Saggy Rear, is this normal? Leaf pack vs AAL vs RAS?
Discussion in '2.5 Gen Tundras (2014-2021)' started by king.cong.1119, Jun 13, 2022.
  1. Jun 13, 2022 at 6:52 AM
    king.cong.1119
    king.cong.1119 [OP] New Member
    Hi all,
    So I recently realized that my stock rear leafs are flat under my setup (>350lbs of constant load on the rear axle). I have talked with some nice folks here and it seems that the flatter leafs are common and maybe normal for tundras? I am planning on doing something to it next year as I spent all my budget already for 2022 on my truck.
    I have couple of questions,
    1. the truck has 24k miles, relatively young, so would this flatter looking leafs be a safety hazard say before I reach 50k miles?
    2. If I want to have a heavier load bearing capability in the rear, would leaf pack works better than aal or RAS? I do off-road quite frequently so I assume RAS is not ideal since it limits suspension travel and have a tendency to come off under full articulation? I don't mind some rake.
    My current set up is
    Bilstein 6112 front with 1.9inch lift.
    Bilstein 5160 rear with stock leaf on coachbuilder +2 shackles.
    Picture of my truck (Fairly level, but even when its leveled, the leaf pack is still flat instead of arched, so I am not sure if the rear leaf on the tundra just flat stock?)
    the rear leaf looks like this on flat ground.
    then when I move my driver rear wheels on a curb, to create some articulation like offroad condition, the rear leaf is inverted
    Thanks in advance for the help and knowledge!
  2. Jun 13, 2022 at 7:05 AM
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
    Bilstein 6112/5160 3/1 w/CB shackles Ironman front bumper, 18+SR5 Honeycomb grill
    its normal tundra leaf sag- i dont even have a shell and mine are flat. ill be doing aal and see how that goes
  3. Jun 13, 2022 at 7:11 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Can confirm mine are very flat but I usually have about 500lbs in the bed.
    king.cong.1119[OP] likes this.
  4. Jun 13, 2022 at 7:33 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    AAL will sag over time, many dont last too long and they ride harsher. RAS is excellent option, get the HD version. I run it and it is great, supports load, stops/helps sag, no harsh ride at all and the price is great. Tundra leafs are soft anyway, so RAS is a great addition to help support them.
  5. Jun 13, 2022 at 7:54 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    1 - Not a safety hazard.
    2 - There are a number of options including AAL, Airbags and RAS. I went the AAL and airbag route and it works well for me. People who have RAS love them. But almost everyone who went either route agrees that a full custom leaf pack is the best option (like Deaver or Dob) - but only if your load is constant like with a camper. If your load varies like mine across commuting, towing, overlanding, etc, having adjustability is very beneficial.
    Also, I will say that while airbags and cradles offer the greatest articulation, there are very, very, very few reports of RAS coming off under full articulation. So while there is a risk, the last few years of reports have proven it to be low.
  6. Jun 13, 2022 at 7:59 AM
    king.cong.1119
    Thanks for the info and please let me know how it goes!
    Thanks, and that sounds about what I have in the bed, if I don't offroad I wouldn't be worrying about it, but since I put my truck into full articulation very frequently, I just worry about the leafs being broken or something down the road.
  7. Jun 13, 2022 at 8:00 AM
    king.cong.1119
    Thanks for the input!
    Do you know how RAS affects articulation? I wonder how much less the articulation will be if any?
  8. Jun 13, 2022 at 8:05 AM
    MSU Tundra
    MSU Tundra Numerous rodeos experienced
    Mississippi
    2017 Tundra and 2013 LC200
    I'll have a similar rear setup as yours and I will be doing the HD Leaf Spring from Dobinsons. All of the research I've done shows this option as the best all around setup. And Dobinsons makes quality stuff.
  9. Jun 13, 2022 at 8:13 AM
    king.cong.1119
    Thank you for the answers.
    I do have a constant load on the back,
    Leer cap: 250lbs
    Spare tire: 100lbs
    Tools/recovery gear: 150lbs
    RCI slider/fuel tank skids: 400lbs ( maybe only 200lbs acting on the rear axle)
    So now that I am thinking about it, my constant weight is almost 700lbs in the bed lol.
    I do put my truck through full flex all the time when I offroad, I assume my leafs go thru the full compression cycle much more frequently than others, will that shorten the expected life span of my stock leafs? I don't want to have something breaks away from home and off the paved roads :)
    I am leaning towards leaf pack, but then not sure if they will fit/work with my coachbuilder+2 shackles.
    Thank you again!
  10. Jun 13, 2022 at 8:13 AM
    frichco228
    Frank
    Virginia
    I do not, would be less than a rear sway bar, but I have no firm info. Many hear run RAS, so hopefully someone will chime in.
  11. Jun 13, 2022 at 8:15 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Those shackles are the only reason you're riding level cause if your pack was ok you'd have a rake.
    If you're worried about offroad capability staying intact then you should go full pack replacement. I'm biased towards Alcan springs but feel free to use whatever your research leads you to use.
  12. Jun 13, 2022 at 8:18 AM
    Saltyhero13
    It is a known issue with the Tundras. From what I read the shackles can exacerbate their weakness (I am not recommending you remove them).
    I am going with RAS HD while I work up to a full suspension upgrade. Will probably replace the leafpacks at some point.
  13. Jun 13, 2022 at 8:19 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Alcan has shackles with their springs if you want them...you could eliminate the shackle lift when you have the springs built. That being said, I have CB +2s with my Alcan pack and they work well but only because he factored that in when he built the pack.
  14. Jun 13, 2022 at 8:20 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Only if extended bump stops aren't installed with shackles that provide lift
  15. Jun 13, 2022 at 8:22 AM
    Saltyhero13
    Gotchya. Thanks for clarifying that.
  16. Jun 13, 2022 at 8:34 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I think whatever route you take, the RAS would be a great addition to, or on its own. You should get the HD set, throw them on and see how it looks/feels. If you still have the sag, you could go with a new leaf pack, but still use the RAS as support or a crutch against hard bottom outs. IMO you cant lose with the RAS. Even if you decide you hate them, which I have never heard, you can probably sell them on here pretty quick for a minor loss.
    I love my RAS and even though I dont have as much constant load as you, you would just run the RAS tighter than me.
  17. Jun 13, 2022 at 2:15 PM
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Currency converter= Earned to wasted dollars
    783D144A-28EA-4FAB-BE67-2DFF528B0079.jpg D80DE3C1-90D2-4B0D-963F-C5800C1F175B.jpg
    My 0.02’s…I hope it helps… I’m glad i bite the bullet and went for the custom Alcan spring set up.. (Usually I’m the one to go for the cheap fix and windup spending more in the end)… I had a constant weight of about 700lbs and was unhappy with ride @ 25psi of air in the bags to keep it level…All kinds of bounce when towing and inverted springs with 1.5 shackles in the back… Had Lew build in 2”s of lift and 800lbs over stock and used his shackles since they were very close to OEM… Love the ride now and no more sag… tows the camper like a dream…. Gas prices have keep me from heading west so haven’t done any crawling (other than some wash board roads locally)….Sorry no help there… my vote is a new leaf pack.. Satisfied customer here… Like totally different truck now
  18. Jun 13, 2022 at 3:45 PM
    king.cong.1119
    nice evo corsa wheels! I am going to take a guess and say you got them thru mainline overland? Just pure guessing. Would you say Alcan springs and Deaver are about similar in terms of quality and performance?
  19. Jun 13, 2022 at 4:49 PM
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Yeah…$ChaChing…gotta keep food on the plates for those boys over at mainline…LOL…. From what I’ve read.. for the most part they’re the same… probably a few more here in the Deaver camp…(They’re pretty busy and harder to get hold of)… but, Lew is a nice guy and super easy to work with… he made me go get a truck weight before i ordered… (which I highly recommend cause my guesstimate was way off) answered my hundreds of questions and the springs were done way sooner than Deaver’s would be.. Deaver tended to want to push people to their U748’s in stock… IDK.. give’m a call see if your experience is different… Anyway, super happy with my springs even with an empty bed it rides better than stock… whole lot more responsive when accelerating. Got my rake back and got rid of the sagging without having to keep messing with my airbags… now they’re just bump stops…(5psi)..hope that helps:cheers:
  20. Jun 13, 2022 at 4:55 PM
    Wahayes
    Will
    2017 tundra limited *sold*
    Our stock springs suck. Mine were inverted just sitting static. I have a cap and offroad alot, but I also tow fairly heavy and hauled alot of broken concrete in it. Also those coachbuilders aren't helping the issue either. They're making it worse. I just upgraded to dobinsons and it's night and day difference
    Dogsled likes this.
  21. Jun 13, 2022 at 5:18 PM
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    How much lift did you get from the Dobinsons?… And did you go back to 1” shackles?…..Come on man…:boink: where’s the pictures?… and don’t short change us on pics of that beautiful front bumper :thumbsup:
  22. Jun 13, 2022 at 5:21 PM
    Wahayes
    Will
    yea normally I'm a pic whore , I don't know what I was thinking haha they were 2.25 springs I got around 3 or more out of them because my sag was so bad. I would have to find my measurements ts before , but after is 25.5 hub to fender I believe. Stock shackles.
  23. Jun 13, 2022 at 5:35 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I have the Toytec progressive 3 leaf AAL and I’m very happy with it. The truck had it installed already when I purchased it with 42k on it, I have 53k on it now. They ride great and support the stock springs well. I also have airbags with cradles but I honestly don’t even need to put air in them and my truck does not squat with my 700+ tongue weight camper, my bed cap, and a bed full of camping stuff. If you’re looking to spend 700 bucks or so a whole new leaf pack is probably the best option, but I have no complaints at all with my progressive AAL and have no plans to change it. It costs less than half the price of a new leaf packs so something to consider.
    Dogsled likes this.
  24. Jun 13, 2022 at 5:35 PM
    I replaced my flat springs with Alcans at 200 lbs over, and 1/2 inch of lift. I run them with Toytec shackles set at 1.5. I may do some measurements at some point to see if the lift from a RAS would be too high...if it would even work with the Alcans.
    Dogsled likes this.
  25. Jun 13, 2022 at 5:48 PM
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    These may help?
    And now back to our regular programming....................
  26. Jun 13, 2022 at 6:07 PM
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    $700 bucks or so....:rofl:
    yeah… but can your springs do this…
    Haha…
    Hey Tundra234…. Did you get the popping noise figured out?…. There are a couple of guys on here that have Alcan and RAS together.
    Saltyhero13 likes this.
  27. Jun 13, 2022 at 6:30 PM
    Silver17
    Eastern PA
    Yeah they can. My springs are the number Juan spring on the market.
    Saltyhero13 and Dogsled[QUOTED] like this.
  28. Jun 13, 2022 at 6:42 PM
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Well played sir…..
    Silver17[QUOTED] likes this.
  29. Jun 13, 2022 at 6:56 PM
    Silver17
    Eastern PA
    :hattip:
  30. Jun 13, 2022 at 7:22 PM
    Not yet...I haven't messed with it lately. Hopefully this weekend.
