Anyone know what this is?
Discussion in '1st Gen Tundras (2000-2006)' started by TundraMath, Jun 12, 2022.
  1. Jun 12, 2022 at 2:49 PM
    TundraMath
    TundraMath [OP] New Member
    Scott
    2006 Tundra SR5
    I found this under my truck. 2006. Obviously rusted off.
    It had a bar code sticker on it that had 4R 049 on it.
    any ideas???Thanks!
    I love my 06 tundra. Only 106K
  2. Jun 12, 2022 at 2:55 PM
    Casper421
    In the woods
    06 DC
    Looks like part of the dust shield for the front brakes.
  3. Jun 12, 2022 at 3:02 PM
    Aerindel
    Aerindel New Member
    Montana
    Brake backing plate for sure.
  4. Jun 12, 2022 at 3:24 PM
    X2
    Tundra2 likes this.
  5. Jun 12, 2022 at 3:24 PM
    Welcome from NY.
  6. Jun 12, 2022 at 4:53 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Agree with guesses above.
    Welcome.
  7. Jun 12, 2022 at 5:16 PM
    Looks like the rear backing plate and it’s super oily, take a look before you drive it more
  8. Jun 13, 2022 at 2:05 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    You need a shiny new one, like this
    Aerindel and FrenchToasty like this.
  9. Jun 13, 2022 at 3:52 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Do the '06s have drum brakes on the rear axle? Even so, isnt the parking brake mounted to the backup on rear discs?
    Methinks this truck is not roadworthy.
  10. Jun 13, 2022 at 4:07 AM
    TundraMath
    Scott
    2006 Tundra SR5
    Thanks everyone for the quick replies! I love this truck…but it sure is rusted underneath!
  11. Jun 13, 2022 at 1:52 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    If the rust is bad enough that entire components are falling off you may want to get it up on a lift and check out the frame. Is the truck sitting in the grass/dirt?
  12. Jun 13, 2022 at 1:53 PM
    Those look like slugs to me. If this fell off on the ground, that would totally make sense.
  13. Jun 13, 2022 at 4:24 PM
    TundraMath
    Scott
    2006 Tundra SR5
    Oh wow. I didn’t see those! It was sitting in my driveway after a rainstorm.
    I have had the frame looked at. A lot of surface rust, but nothing major. Toyota actually inspected it like 9 or 10 years ago and sprayed something on it ( wasn’t bad enough to replace)…but that coating lasted like a year or two.
  14. Jun 13, 2022 at 5:00 PM
    Aerindel
    Aerindel New Member
    Montana
    Brake backing plates rusting off is of itself, not a big deal. I've seen that happen a lot on subarus for instance with no other rust. They are a lot like exhaust parts, thin metal exposed to high heat and which are always pelted with whatever water and rocks you're driving through. If something is going to rust off your vehicle, they are among the first to go.
  15. Jun 13, 2022 at 5:47 PM
    A lot of people who got the coating later found their frame rusted from the inside out. But not until something snapped in half. It was a topical solution to conceal the underlying rot.
  16. Jun 17, 2022 at 1:28 AM
    tunyota
    tunyota Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
  17. Jun 17, 2022 at 1:37 AM
    Aerindel
    Aerindel New Member
    Montana
    Negative. Its the front. The rear plate is thick steel, and holds the brakes together, if that rusted out, he would know it. Its the front, its much lighter, and is just a dust cover/debris shield.
    tunyota likes this.
  18. Jun 17, 2022 at 1:50 AM
    tunyota
    I would agree now that I have watched several videos on replacing the front rotors. :thumbsup:
    Aerindel[QUOTED] likes this.
