Gen 2.5 leak between bed rails and canopy - reliable fix ?
Discussion in 'Tonneau Covers, Caps and Shells' started by SSPey, Jun 6, 2022.
  1. Jun 6, 2022 at 9:21 AM
    SSPey
    SSPey [OP] .
    Oregon
    2021 DinoSR5
    I just had an ARE Z installed on my 2021 CrewCab, right before a weekend of solid Oregon rain. Water seems to be seeping between bed rail tops and the canopy (the install seam), making puddles in the bed, especially at the corners. This is much more leaking than I remember with my 2001 Tundra (ARE) or 1998 Tacoma (Century) canopies.
    Is this a known problem with a known solution on the Gen 2.5? I don’t want to make multiple return trips to the dealer who installed it. I am wondering if this is a late Gen 2.5 issue with the bed rail caps, which seem a bit flimsy?
    I’m looking for a reliable solution, even if it means shelling out a little more money for a better gasket. I want to nip this in the bud before we get to the real rainy season in the fall.
    I did a search on leak in this forum and mostly came up with leaking windows
  2. Jun 6, 2022 at 9:23 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    The corners in the front by the bulkhead are notorious for leaking since its an uneven plane to the center bulkhead. You could run some weatherstripping on the center bulkhead and use some silicone on the edges of the bed caps. I had to do this with my diamondback. Its pretty waterproof now with the hose test I did.
    SSPey[OP] likes this.
  3. Jun 6, 2022 at 9:45 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    The only leaking I have on my Leer is on one side of the rear door where a seal has come unglued and I'm waiting for a replacement. Do the sides of your ARE not overlap the bed sides somewhat?
  4. Jun 7, 2022 at 5:47 PM
    SSPey
    SSPey [OP] .
    Oregon
    2021 DinoSR5
    The sides do overlap, though not sure about the seam along the cab. Talked to a few buddies with different canopy brands on their Tundras and the same issue, especially at the corners near the cab.
  5. Jun 13, 2022 at 2:37 PM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    I have the ARE CX with windoors on my 21 CM and experience some leaking in the corners near the cab as well
    Not terrible but bothers me alittle
    Did some black urethane in between where the bed panels meet
    Figured where I can clearly see daylight was a place to start
    My ARE dealer (who I know very well) pre warned me about the tundra being tough to seal
    I opted for the bedmat instead of full bed rug bc of this known issue
