Sway Bar Issues?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 14TundraToy, Jun 5, 2022.
  1. Jun 5, 2022 at 3:08 PM
    14TundraToy
    14TundraToy [OP] New Member
    Jerry
    2014 Tundra 4x4 Crew Max
    3" King Adj. Coil-over, RCI Full body Skids, RockSlide Eng. Sliders, 35" Too RT's, SnugTop Shell, Lighting all around.
    Hello,
    I have a 2014 Tundra that i recently changed my lift kit out for the new 2.5 Adj. Kings set for 3" lift to match what i have been running. I now have issues with my front sway bar contacting the coil-overs bottom bucket. This has caused surface damage to the buckets and i am looking for relocation brackets to fix this. I have only been able to get drop brackets and that did not work. I need to move the bar forward at least 1/2" to 5/8" to creat a space between the two moving parts.
    Has anyone had this issue and what was the fix besides removing the sway bar.
    Any help would be great.
    Thanks All
  2. Jun 5, 2022 at 6:35 PM
    Kernal
    Kernal New Member
    Kyle
    Charleston SC
    ‘18 4x4 4x4 DC
    Just take it off and throw it in the garbage. If you actually off-road your truck you’ll be happy you did.
    wyoboypt, SR5BART, pvn.beluga and 5 others like this.
  3. Jun 5, 2022 at 6:42 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    ^ that
  4. Jun 5, 2022 at 9:16 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Absolutely take both off and enjoy.
    wyoboypt and pvn.beluga like this.
  5. Jun 12, 2022 at 6:14 AM
    14TundraToy
    Jerry
    The wife drives it every once in a while so it has to stay. It would be nice to have quick connects. But for now i need to modify the position of the bar to work.
  6. Jun 12, 2022 at 4:25 PM
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
    Bilstein 6112/5160 3/1 w/CB shackles Ironman front bumper, 18+SR5 Honeycomb grill
    Let me know what u find. I have that issue also
  7. Jun 12, 2022 at 4:39 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Stupid question, but the lower shock mount spacers are installed the correct orientation?
    831Tun likes this.
  8. Jun 12, 2022 at 4:53 PM
    Wahayes
    Will
    2017 tundra limited
    Does this make a clunking noise when it happens? I think it's happening to me
  9. Jun 15, 2022 at 5:17 PM
    14TundraToy
    Jerry
    There is no clunking noise but you can see the rub markings on the shock lower cup. Yes the shock spacers are installed correct we did check that right off.
    Sway bar is off for now I'm heading up to the Mountain this weekend. See how the wife feels driving it. I am going to keep looking for the right parts. Any help would be great.
  10. Jun 15, 2022 at 7:42 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    This seems to be common with kings. Can’t you round off the sway bar ends?
  11. Jun 15, 2022 at 7:46 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    On the Tacoma, the king coilovers come with a new mounting bracket for the swaybar. Did the tundras not come with one?
  12. Jun 15, 2022 at 7:50 PM
    M3Tundra-JK
    Scott
    2005 GX470
    You can kinda see it here. Maybe
  13. Jun 15, 2022 at 8:23 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I’ve seen lowered brackets before. I’d take off the front tho personally.
  14. Jun 15, 2022 at 8:23 PM
    xtyfighterx
    Ty
    North Idaho
    Did you get an alignment done yet??
  15. Jun 15, 2022 at 9:45 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    This might sound like a dumb question but if you go off road, you probably wouldn't have sway bars to begin with. If you dont go off road, what is the on road advantage to lifting a truck?
  16. Jun 16, 2022 at 3:32 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    To actually answer your question, Icon, Toytec, and Readylift sell relocation brackets specifically for this issue. Around $40.
    Leo's first likes this.
  17. Jun 16, 2022 at 1:10 PM
    14TundraToy
    Jerry
    To catch up with everyones responses Yes i did the alignment didn't do anything. I agree for the offload i did remove it for the 5days in Death Valley but reinstalled for the streets. I have tried the Ready Lift part #5008 which shows a relocation but it is only a spacer for the Tundra, same with the Toytec. The relocation bracket shows the 4 holes that will allow the mounting of the sway bar 1/2" forward but they are for the tacoma and 4Runners. You call them and they can't answer why the picture doesn't natch the product numbers.
    I am over to for a while i have removed it and like it but wife when she drives it will just deal with it.
  18. Jun 16, 2022 at 1:24 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Don’t the drop brackets shift the mounting points by 1/2” or so? Make sure they were turned the right way?
  19. Jun 22, 2022 at 4:15 PM
    14TundraToy
    Jerry
    The drop bracket moves it down and that shifts it a little but not forward enough to count. It's off now and i am good and wife doesn't drive it enough to worry about it but i am going to still look for a way to make it work someday.
  20. Jun 23, 2022 at 11:23 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    If you're happy with your caster, then you could try changing your misalignment spacers so that the one closest to the sway bar is longer than the other side - either switch them around (if they're different sizes and the shorter one is on the sway bar side) or purchase a new set. I had to do something similar because my CV boot was rubbing on my spring.
    batman900 likes this.
  21. Jun 23, 2022 at 3:07 PM
    xtyfighterx
    Ty
    North Idaho
    I suggested that to.
    batman900[QUOTED] likes this.
