Moon roof tint?
Discussion in '3rd Gen Tundras (2022+)' started by gr8fasushi, Jun 17, 2022.
  1. Jun 17, 2022 at 12:52 PM
    gr8fasushi
    gr8fasushi [OP] 22 Tundra Limited TRD Off Road
    how many of you guys have tinted the moon roof on your 22 tundra? I'm considering doing a 50% ceramic tint, but wondering if I should go darker/lighter.
    AGTundra and Wixo like this.
  2. Jun 17, 2022 at 1:30 PM
    Wixo
    Wixo The Best Member
    Mawr
    RGV
    5.7L 4x4 CrewMax SB
    Tint
    Depends on where you're from. Here in Deep South sub tropical Texas, 5% ceramic is the way to go on everything you can.
  3. Jun 17, 2022 at 2:31 PM
    gr8fasushi
    it gets pretty hot here. We get to 110+ in the heat of the summer.
  4. Jun 17, 2022 at 3:42 PM
    Wixo
    Mawr
    RGV
    5.7L 4x4 CrewMax SB
    Tint
    Then get the 5%. That sun hitting you straight from the top will heat the inside up even if you never forget to put the interior cover back in the closed position.
  5. Jun 17, 2022 at 4:00 PM
    DanSanDiego
    DanSanDiego New Member
    2019 Tundra Limited 4x4
    I am here in Southern California and have 5%. It is definitely the way to go.
    gr8fasushi[OP] and tech1208 like this.
  6. Jun 17, 2022 at 5:56 PM
    gr8fasushi
    Yeah I think I'll go 5%. It'll also look really good
    Wixo likes this.
  7. Jun 17, 2022 at 8:38 PM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    The tint installer convinced me to go with 35% (I think); I wish I had gone darker. I would probably lean more towards 5 next time.
    Wixo and gr8fasushi[OP] like this.
  8. Jun 18, 2022 at 8:00 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    I went ceramic all around- 80 windshield, 20 fronts, 80 on the back doors, 35 pano, 35 back glass. Huge improvement in the heat department
    Wixo, jmay86 and gr8fasushi[OP] like this.
  9. Jun 18, 2022 at 10:19 AM
    FLKX
    FLKX New Member
    35% here on the pano, great on sunny days for the open and airy feel and not too dark.
    Wixo likes this.
  10. Jun 18, 2022 at 10:30 AM
    mannyg84
    mannyg84 New Member
    What are you guys paying for ceramic all around (4 doors, back window and pano)?
  11. Jun 18, 2022 at 10:33 AM
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    '22 Lunar Rock LTD DC TRD-OR
    did you go 80 on rears to match 20 on fronts? I’m scheduled in a week or so and want 15 or 20 up front and to match rears to it… Can’t figure out what the factory % is…
  12. Jun 18, 2022 at 10:59 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    Factory windows are around 75%
    gr8fasushi[OP] likes this.
  13. Jun 18, 2022 at 11:04 AM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    I’ll let ya know a secret. If you get anything tinted regardless of the percentage will block the same amount of head and UVA A/B rays. This is for a semi metallic biased film.
    When you step up to a full ceramic sale rule applies, however ceramic will block out more heat.
    * when a vehicle is still and has zero circulation regardless of semi metallic or ceramic it’s still green housing. Meaning it’s going to be hot.
    * best things to fully tint; sunroof , windshield.
    Stay away from a $99.00 specials. Always ask what brand and if it’s semi metallic or other. When I sold tint Llumar was/is still my go to. However maddico is getting better and what’s on my rig.
    Kap1, AGTundra and gr8fasushi[OP] like this.
  14. Jun 18, 2022 at 11:35 AM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    20 year film installer here ….the main concern I tell my customers is with 5% kind of feels like you lose the roof visibility …the ceramic film causes the glass to absorb a lot of that heat as well …too much absorption could lead to failure/cracked glass
    We do roofs down to a 18%
    We also exclusively use ceramic film
    As far as metallic films we stay away from those bc they usually interfere with signal in newer cars/trucks
    Typically cost for ceramic installs can depend on difficulty of car but crew cab pickups run in the 400’s
  15. Jun 18, 2022 at 4:07 PM
    Wixo
    Mawr
    RGV
    5.7L 4x4 CrewMax SB
    Tint
    Wtf!? $400? Where Im from, ceramic all around done in your driveway/outside your office is $180. $195 if you want the sunroof done as well.
  16. Jun 18, 2022 at 4:34 PM
    99ways2die
    99ways2die New Member
    NJ
    2022 Tundra Platinum
    Paid $160 for ceramic in NJ. 2x fronts and sunroof.
    35% on the fronts, and 20% on sunroof....wish I went a bit darker on the sunroof itself, but understand the risks on seal/etc separations due to heat retention (due to tint).
    Slim chance of failure, I was told, but never the less the installer gave me the official warning b4 proceeding.
    -99
    AGTundra likes this.
  17. Jun 18, 2022 at 5:13 PM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    You get what you pay for in tinting…most Toyotas we remove door panels and often remove glass …tint entire window …sun cure them …then file the edges…looks like they are OEM big time
    And as far as cleanliness and consistency tough to beat
    We are also a shop with a combined 37 years experience
    We do it different
    Kap1, Blang805, DexterL and 6 others like this.
  18. Jun 18, 2022 at 5:44 PM
    t300
    t300 New Member
    Manitoba
    22tundra
    Love quality work. Wish you were around here!
  19. Jun 18, 2022 at 6:09 PM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    The new body with the pano roof would be laminated …where as previous gens would be tempered glass (crazy durable)
    The lam dual glass setups is what some shops had problems with
    I have only seen one sunroof blowup
    It was a newer body F150 with 5% on the dual roofs
  20. Jun 18, 2022 at 6:39 PM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I used 80 3m on my windshield a bit cheaper ceramic everywhere else. When the guy finished the windshield he said I have enough left over for your sunroof at no charge!
  21. Jun 18, 2022 at 9:06 PM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Dang, I'm shocked at the prices I see on here. I paid $650 for everything tinted and that was $100 off because I've had several cars done at the same place. Even before the Covid craziness and whatnot, I couldn't get my windows done for $180 by a homeless guy in the Walmart parking. I think my last truck was 450-500 before Covid.
  22. Jun 18, 2022 at 9:22 PM
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    Quoted $309 here in central OH for Lumar ceramic fronts (15%), rears (50%), and back glass (50%)… $109 more for full windshield with 70% ceramic…
  23. Jun 19, 2022 at 4:43 AM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    ….A retail-ish quote for a full truck with the WS would 550-600$ plus little more if a person wanted roof as well (Southeast NC)
    The sides and rear are one thing but in these new 60-80 thousand dollar trucks doing a WS for any less than 180-200 is crazy if you ask me
    Hell when you pull a 60in x40in piece of ceramic your prob looking at 75$ of film cost
    ‘Some’ mobile guys are my problem…they talk cheap and tint poorly and make the industry look bad
    Been in the same location for 16 years tinting
    I have to do it right…I’m too easy to find otherwise
    Kap1, Blang805, Donas and 3 others like this.
  24. Jun 19, 2022 at 6:27 AM
    Tundra1D6
    A real tinter will remove door panels and felts to truly tint glass. They will also tint to the edge of the glass and have very little if any gap, round the edges etc. sounds like you have some experience haha
    This man knows what he’s talking about. Also who gets tint done in a mobile unit. I’d hate to see the trash that ends up caught in the film.
    You get what you pay for, true ceramic tint is expensive a roll thus the cost is roughly double compared to semi metallic.
  25. Jun 19, 2022 at 6:48 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    Same on my sunroof on my 2012 Tundra
  26. Jun 19, 2022 at 8:44 AM
    I need to have my tint repaired. It was like this from 6 months old.
  27. Jun 19, 2022 at 8:45 AM
    On front windshields, do you do them in the truck or prefer before a replacement?
    AGTundra[QUOTED] likes this.
  28. Jun 19, 2022 at 9:05 AM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    :amen:
  29. Jun 19, 2022 at 9:09 AM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    It is so nice to do them out but obviously not always the case
    We use a soak rope in the firewall to try to prevent water where it shldnt be and oversized microfiber towels to protect dash/cluster areas
    We have not done a 3rd gen windsheiod yet just visor strips (not a huge fan)
    GODZILLA and ColoradoTJ[QUOTED] like this.
  30. Jun 19, 2022 at 9:10 AM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    A lot of shops don’t sink those edges very deep and it leads to that problem…I would return as soon as possible and ask for a repair
