Floor Shifter conversion? Is it possible?
Discussion in '2nd Gen Tundras (2007-2013)' started by Jammminjay, Jun 14, 2022.
  1. Jun 14, 2022 at 9:56 AM
    Jammminjay
    Jammminjay [OP] New Member
    2008 tundra sr
    35s icon kift
    I purchased a 2008 Tundra with a column shifter and I regret it. I wish I got the floor shifter... I am going to do the center console conversion soon but want to know if anyone has converted the column to a floor shifter? I know it is possible. I would assume the wiring might be tricky and you might need a new steering column.
    chugs, Jorgesworld86 and WVI like this.
  2. Jun 14, 2022 at 10:23 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Probably way more money and trouble than it's worth but I'm sure it's possible.
  3. Jun 14, 2022 at 10:24 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    Have not tried that but I really wish that they offered the column shifter in the higher trim levels. I would love a front "bench" seat. Sure I have less storage and it is not as sexy but what else do you loose? The others are doing it in their higher trim level trucks.
  4. Jun 14, 2022 at 11:07 AM
    MadMaxCanon
    I am curious why you regret it. If you really want, you can ditch your middle front seat and just install the center console and use the shifter spot as an extra cup holder or something.
    Hyperforming likes this.
  5. Jun 16, 2022 at 4:52 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    How good are you at automotive wiring?
    I am sure it is possible with enough time and work. I swapped a full 2014+ dash into my 2007. If that can be done I’m sure this can also.
    If this is somthing you really want to purse I will take a look at the wiring differences. I don’t think I have seen anyone actually do the entire thing yet.
  6. Jun 17, 2022 at 11:33 AM
    Jorgesworld86
    Jorgesworld86 New Member
    Orange County,CA
    2013 Tundra Limited Rock Warrior
    Very nice truck
  7. Jun 17, 2022 at 12:08 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    You should do a four on the floor.
    grave likes this.
  8. Jun 27, 2022 at 3:18 PM
    LillDragun
    LillDragun New Member
    Main reason why I'm not getting a 2022+. I LOVE my bench seat!! might only use that middle seat for a person sitting there a few times a year, but I'm enjoying it in other ways.
    Terndrerrr and MadMaxCanon like this.
  9. Aug 12, 2022 at 7:21 PM
    Chrslefty
    Chrslefty New Member
    08 dubble cab
    Op any luck with this??
    The reason I would like to get ride of the column shifter is to get the telescopic steering column.
  10. Aug 12, 2022 at 9:23 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    How's your girlfriend suppose to sit next to you with a center console in the way?
  11. Aug 12, 2022 at 10:19 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I wish my truck had the column shifter. I’d much rather have the extra seat. There is a thread here where someone went pretty far down the rabbit hole, but as far as I know, there have been no completed conversions one way or another.
    Rincon805, DKray_SX and Chrslefty like this.
  12. Aug 13, 2022 at 6:08 AM
    Retroboy1989
    Northern Utah
    I've scoured this site for successful conversions going the other way (floor shift to column shift). It's an unbelievable amount of parts swapping and wiring. I think it gets into the immobilizer system if I recall. The that is where I tap out.
    Your direction is the easy way if you can stand keeping the column shifter. There have been several guys on here that have swapped the middle seat for a console. They just use a blank plate or a 3d printed plug in the console shifter hole. One guy may it into a nice tray.
    Chrslefty likes this.
  13. Aug 13, 2022 at 6:19 AM
    Retroboy1989
    Northern Utah
  14. Aug 18, 2022 at 3:12 PM
    Trust86
    Trust86 New Member
    2007 DC
    I’ll take you up on this offer if you’re still up for it :D
    Jeff_5_7[QUOTED] likes this.
  15. Aug 19, 2022 at 7:29 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    I will spend sometime looking at it tomorrow. I really don’t think it is a big difference wiring wise but I guess we will find out.
    Trust86[QUOTED] and Leo's first like this.
  16. Apr 24, 2023 at 12:11 PM
    Trust86
    Trust86 New Member
    2007 DC
    Yearly bump LOL. Still trying to convert floor to column shifter. I have everything for the swap except for the column shifter itself and the shift cable. Would you be able to check the wiring for me?
  17. Apr 24, 2023 at 12:20 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    I took a look at the wiring diagrams and these are the major systems I see with denotions for column or floor shift. I didnt look specifically through each section but my assumtion is this will be a large undertaking wiring wise.
    Electronically Controlled Transmission and A/T Indicator <3UR-FE, 3UR-FBE>
    Shift Lock
    Cruise Control <3UR-FE, 3UR-FBE>
    Back-Up Light
    Parking Assist <Intuitive Parking Assist>
    Power Outlet <12V>
    Trailer Towing
    Trust86[QUOTED] likes this.
  18. Apr 24, 2023 at 12:36 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I've been through this topic with others on here, but I've lost track of where exactly it was discussed. Hell, it may have actually been some PM for all I can remember at this point. And I'm also pretty sure it was for the Gen 2.5 trucks. While there are a lot of similarities there are also a lot of differences between different "batches" of the Gen 2 and Gen 2.5 rigs, and I've seen the most differences in the early Gen 2's between the 2007 and the 2008 models.
    It's not terrible, but it's far from plug-and-play. Things like shift lock solenoid (prevents key from being removed when in gear) are different. There are likely wiring connectors that are not present in the needed locations and will require routing new wires and terminating new connectors.
    Trust86 likes this.
  19. May 29, 2023 at 9:08 PM
    Retroboy1989
    Northern Utah
    I would love to do this conversion, but it's more involved than I want get. I'd rather not mess with the immobilizer wiring and such.
  20. May 29, 2023 at 9:43 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I too would love to do this. I love the functionality of the 6th seat. The console wastes a lot of space as far as I’m concerned.
  21. Jun 2, 2023 at 3:49 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    sounds like a huge waste of time and money, but... do you
  22. Jun 2, 2023 at 7:36 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Well, that’s one way to get your post count up I guess.
    07 Tundie likes this.
  23. Jun 7, 2023 at 10:25 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    and you got one more i see, congrats
