Opening Toyota Transfer case oil can
Discussion in '2.5 Gen Tundras (2014-2021)' started by Joe333x, Jun 12, 2022.
  1. Jun 12, 2022 at 5:58 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    2019 Tundra CrewMax Platinum
    UPDATE: Found a churchkey
    So this is going to sound silly but being in my 30s, I obviously have never opened a can of oil. I dont think I even own one of those pointed openers that you poke a hole at each end with. Would it be okay to use a hand held rotary can opener or should a grab a metal poke one?
  2. Jun 12, 2022 at 6:01 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Use a p38
    F0X672, Hbjeff and Joe333x[OP] like this.
  3. Jun 12, 2022 at 6:02 PM
    Screw driver, stab it like your breaking up ice
    Joe333x[OP] likes this.
  4. Jun 12, 2022 at 6:10 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Hey Joe,
    Some years ago, gear oil formulators evolved due to a consumer need for simplifying user experience. One of many bottling improvements I’m sure, was a hard plastic bottle and today companies like Valvoline offer their Flex Fill packaging technology. Take a moment to open and easy to get into your transfer case. Just took a 3,000 mile trip with this in my front/rear diffs and transfer case and couldn’t be happier, due to the packaging, I’ll be using this formula until something better comes along! Hope you get many miles on your truck!
    WBW likes this.
  5. Jun 12, 2022 at 6:10 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Next time you’re out stop at the dolla tree
  6. Jun 12, 2022 at 6:22 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    I use the same in my front and rear diffs but unfortunately the transfer case calls for 75w and you can choose between ravenol or toyota. When Toyota changed transfer cases (i forget which year) but you can tell by if your drain and fill plugs are 3/8 sockets or bolts. The older transfer case that took 75w90 had the drain plug under the little skid plate. I contemplated using the ravenol but had seen a couple bad reviews and seen some that used 75w90 post about rough transfers into 4wd. So after some careful consideration, I figure I only am doing it every 30,000, which is about 3 years for me. So I'll spend the extra money on the correct spec oil simply because I have super smooth transfers in and out of 4wd and would like to keep it that way. I do know that most have posted that even dealers use 75w90 and probably have no idea Toyota changed the spec.
    georgiey22[QUOTED] likes this.
  7. Jun 12, 2022 at 6:55 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    Look what I just found in the back of my silverware drawer! No idea where it came from but sure glad I have it! Knickerbocker was discontinued in the 70s so this thing has probably been used to open an oil can before lol. Known as a "churchkey" for anyone curious.
  8. Jun 12, 2022 at 7:57 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I posted one of the "bad" reviews on Ravenol, based on the looks and smell of the oil when changing. But once the UOA got back, everything was all good. Almost 60k miles on it I believe. And it still had life left. I switched to HPL 75w.
    Could you post a photo of what the Toyota 75w looks like in a clear container with your leftover fluid? I'm curious. I've heard different things.
    Doxiedad and Joe333x[OP] like this.
  9. Jun 12, 2022 at 8:00 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    Absolutely! Hoping to do the job next weekend, I'll post it in this thread afterwards with a side by side of the old and new.
    Sumo91[QUOTED] likes this.
  10. Jun 12, 2022 at 8:03 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    What is HPL 75w, havent seen that one yet.
  11. Jun 12, 2022 at 8:12 PM
    Sumo91
    TN
    High Performance Lubricants
    They make incredible oil, they're one of the site sponsors on BITOG, which says alot if you've ever been on that site, and see how some people tear apart any kind of boutique oil brand that isn't absolutely top tier. I called them and discussed my oil needs, and asked if they made a 75w, they said no, but they can definitely make a batch for me whenever I need it. Same price as their diff fluid too.
    I've put it through many miles of offroading so far, and it's been fantastic. Quicker engagements than the ravenol and zero issues.
    Joe333x[QUOTED][OP] likes this.
  12. Jun 12, 2022 at 8:16 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    That would explain why nothing came up on google lol. They should definitely make it commercially available since right now theres only 2 choices, a third would be nice but I'm sure the market isn't not that big or else one of the larger brands would have already jumped on it.
  13. Jun 12, 2022 at 8:16 PM
    Sumo91
    TN
  14. Jun 12, 2022 at 8:21 PM
    Sumo91
    TN
    I talked with him about it, and the demand for mass production isn't there. But if anyone needs it, he can make it for you.
  15. Jun 12, 2022 at 8:22 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    Good to know, what was the cost if you dont mind me asking?
  16. Jun 12, 2022 at 9:14 PM
    Sumo91
    TN
    It wasn't alot. I bought like $500 worth of oil at the time. I'll have to look.
  17. Jun 12, 2022 at 9:21 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    Thanks just curious were it stacks between ravenol and the toyota stuff, I paid $55 a can for the oem stuff and ravenol is $25.
  18. Jun 13, 2022 at 4:24 AM
    Sumo91
    TN
    Just checked the current pricing (not sure if it changed since I bought it) I bought 12 quarts, and it came out to 18.44/qt +shipping.
    I tend to buy lots of oil at once to save on shipping and bring the total cost per quart down.
    Joe333x[QUOTED][OP] and “J” like this.
  19. Jun 13, 2022 at 5:29 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Ive actually got two of these in a box in the shed.
    WILLINH likes this.
  20. Jun 19, 2022 at 1:31 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    Here you go, just changed it today, old on the left new on the right. I'd say it has a similar color to motor oil and a similar smell to regular 75w90 gear oil.
    Sumo91[QUOTED] and GODZILLA like this.
  21. Jun 19, 2022 at 1:38 PM
    18" TRD Off Road Wheels
    Looks a bit darker, but that's normal for any oil. How did it smell?
  22. Jun 19, 2022 at 1:42 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    Didn't smell much different than typical gear oil smell. That was 33k miles, I'm sure it was was still good to go but felt like changing it. There was some small metal debris in the pan but nothing too crazy for a first time fluid change.
    GODZILLA[QUOTED] likes this.
  23. Jun 19, 2022 at 1:43 PM
    That's good info. :thumbsup:
  24. Jun 19, 2022 at 2:31 PM
    Sumo91
    TN
    Thanks for the picture!
