imagine anything is different about your belt over mine.
    BubbaW[QUOTED] likes this.
  10. Jun 24, 2022 at 7:52 AM
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Eibach Pro Sport Shocks (1.25in), RAS HD, Sumo Springs, HAWK Talon Rotors, OEM Tow Mirrows, Lund Hard Fold Tonneau, ESP Storage, Stampede Flares, Husky xAct Fit liners, General Grabber ATX 275/60R20
    @singher. You should also check the rack and pinion. For that truck (I own an 06 Dbl Cab also) that's the $1100 replacement model. Look for leaks/torn bellows and any play or weird noises when turning steering wheel.
  11. Jun 24, 2022 at 8:18 AM
    With modern materials, 90k/108mos (9yrs) is a pretty safe bet. It may not have been the case with the OEM parts. We've definitely seen guys here make it well into the 100k's of miles with the original belt.
    Anyway, it's super easy to inspect the belt for peace of mind. Make a point of checking it at each oil change, which should be at least once a year with the mileage you're pushing.
    Mine's also at the 5yr mark, IIRC. I'm going to stick with 10yr/100k miles as I've done with all my other vehicles. OEM/Owner's manual always errs on the side of caution for legal reasons.
