Dented Oil Pan
Discussion in '1st Gen Tundras (2000-2006)' started by w.verd, Jun 19, 2022.
  1. Jun 19, 2022 at 9:59 PM
    w.verd
    w.verd [OP] New Member
    Will
    2006 Crew Cab 4wd
    Hello everyone, first post here.
    I’ve got an 06 V8 tundra 4wd, and I recently dented the oil pan. I would like to get some thoughts on if it is necessary to replace the pan. My current thoughts are that’s it’s probably not a big deal, and I may replace the pan and gasket at some point in the future, especially if I’m doing other repairs in the area. It seems that either the front differential needs to come out or the engine needs to be lifted to make space for this.
    Thoughts? Thanks,
    YardBird likes this.
  2. Jun 19, 2022 at 10:00 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I don't see a problem.
  3. Jun 19, 2022 at 10:04 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You have a custom slightly reduced capacity pan
    Filthyphil, alb1k and YardBird like this.
  4. Jun 19, 2022 at 10:51 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    The skid plate should cover that right? Did you mess that up too or is it missing?
  5. Jun 19, 2022 at 11:14 PM
    gascap
    gascap New Member
    2002 Tundra
    As long as you don't hear any noise from there it's no problem. You'd have to have the crankshaft hitting against it before it's a concern.
  6. Jun 20, 2022 at 4:48 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    +1, a buddy and I took his dad's Pinto down a dirt road deer hunting in WV. A big snowstorm hit and a Blazer towed us out. The oil pan hit a rock and the crank shaft was beating the crap out of it.
    gascap[QUOTED] likes this.
  7. Jun 20, 2022 at 5:21 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    dented my 06 oil pan like that a long time ago when installing new headers, no issue came of it.
  8. Jun 20, 2022 at 5:57 AM
    Retired...finally
    Hard to tell by the photo just how far it's pushed in. From experience two dented pans on other types didn't turn out well. One pushed the pan into the sump pickup resulting in low oil pressure and another broke the sump pickup off allowing oil pickup only if the oil level was at the top of the oil level. Going around a turn caused oil starvation.
    Mr.bee likes this.
  9. Jun 20, 2022 at 6:50 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    if you didn’t hit the oil pickup tube, then it should be fine. Keep an eye on the oil pressure gauge.
    DarkMint and FirstGenVol like this.
  10. Jun 20, 2022 at 7:10 AM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Is the oil pickup tube that brown tube doohickey coming up from the bottom and going into that "mesh" strainer thing right thar?
    Also, is that flat section in the tube a problem or is it supposed to look like that?
  11. Jun 20, 2022 at 7:15 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Yes, and I’m not sure about Toyotas, but I’ve seen the welds break from the gentlest of wiggles on other engines. Either at the pump flange, or the strainer falls off.
    that pic was from ih8mud & may be from a 2uz land cruiser, but was the best pic I could find of the tube installed.
    DarkMint likes this.
  12. Jun 20, 2022 at 7:25 AM
    Lots of good answers here, but this is the most correct answer on the page IMO.
    My biggest concern would be impact with the pickup orifice and screen itself, that the pan wasn't mashed into it, preventing uptake. I haven't had my pan off to see if the pickup tube snakes around and could be dented in. But yeah. No oil volume issues from this. Just interference/uptake potential.
  13. Jun 20, 2022 at 9:34 AM
    This is a really neat and helpful picture. I've never seen the bottom of the engine exposed like this before. Thanks for sharing.
  14. Jun 21, 2022 at 10:19 AM
    w.verd
    Will
    2006 Crew Cab 4wd
    Thanks for all the replies! It looks like the oil baffle plate and pickup tube are a good bit higher than the dent in the lower pan according the the diagram in the FSM, so I think I’ll be okay. Thanks everyone!
    gascap and Bikeric like this.
  15. Jun 21, 2022 at 10:46 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Yes ^this.
    The lower steel pan being dented doesn't come close to anything. It's the upper aluminum pan that houses the oil pickup.
