2021 TRD Pro Westcott torque specs
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jr3volution, Sep 7, 2021.
  1. Sep 7, 2021 at 4:21 PM
    Jr3volution
    Jr3volution [OP] New Member
    Johnnie
    DFW TX
    2022 Tundra Platinum
    Hello all.
    does anyone happen to know the torque specs for the reinstallation of the bolts that have to be taken off?
    Thanks I’m advance
  2. Jun 14, 2022 at 2:29 PM
    DadduMan
    DadduMan New Member
    2021 Black Tundra TRD Pro
    Found myself asking the same question today. Called Westcott and they told 90,92,94 ft/lbs all should be good. So I’m going with 92 ftlbs.
  3. Jun 14, 2022 at 4:46 PM
    Jr3volution
    Johnnie
    DFW TX
    I used the specs that rough country has for their level
  4. Jun 14, 2022 at 5:30 PM
    DadduMan
    DadduMan New Member
    What did the Rough country specs say? I actually just torqued them to 90. They were pretty loss on their and I assume the shop guy did 74 ft lbs!
  5. Jun 14, 2022 at 6:23 PM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Here ya go…
  6. Jun 14, 2022 at 6:26 PM
    FISHN43
    FISHN43 New Member
    Ohio
    Your asking about a 2021 TRD Pro….but your profile says you have a 2022 Platinum??? Just wanna make sure its the correct specs you need.
  7. Jun 14, 2022 at 10:00 PM
    DadduMan
    DadduMan New Member
    If these are factory specs I believe they don’t apply to aftermarket ubolts, which most are thicker than stock ubolts.
  8. Jun 15, 2022 at 4:34 AM
    FISHN43
    FISHN43 New Member
    Ohio
    If you didn’t get new torque specs with the new bolt I would probably torque it the same even if its a beefier bolt. Mark it to make sure it doesn’t loosen.
