Turn Signal and Brake Light Power Wires
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, May 28, 2022.
  1. May 28, 2022 at 8:22 AM
    matictundra
    matictundra [OP] New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I’ll be mounting my two 5’ whip lights on the roof rack. Cable will go thru the scanstrut deck seal located very near the front center and ending up in driver kick panel. My whips have brake and turn signal wire triggers. Where and which power color wires in the driver kick panel for brake, left signal and right signal?
  2. May 31, 2022 at 2:56 PM
    matictundra
    Franco
    AZ
  3. May 31, 2022 at 6:47 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Turn signals come from the flasher relay to the bulbs. Green 10 front left blinker Tan 17 front right blinker. Sky Blue 8 Rear Right blinker, Black 2 Rear Left Blinker
    Stop light I would go for the tan 8 wire coming out of A51
    matictundra[OP] likes this.
  4. Jun 1, 2022 at 4:41 PM
    matictundra
    Franco
    AZ
    Thanks.
  5. Jun 11, 2022 at 10:45 AM
    matictundra
    Franco
    AZ
    Where exactly is A51 connector behind the driver dash? Pix would be great, I dumb with out visual reference.
  6. Jun 11, 2022 at 11:17 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
  7. Jun 11, 2022 at 1:09 PM
    matictundra
    Franco
    AZ
  8. Jun 11, 2022 at 9:51 PM
    matictundra
    Franco
    AZ
    I ended up tapping PA1 connector red 6 wire. PA1 is located on the driver side.
  9. Jun 11, 2022 at 10:19 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Glad you got it worked out.
    Please post a pic when you get it all done.
  10. Jun 13, 2022 at 8:17 AM
    matictundra
    Franco
    AZ
    I also ended up reconnecting to sky blue 8 and black 2. The other mentioned wires also power up when daylight running light is on.
    Jeff_5_7[QUOTED] likes this.
