Ever check your spare?
Discussion in 'Wheels & Tires' started by surffj62, Jun 18, 2022.
  1. Jun 18, 2022 at 4:03 PM
    surffj62
    surffj62 [OP] New Member
    2011 DBL RW
    I dropped mine the other day to replace it. Glad I did, the amount of sidewall rubbing (top of tire as it is cranked up) was amazing. Probably wouldn’t have held the weight of the truck.
    Not wanting that to happen again- any ideas? Thinking a old bike tube and gorilla tape? That really thick clear tape applied to sidewall before I crank new on up?
  2. Jun 18, 2022 at 4:19 PM
    I use a thick rubber gasket material and glued it in place.
    Good idea to drop the spare down every 6 months and rotate and clean all the dirt that collects inside the wheel. Remember to keep the spare at maximum pressure.
  3. Jun 18, 2022 at 4:26 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    I'm interested in your gasket solution if you have pics.
    When I bought my 2008 in 2020 I checked the spare and it was the ORIGINAL TIRE. All cracked up and wouldn't hold air despite having full tread. The wheel was all rusted too.
    Naturally I replaced it but I'd like to save this spare from the same fate.
  4. Jun 27, 2022 at 12:04 PM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    I just noticed this damage on my spare too, actually made me nervous airing it up to an operational pressure.
    I was thinking about acquiring a matching 5th rim to do 5 tire rotations when it comes time to replace this set of tires, but not if the tires I depend on every day will be damaged when in the "spare" position.
    PhotoNerd likes this.
  5. Jun 27, 2022 at 12:07 PM
    Taco-Spike
    Two Trucks
    I check it at least twice a year
    BravoDeltaRomeo likes this.
  6. Jun 27, 2022 at 12:13 PM
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    My 07 had original spare, the original owner tried bragging to me like that was a selling point! I put 2018 TRD wheels on it and then scored a set of FREE crappy older factory alloys so that I could steal one for a spare and part out the rest. Now I have 5 aluminum wheels that all use same lug nuts and a much fresher spare tire. If anyone wants another spare that looks like photonerds I'll give it up for free. 100% tread but I wouldn't drive on it.
  7. Jun 27, 2022 at 12:27 PM
    Wahayes
    Will
    2017 tundra limited *sold*
  8. Dec 31, 2022 at 6:39 AM
    HTXtundra4x4
    HTXtundra4x4 Texas
    Katy, TX
    2018 SR5 CM MGM
    I just dropped my spare and noticed the damage as well. Not good to be driving on. Luckily I didn’t need it and will be replacing soon. Also going to look into the thick gasket material idea.
  9. Dec 31, 2022 at 12:07 PM
    Bammer
    Monroe, CT
    I just dropped mine for the first time since purchasing the truck new. In ok shape, cleaned it all up,gave the rim a good cleaning and coating. Tire is still good, aired up to 35 from 10 !
  10. Dec 31, 2022 at 1:01 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Just dropped mine after seeing this thread. We put a matching wheel/tire up there in the summer, so it wasn't bad but did have a some minor rubbing.
    I cut up all old MTB tire and placed it in all for spots, friction fit for now. I'll secure the makeshift rubber gasket with some zip ties when it warms up.
  11. Dec 31, 2022 at 2:34 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    You can also split some rubber hose and zip tie to the contact points for the spare.
  12. Dec 31, 2022 at 3:26 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Good idea too.
    I think I'll try hitting up our Canadian version of Harbour Freight (Princess Auto) and buying a couple feet of this. Making some cuts, gorilla double sided tape (trial before permanent) and slap it up on a few places.
    With the size, I should only need a foot or two. Bad reviews are because of "rubber smell", which I won't care about.
    https://www.princessauto.com/39-in-...ber-mat-sold-by-the-foot/product/PA0008681645
  13. Jan 1, 2023 at 9:29 AM
    NewImprovedRon
    Ron
    NW Arkansas
    I bought rubber heater hose from AutoZone when I did mine. Split it down the middle with a box cutter, slip it onto the contact areas and zip tie. Goes pretty fast.
  14. Jan 1, 2023 at 9:40 AM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    Thank you for mentioning lug nuts!!
    Not 48 hours ago, I mentioned to the wife that I had not checked the spare pressure in a LOT of years, and needed to do it ASAP. What I hadn't thought of was, I upgraded from SR5 to TRD rims last year, which meant new lug nuts, and naturally I THREW AWAY the old nuts. :frusty:
    Oh well. Better to get reminded this way than at 2AM on a rainy night, 1000 miles from home.
    blackoutt[QUOTED] and GG.Offroad like this.
