Anyone have a Diehard 27F battery?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra234, Jun 9, 2022.
  1. Jun 14, 2022 at 8:17 AM
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    I know this is a super stupid question, but what battery tray does the Tundra factory come with? I know I will need a new seat if I go 31, but will 27 fit without a new seat?
  2. Jun 14, 2022 at 8:58 AM
    BayRunner
    BayRunner I’m here, except when I’m not
    2017 Tundra Platinum
    The tray fits a 27 perfectly.
  3. Jun 14, 2022 at 9:07 AM
    Tundra234 [OP] New Member
    They have come with both options. Some came with the 24F and shorter tray and some came with the 27F and longer tray.
  4. Jun 14, 2022 at 9:15 AM
    BayRunner
    Ah, I was not aware that they actually had 2 separate trays. Seems in inefficient to me.
  5. Jun 14, 2022 at 9:25 AM
    Yeah i found that out the other day.
  6. Jun 14, 2022 at 9:46 AM
    Ghost Rider
    Ian
    Cypress, Texas
    Guess the next quest is to find out what try I have then.....lol
  7. Jun 14, 2022 at 9:55 AM
    BayRunner
    Do you know what size battery your truck came with? Also could be a difference of having the towing package or not.
  8. Jun 14, 2022 at 9:59 AM
    I can measure mine....the 27F tray is about and inch and a half longer than the 24F.
  9. Jun 14, 2022 at 10:04 AM
    Ghost Rider
    Ian
    Cypress, Texas
    Mine is a 27F.
    Truck is '21 CM TSS package. At least don't have worry about the tray now, not going for 31F at this point.
  10. Jun 14, 2022 at 10:12 AM
    BayRunner
    So did you end up having to get the 24f Diehard?
  11. Jun 14, 2022 at 10:51 AM
    27F flooded
  12. Jun 17, 2022 at 7:50 AM
    Ghost Rider
    Ian
    Cypress, Texas
    Sorry @Tundra234 , do you or anyone know where to get a 31F battery tray?
    Am thinking to go all-in and just get it done while I am waiting on the SDHQ battery terminal billet....
  13. Jun 17, 2022 at 8:01 AM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    Rago fabrication makes a real nice one for the 31F...
  14. Jun 17, 2022 at 8:11 AM
    Ghost Rider
    Ian
    Cypress, Texas
    But the page says it fits the 2nd gen from 07-13, do you know if it fit the 2021?
  15. Jun 17, 2022 at 8:40 AM
    I need to order the SDHQ terminals as well since I have to replace the positive terminal anyway. They are only recommended for sealed batteries, but I think it will be fine as long as the battery doesn't leak.
  16. Jun 17, 2022 at 8:42 AM
    Ghost Rider
    Ian
    Cypress, Texas
    Me and my co-worker (Taco) are both eyeing that X2 31M from Batteries Plus, he's got his tray for 31 already whereas mine is a 27F tray, not sure if it will make that much of a difference tray size-wise.
  17. Jun 17, 2022 at 8:46 AM
    Doing the diode mod for charging?
  18. Jun 17, 2022 at 8:47 AM
    Ghost Rider
    Ian
    Cypress, Texas
    Maybe, or just slap the trickle charger on it when not driving.
    I might be getting a beater for daily driving to work, and push the beast on weekends and long trips.
    hagrid likes this.
  19. Jun 17, 2022 at 8:55 AM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I have been very pleased with my terminals....
  20. Jun 17, 2022 at 9:01 AM
    #50
    I was looking at the AGM batteries until the dealer told me if would void the warranty. I don't know if he said that because it is a deep cycle? :notsure:
  21. Jun 17, 2022 at 9:02 AM
    #51
    I was looking at those too.....half the cost of the SDHQ terminals.
  22. Jun 17, 2022 at 9:03 AM
    #52
    Ghost Rider
    Ian
    Cypress, Texas
    Which one is this? Do you have a link?
  23. Jun 17, 2022 at 9:05 AM
    #53
    Ghost Rider
    Ian
    Cypress, Texas
    I am seriously doubting the "void warranty" part unless they are referring to the mod that must be done to get the voltage up to par for AGM, which then I guess would void it.
    But to hell with it, I got SP9100 and voiding possibly any and all warranty, not gonna be very concerned as far as that part.....
    But if I do get it all lined up (tray, battery, terminal), I might just use trickle charge until I can figure out a sure-fire safe way to get the voltage mod going.
  24. Jun 17, 2022 at 9:06 AM
    #54
    Those are the GPAudio. They are around $60 and Amazon carries them.
  25. Jun 17, 2022 at 9:10 AM
    #55
    Someone on here had a very nice distribution block setup. I don't remember who it was.
  26. Jun 17, 2022 at 9:45 AM
    #56
    BayRunner
  27. Jun 17, 2022 at 9:57 AM
    #57
    Not bad. I just think 2 leads and a distribution block would clean up nicer than several leads coming from the battery.
  28. Jun 17, 2022 at 10:07 AM
    #58
    Ghost Rider
    Ian
    Cypress, Texas
    I am just more concerned about the material and the connectivity....AGM should not worry about leak or spill, but regular batteries are prone to leak, no matter what.
  29. Jun 17, 2022 at 10:08 AM
    #59
    BayRunner
    I thought the same. I worked these in when I installed the ARB compressor. Tucked the positive block under the tank and the negative on the ground screw.
    Tundra234[QUOTED][OP] likes this.
  30. Jun 17, 2022 at 10:23 AM
    #60
    I'm wondering if this is what I need. I'm running power leads for 2 light bars (the BDS8 in the bulge, the 20 inch in the bumper), 3W liners window module, train horn compressor, and 4 guage for stereo. I dont know if the 4 guage will connect to this fuse block though.
    Amazon.com : Blue Sea Systems Fuse Block ST Blade 12 Circuit with Ground and Cover, 5026 : Fuse Block With Relay : Sports & Outdoors
