  1. Jun 14, 2022 at 6:20 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Micro tactically placed. But, please don't grab my bar on the whoops. You will ride in back after that.
  2. Jun 14, 2022 at 6:24 PM
    So when I had a gas powered trike……. Instead of using pvc sleeves, which where thin and wore out fast, Hdpe was the kittens mittens! You could find it in 3/4 wall I think and it would drift for days and not take much off the overall diameter of the sleeve.
    alb1k[QUOTED] likes this.
  3. Jun 14, 2022 at 7:48 PM
    daveeasa
  4. Jun 14, 2022 at 7:54 PM
    alb1k
    Left Coast
    It's good
    :yes:
  5. Jun 14, 2022 at 7:57 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    I'll see your Dual Cab, and raise you an Access Cab...
    MS22, NUDRAT, Voss and 1 other person like this.
  6. Jun 14, 2022 at 8:20 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    So I didn't do a build thread of my rig but I definitely should have. All I can say is so far I love the stance and ride quality with m setup. Also I have airbags so when I tow I bearly have any squat. I'll try and get a picture tomorrow without my trailer.
    NomadicFrog, ktundra, NUDRAT and 9 others like this.
  7. Jun 14, 2022 at 9:08 PM
    Sooooo….. DC>single cab> AC?
    CodyP likes this.
  8. Jun 14, 2022 at 9:14 PM
    KK6PD
    ROAD
    With the TEQ grille?
    Tundra2 likes this.
  9. Jun 14, 2022 at 9:17 PM
    daveeasa
    Would you guys do front camera on top of the YO or below it?
  10. Jun 14, 2022 at 9:18 PM
    Poppycock
  11. Jun 14, 2022 at 9:19 PM
    KK6PD
    ROAD
    On top. The higher you mount a camera, the better the perspective, unless you are looking for something on the ground!
  12. Jun 14, 2022 at 9:21 PM
    daveeasa
    Kk, my thoughts too but my Taco has it below. We will see how it mounts if I ever get to it. A little annoying to run the camera cable through the hood.
    also today I learned that when adding a MH tailgate panel you should leave the stock access panel intact.
  13. Jun 14, 2022 at 9:23 PM
    Wait till you knock up slippery sally, then DC are perfect for kids! Minus this back door that takes out ankles on flat ground!
    oscardog86 and 5N0W808[QUOTED] like this.
  14. Jun 14, 2022 at 9:27 PM
    daveeasa
    My stock panel smashes the rods for the handle. I really don’t want that again. Spacers? I will try and see I guess.
  15. Jun 14, 2022 at 9:28 PM
    daveeasa
    It’s an idea, but easy to swap if the bracket I have will work on this grille. Looks like it should. Bought it for the taco but after I drilled and too lazy to swap because what works isn’t worth messing with.
    I heart front cameras for parking.
    CodyP likes this.
  16. Jun 14, 2022 at 9:28 PM
    Miracles are real!! Hahaha
    5N0W808[QUOTED] likes this.
  17. Jun 14, 2022 at 9:29 PM
    daveeasa
    Good plan for the gap. I’ll try out the stock panel sandwich, maybe it behaves better that way.
    PO didn’t baby it. It’s a truck after all.
    5N0W808 likes this.
  18. Jun 14, 2022 at 9:32 PM
    alb1k
    Left Coast
    It's good
    You might be in repeat or have a frequency offset. I only know how to program these on a computer, even that is voodoo.
    Simplex (direct) sends and receives on same freq. Repeat or other shit uses 2 frequencies. 1 send, 1 receive. You are transmitting on a different frequency than receiving, or there is some mode that scrambles your send.
    5N0W808[QUOTED] and FrenchToasty like this.
  19. Jun 14, 2022 at 9:32 PM
    Party hardy!
    alb1k likes this.
  20. Jun 14, 2022 at 9:38 PM
    KK6PD
    ROAD
    Radios are easy, as alb1k said, simplex, duplex , offsets + or -
    You need some help, PM me. What rig are you using?
    I've been a Radiohead for 5 decades.....
    Be glad to help out!!
  21. Jun 14, 2022 at 9:42 PM
    Good to know!!!
    Pure sign language to me!
    alb1k and KK6PD[QUOTED] like this.
  22. Jun 14, 2022 at 10:22 PM
    alb1k
    Left Coast
    It's good
    Big resource here. Just sayin.
    FrenchToasty and KK6PD[QUOTED] like this.
  23. Jun 15, 2022 at 1:37 AM
    KK6PD
    ROAD
    Thanks, Ill look this up, and let you know what's up!
    Edit 1, by chance is it this one?? BTECH GMRS-V1
    Edit 2, I now have the operation manual, 88 pages, this is actually a versatile radio. Pretty standard stuff, I need to next check out the Programming Software, that's usually the painless way to set this thing up. Once you figure out how easy it is to program, not a problem. Hardest part is figuring out what the column headers mean.
    I think you think you hate it because it looks complicated, That happens to a lot of folks. One of the aspects of the old job was instructing folks how to use a radio!
    If you can drive, build/rebuild Tundras, do mods, then drive on/off road, then party & camp, and your still alive.. you can figure out radio!
    I can help!
    NUDRAT, tokolosh, w666 and 1 other person like this.
  24. Jun 15, 2022 at 5:09 AM
    Holy hell, thank you for this! I think this is exactly what I needed to see. Are you running 265/70/17 or 275/70/17?
    @daveeasa I agree with Erik on this one, and I gotta say, I think this insert looks (1) way better than the other you had, (2) far better on the earlier years with the oval opening like yours versus the upside-down horseshoe shaped insert like mine, and (3) I lefitimately don't even think you need to paint the damn thing, but I'd love to see someone vinyl-wrap the outer ring, and maybe the inner stripe, just for a reversible 10ft "what it'd look like" for others to see.
    daveeasa likes this.
  25. Jun 15, 2022 at 5:09 AM
    Link, if helpful: https://baofengtech.com/product/gmrs-v1/
  26. Jun 15, 2022 at 5:12 AM
    PS - @daveeasa you need to take some of this stuff to your trim. It works better than any of the other products I've tried.
  27. Jun 15, 2022 at 5:59 AM
    daveeasa
    The plastic grille is also much lighter than the IS one. It’s a keeper for sure. Trying to decide if I want to put some anti-seize on the threads or not. I could see doing the letters a different color, black on black perhaps.
    Which trim specifically?
    Front bumper is going to get tossed as soon as I can get an order in. I’ll try to call again today.
    Side moulding I may remove, not sure. Looks good with no moulding on others.
    I have bushwacker fender flares and new heated mirrors which are color matched rather than chrome, just need to install.
    Also new mud guards and inner splash liners, in the bed, waiting patiently.
    I don’t think there is much black trim to rehab? The rubber bed mat I suppose but I plan to use it as a template if I can get a single piece of mat at a trailer supply store.
  28. Jun 15, 2022 at 6:00 AM
    Casper421
    In the woods
    06 DC
    I rub on the firewall, need more co adjustment. TC uca’s.
  29. Jun 15, 2022 at 9:55 AM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    Ehh not really. Ill try a 91 tune if I get the time and see if that makes any difference. I would hope that Unichip would throw a bit of timing at it with higher octane fuel but you never know.
  30. Jun 15, 2022 at 10:47 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    That looks great!
    Dave8699[QUOTED] and shifty` like this.
