Smoking when accelerating
Discussion in '2.5 Gen Tundras (2014-2021)' started by Js1732, Jun 13, 2022.
  1. Jun 13, 2022 at 10:49 PM
    Js1732
    Js1732 [OP] New Member
    Tried checking through previous posts, and couldn't find anything. 2015 Tundra, 60000ish miles, frequent oil changes, and without any leaks or mechanical failures. Driving at 50-60mph and then punching it to pass vehicles and/or accelerating up an incline without a load, a large cloud of smoke exits the tailpipe. At no other time does the truck smoke. I don't know if it's blue or gray, but it clears up pretty fast. Just a large plume of smoke like I rolling coal. Just started recently seeing it in the last couple of months. I know it could be a plethora of things, but after all these years, this forum has yet to steer me wrong. Thanks in advance!
  2. Jun 14, 2022 at 2:42 AM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    Could be an injector problem I'd take a hard look at the plugs and see if they all look the same. Bad fuel can cause some issues that are really hard to put your finger on
  3. Jun 14, 2022 at 3:44 AM
    Bammer
    Monroe, CT
    Blue smoke = oil
    White smoke = water
    Black smoke = fuel
    Is your oil level dropping between oil changes? If so how much, same for coolant level, any drop in level?
    mambo143 likes this.
