Desperate for airbags or something to eliminate rear sag
Discussion in '3rd Gen Tundras (2022+)' started by ToyotaTundraguy, Jun 15, 2022.
  1. Jun 15, 2022 at 12:34 PM
    ToyotaTundraguy
    ToyotaTundraguy [OP] New Member
    2022 tundra trd sport
    Truck is terrible sag with trailers or a little weight
  2. Jun 15, 2022 at 12:36 PM
    Pics? What’s Considered terrible?
    Taco-Spike likes this.
  3. Jun 15, 2022 at 12:39 PM
    Taco-Spike
    Two Trucks
    I've heard a few people say this about rear coil springs versus leaf springs. Most all I've heard from in person were not Toyotas though
  4. Jun 15, 2022 at 12:44 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Airbags or stiffer coils are your best options.
  5. Jun 15, 2022 at 12:47 PM
    ToyotaTundraguy
  6. Jun 15, 2022 at 12:50 PM
    HaveFun
    HaveFun Happy to be here
    Fair Oaks Ranch, Texas
    2019 Black Tundra CM SR5
    :eek2: That is extreme. I have not tried air bags but really enjoy my black sumo springs.
    ATV25 and Acedude like this.
  7. Jun 15, 2022 at 12:54 PM
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    '22 Lunar Rock LTD DC TRD-OR
    Think there are a few on this forum who have replaced their rear springs with heavier rated ones intended for the 80 Series Land Cruiser... YMMV
    CaptRussia253 likes this.
  8. Jun 15, 2022 at 12:55 PM
    ToyotaTundraguy
    That’s the help I’m looking for but cannot seem to find . I’m open for mods just need info
  9. Jun 15, 2022 at 12:58 PM
    ToyotaTundraguy
    Truck can sure pull but suspension designed for groceries
    woods, LEM, MaxPower and 1 other person like this.
  10. Jun 15, 2022 at 12:59 PM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    I don’t see a weight distribution hitch. You NEED one of those first!
    Then get your truck weighed. Knowing your axle weights help point you in the right direction.
  11. Jun 15, 2022 at 1:01 PM
    ToyotaTundraguy
    I got one for 8000 pounds that very same day .. helps for sway but want worth its money for sag
  12. Jun 15, 2022 at 1:02 PM
    ToyotaTundraguy
    My 2018 tundra did not sag like that by the way
  13. Jun 15, 2022 at 1:03 PM
    Terndrerrr
    Music City
    6UR-FE
    With the same camper?
  14. Jun 15, 2022 at 1:04 PM
    ToyotaTundraguy
    Yes sir
    woods and Terndrerrr like this.
  15. Jun 15, 2022 at 1:06 PM
    ToyotaTundraguy
    This truck is twice the towing machine don’t get me wrong but is saging too much . The 10 speed loves towing at hwy speeds
    j-utah and FrozenFella like this.
  16. Jun 15, 2022 at 1:13 PM
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    reach out to @evergreenoffroad I'm pretty sure they've done this swap, or something similar.
  17. Jun 15, 2022 at 1:15 PM
    ToyotaTundraguy
    Thanks fella .
    One last thing … these truck rip like you wouldn’t believe I blew aways an f350 ford Tremor
    Rykr and j-utah like this.
  18. Jun 15, 2022 at 2:10 PM
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    2023 Tundra Hybrid Limited L TRD OR 4X4
    What's the tongue weight of your trailer? Are you carrying any cargo in the box? Are you sure you have your weight distribution hitch dialed in right?
    GODZILLA, Dfrink, gnc1017 and 2 others like this.
  19. Jun 15, 2022 at 2:15 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Roadmaster Active Suspension system.
    Florida AF, bgdv1 and OHwendTrd like this.
  20. Jun 15, 2022 at 2:15 PM
    ToyotaTundraguy
    7000 pound trailer . So 700 maybe . 100-150 pounds of gear at best in truck
  21. Jun 15, 2022 at 2:16 PM
    ToyotaTundraguy
    Hitch place installed . And let me know if I try to go to tight there could be damage
  22. Jun 15, 2022 at 2:17 PM
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    With a couple of adults in the cab you'd still be within payload limits. I'm thinking tweaking of your weight distribution hitch set up may help you out.
    Soupbean77 likes this.
  23. Jun 15, 2022 at 2:19 PM
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    That sounds reasonable. Can you post a photo of your rig with the weight distribution hitch in use?
    Cpl_Punishment and 22PlatWCP like this.
  24. Jun 15, 2022 at 2:19 PM
    Which weight distribution hitch do you have? If you can, install it, hook up the trailer, and then post pics. Your bars should be parallel to the ground. If not set up properly, you will sag still.
    https://www.etrailer.com/faq-how-to-install-weight-distribution.aspx
  25. Jun 15, 2022 at 2:21 PM
    ToyotaTundraguy
    that suspension does not work with coils
  26. Jun 15, 2022 at 2:23 PM
    ToyotaTundraguy
    I hook up to trailer and Jack that thing right up and install bars then let Jack back off
  27. Jun 15, 2022 at 2:25 PM
    ToyotaTundraguy
    I usually with two people hooking up I can manage to get 4 links on chain .
    It helps but still sagging as is why I want air bags or lifts etc .
    So tight when I turn or get on uneven ground it sounds like piano wire like it’s sick
  28. Jun 15, 2022 at 2:30 PM
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    Land cruiser springs or Firestone coil-rite 4164 kit. I'd make sure your weight distribution hitch is properly setup first. My experience with a dealer install was garbage. I had to fix it myself.
  29. Jun 15, 2022 at 2:38 PM
    Those style LDH are not my favorite and not a fan. Personally I would go with a trunnion style LDH.
    https://www.etrailer.com/Weight-Distribution-Hitch/Fastway/FA92-00-1200.html
  30. Jun 15, 2022 at 3:11 PM
    Wahayes
    Will
    2017 tundra limited *sold*
    Damn. To be fair my 2.5 gen squatted something fierce with trailer too
    MEGA VOL, Markus, Tundyfundy and 6 others like this.
