Leveling 22 Platinum with AVS/Air
Discussion in '3rd Gen Tundras (2022+)' started by 2bak, Dec 22, 2021.
  1. May 21, 2022 at 8:34 AM
    #91
    matthinkle
    matthinkle New Member
    Lighthouse Point, FL
    2022 1794 Hybrid
    I’m curious to see how it’s different on the hybrid. I heard in one of the reviews that the hybrid rides lower. It’s part of the reason I’m asking. Then again will the weight of the batteries help at all? Or are they too far forward?
  2. May 21, 2022 at 11:28 AM
    #92
    22PlatWCP
    22PlatWCP New Member
    Mississippi
    2022 WCP Platinum 4x4
    Made the adjustment on mine today…took about 15 minutes total. I took it up the entire available adjustment…in the “High” position my wheel openings are 40” from the ground and 39” in the “Neutral” position. The ride felt a lot smoother, without the sudden bump stops I’ve feeling. That, however, is purely subjective since I “wanted” it to feel smoother.
    andrewmcc32 and Jr3volution like this.
  3. May 23, 2022 at 12:02 PM
    #93
    andrewmcc32
    andrewmcc32 New Member
    22 Platinum Pearl 4x4
    Just did this to my truck!! Super easy and gave me 2”. Thanks for the thread… awesome info!!!
  4. May 23, 2022 at 3:02 PM
    #94
    22PlatWCP
    Mississippi
    Drove my truck around quite a bit today and that adjustment definitely made the ride smoother…didn’t hit the bump stops at all. I might try adjusting it back down a little since it does feel a little bit floaty.
  5. May 23, 2022 at 3:19 PM
    #95
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    leave about 1/16" of exposed adjustment slot next to the bolt head...that seems to be a good spot
    prosledder, vzmotion and 22PlatWCP like this.
  6. May 23, 2022 at 9:24 PM
    #96
    Boon22
    Boon22 New Member
    2022 Tundra Platinum Crewmax 4x4
    This is about where I adjusted mine to and it rides great!
  7. Jun 2, 2022 at 5:15 PM
    #97
    prosledder
    prosledder New Member
    After the adjustment to raise the rear does it still self level to some degree when towing a small trailer or have a load in the bed? I would think it would add air up to whatever the max psi is.
    Abraham5G likes this.
  8. Jun 2, 2022 at 5:25 PM
    #98
    eddiefromcali
    Eddie
    100% Stock
    Yes
    prosledder[QUOTED] likes this.
  9. Jun 2, 2022 at 5:29 PM
    #99
    prosledder
    Thanks! I mean all we're doing is faking out the sensor so in theory if if senses a lower ride height it should add air to "level" back out to where it thinks it's level.
  10. Jun 2, 2022 at 5:33 PM
    #100
    eddiefromcali
    Eddie
    100% Stock
    Correct. Were only adjusting the neutral position. Once it senses some sag, it'll lift to the new neutral. We're not going over oem parameters since it's all oem adjustment range
    prosledder likes this.
  11. Jun 2, 2022 at 5:39 PM
    #101
    prosledder
    Right! thanks again! pretty slick actually to have that little bit of adjustment.
  12. Jun 15, 2022 at 2:08 AM
    #102
    Ride123ca
    Ride123ca New Member
    I Adjusted mine till I had 1/16th of an inch showing left on the open part and no longer bottom out but ride is a little stiffer
    eddiefromcali and prosledder like this.
  13. Jun 15, 2022 at 8:57 AM
    #103
    eddiefromcali
    Eddie
    100% Stock
    You can definitely adjust it down a bit from there and you won't bottom out but you obviously lose height.
  14. Jun 16, 2022 at 9:18 PM
    #104
    John Reed
    John Reed New Member
    Oregon
    Do you have AVS or just the rear air suspension?
  15. Jun 18, 2022 at 2:27 PM
    #105
    Seawolf
    Seawolf New Member
    2022 Toyota Tundra Platinum 4x4 Blueprint
    I wanted to see what's actually happening underneath the truck; so today I stuck a GoPro underneath the rear of my truck and took off down a local road. This road is not a bad road. It's well maintained with no breaks in the pavement. It just has some relatively minor dips here and there that, as many of you are aware, really upsets these trucks equipped with the air suspension. My truck, on a flat surface, has only about 1/2 an inch of space between the bump stop and the rear axel. I'll be taking care of this little matter soon, but figured I'd share the footage incase anyone is curious what it actually looks like in action.
  16. Jun 18, 2022 at 2:34 PM
    #106
    eddiefromcali
    Eddie
    100% Stock
    You've now spent more time complaining about it than what it would have taken you to adjust the levers, congratulations
    ziznack and prosledder like this.
  17. Jun 18, 2022 at 3:53 PM
    #107
    Seawolf
    Seawolf New Member
    You are absolutely correct. I’ve edited my previous post to remove the complaining. It’s not my intent to add drama for drama’s sake.
    The primary purpose of my previous post wasn’t to complain; so my apologies if it came across that way. I just wanted to provide visual proof of what’s happening so that those with less than impressive dealers can be shown what’s happening instead of them having to take someone’s word for it. I understand that some folks, no matter how simple the perceived fix is, don’t want to tackle it themselves.
    bigblue14 and gnc1017 like this.
  18. Jun 28, 2022 at 6:36 AM
    #108
    gowithit13
    gowithit13 New Member
    Ray
    2023 Platinum
    Seawolf,
    thx for the video.
    I have been dealing with my dealer and toyota corporate since day 1, Feb 8th.
    They have determined that the vehicle it set up to factory specs. I have driven three other Tundras with the AVS Air Suspension and they all perform the same.
    My hopes are that with enough complaints Toyota will perform a recall to make the proper adjustments.
    I have not wanted to make the adjustment myself but I have had enough and will finally do it this weekend.
  19. Jun 28, 2022 at 7:01 AM
    #109
    Seawolf
    Seawolf New Member
    You're welcome, gowithit13.
    I was in the manual over the weekend (for an unrelated reason) and ran across page 366-367 where it talks about the air suspension settings. In the manual, it states that the "HI" mode is supposed to be 1.6" higher than "N" mode. Interestingly, it also states that "LO" mode is supposed to be 1.2" lower than "N" mode. In the case of my truck that only sits 1/2" from the bump stop, it can't possibly be sitting at factory specs. Either that, or the manual is incorrect because for "LO" mode to be 1.2" lower than "N" mode then the distance between the bump stop and the axle would have to be at least 1.2" in "N" mode.
    It stinks that you can't get a favorable response from your dealer or Toyota, but fortunately from what others have said it should be a relatively easy adjustment. Just make sure you're on a flat, level surface when you do it and take measurements before and after. I finally got the recall notice on mine for the bolts. I plan on asking them to take a look at it when I take it in for that. If they don't want to do anything about the ride height then I'll just do it myself as well.
  20. Jun 28, 2022 at 7:53 PM
    #110
    Jkwolfe09
    Jkwolfe09 New Member
    Jerren
    Has anyone seen afe rear air ride arms? Looks like you can adjust it even further the the oem ones.
    autcash and matthinkle like this.
  21. Jun 28, 2022 at 8:08 PM
    #111
    AviatIT
    AviatIT New Member
    Western Colorado
    2022 1794 MGM CM Tundra
    Tinted Windows, Ceramic Coating
    I sent a couple posts with pictures from this forum to my dealer before picking up my new truck. They made the adjustments for me ahead of time and charged me an hour which also included installing the TRD skid plate. They were unfamiliar with the lever adjustments as mine was the first through their dealership with air suspension. As a side note the two levers were set completely different from each other straight from the factory. I have had zero issues hitting the bump stops and the ride is excellent especially in sport + mode.
    RookieEP and prosledder like this.
  22. Jun 29, 2022 at 7:49 AM
    #112
    TWade
    TWade New Member
    Tanner
    2023 Tundra TRD Pro Black on Black
    This is the first leveling arm I have seen outside of Westcott. The webpage references a front leveling kit that doesn't seem to be available yet. Maybe once available, it will be easier to get your hands on.
  23. Jun 29, 2022 at 8:19 AM
    #113
    Jkwolfe09
    Jerren
    I’m not sure you’ll need afe level to use these.
  24. Jun 30, 2022 at 2:27 AM
    #114
    Nitricacid
    Nitricacid New Member
    Jerzey
    22 Tundra Platinum 4x4 Midnight Black
    If the arm is adjusted all the way up is there still more travel left when hitting the high setting? Or will it do nothing cause its maxed out?
  25. Jun 30, 2022 at 5:31 PM
    #115
    JRD
    JRD New Member
    2022 Tundra 1794 Blueprint
    So, I certainly don’t want to sound stupid but, when you adjust the levers to raise height, should the slot be below or above the locknut??
  26. Jun 30, 2022 at 5:52 PM
    #116
    prosledder
    The nut should be towards the bottom, with the space of the slot above the nut. Someone correct me if I'm wrong...BTW I read after making the adjustment it's good to manually raise the truck up and then lower back to N so it resets / recognizes the new position.
  27. Jul 1, 2022 at 8:20 PM
    #117
    CamsRetriever
    CamsRetriever New Member
    Roseville, CA
    2022 Platinum CM MGM
    Here is before (2”level only) and after (2” level and adjustment of rear nut). Took 30 seconds to adjust rear.
    Scooter73, Jagator and eddiefromcali like this.
  28. Jul 1, 2022 at 8:44 PM
    #118
    eddiefromcali
    Eddie
    100% Stock
    What front kit was that?
  29. Jul 1, 2022 at 8:47 PM
    #119
    CamsRetriever
    Roseville, CA
    just the cheap $45 2” spacer that driven companion has the Amazon link to.
    eddiefromcali[QUOTED] likes this.
  30. Jul 2, 2022 at 8:31 AM
    #120
    prosledder
    Looks sharp! factory wheels look pretty good
    CamsRetriever[QUOTED] likes this.
