Nav System Sound
Discussion in '3rd Gen Tundras (2022+)' started by WasAChevy, Jun 11, 2022.
  1. Jun 11, 2022 at 9:56 AM
    WasAChevy
    WasAChevy [OP] New Member
    Sometimes she provides audible turn by turn info, sometimes not. Sound is not on mute.
    Anyone encounter this issue?
  2. Jun 11, 2022 at 12:53 PM
    MJPlat
    MJPlat New Member
    The next time you’re supposed to hear something from the nav turn the volume up quickly. The system allows you to tailor the volume separate from the radio or your phone and will jump between them quickly.
  3. Jun 13, 2022 at 6:50 AM
    WasAChevy
    Worked like a charm, thanks!
  4. Jun 13, 2022 at 10:08 AM
    Troa
    Troa I blue it again.......
    Nomad
    2022 Blueprint Limited
    You can also go into the nav and "test" the nav volume. This will trigger it to say something allowing you to adjust the volume while it's doing so.
    I found it incredibly difficult to try and anticipate when it would speak so I would be ready to adjust the volume while driving. I would try, miss it, and crank up the music instead.
    WasAChevy[OP] likes this.
