3/2 Lift options
Discussion in 'Suspension' started by TM1107, Jun 19, 2022.
  1. Jun 19, 2022 at 3:31 PM
    TM1107
    TM1107 [OP] New Member
    Hey everyone, first post here and there is a TON to digest. I’ve got a 2016 limited 4x4 and I’m wanting to do a 3/2 lift on it. Im also wanting to keep the price a bit lower, maybe $5-600, and perform the job myself. With that being said I’m looking at ReadyLift/Rough Country spacer kits, or a Bilstein 5100 lift. Main questions are 1) why do the spacer lifts make the ride worse? 2) what other parts would I need for the 5100 install? 3) any other recommendations for other options?
    The truck is on pavement 95% of the time, with the other 5% being on decently maintained dirt two tracks, so no REAL off-roading.
    Thanks in advance!
  2. Jun 19, 2022 at 3:33 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    My only response after reading and experiencing needed changes to what was bought - adjustable coilovers.
  3. Jun 19, 2022 at 3:39 PM
    +1 on coilovers. I've had the Readylift 3/2 spacer kit....never again. Rode terrible.....picked up every bump. Switching to my Toytecs was a night and day difference.
    alb1k likes this.
  4. Jun 19, 2022 at 3:48 PM
    TM1107
    Any options for coil overs in my price range?
  5. Jun 19, 2022 at 3:52 PM
    Toytec complete at the bottom of the page. That particular set isn't adjustable height wise but they are a descent set.
    alb1k likes this.
  6. Jun 19, 2022 at 3:55 PM
    alb1k
    Left Coast
    It's good
    I don't know your price range. I only know that the initial cost increases when you have to make changes to suit your needs if your front is locked in. Doesn't matter if it's street / off-road or both. I would get bilsteins at the minimum, they give you options with the perch clips. Or just get King or Fox and never look back.
    I should add, I'm first gen. Listen to guys like @Tundra234 first. But, really, the lessons are the same.
  7. Jun 19, 2022 at 8:12 PM
    jaflynn738
    jaflynn738 New Member
    Virginia
    I just had the Bilstein 6112 coilovers installed and love them. I went with the fourth setting for 2.5 inches.
    alb1k likes this.
  8. Jun 20, 2022 at 4:37 AM
    TM1107
    When it comes to installing Bilstein 5100s up front, do I need anything else? Or do I just use OEM coils? And then for a rear 2” lift just a block/U-bolt set up?
    Also a quick side note, why are spacer lifts so rough? It seems to me that it wouldn’t change anything since it’s ABOVE the coil and not preloading it
  9. Jun 20, 2022 at 4:43 AM
    War Machine
    War Machine SSEM # 5 3MW
    I have a spacer 3/2 on my 2017 (the truck came with it). Didn’t realize how rough it rode until I got my 21 with no lift. Can’t speak to the difference with a different kind of lift but it’s definitely a hell of a lot rougher than stock.
