Wheel vs Tire width
Discussion in 'Wheels & Tires' started by TM1107, Jun 23, 2022.
  1. Jun 23, 2022 at 5:46 PM
    TM1107
    TM1107 [OP] New Member
    So maybe I'm not that bright, but I see a lot of people on here running 20x9 wheels with 35x12.5 tires etc. Basically, how do you run a tire that's wider than your wheel? It just doesn't make sense to me :monocle: thanks in advance!
  2. Jun 23, 2022 at 5:59 PM
    Brums
    Brums New Member
    Bethel, OH
    22 Tundra DC TRD Sport
    rubber is quite the resilient material,
    but basically, in theory that tire would fit a 12.5 inch wide rim, would never put it on one that size, cause you get into stretch and sidewall deformation, can be dangerous etc..
    but every tire manufacturer has specifications on what rim sizes their tires will fit
    this nitto terra grappler, states it will fit an 8.5 to 11.0 inch wide rim
    the tire literally is "squished" on a smaller width rim, and it is "stretched" on a wider rim,
    hope that helps
    Saltyhero13 likes this.
  3. Jun 23, 2022 at 6:09 PM
    Brums
    Brums New Member
    Bethel, OH
    like this is dangerous stretching
    the middle one of this would be some pretty extreme squish, the person mounting the tire would have a hard time putting on the tire
    the right side would be stretch, like the tire above
  4. Jun 23, 2022 at 7:13 PM
    TM1107
    well alright that's easy enough! Thanks
