TRD Pro Suspension
Discussion in 'Suspension' started by Tundraofnv, Apr 18, 2022.
  1. Apr 18, 2022 at 3:33 PM
    Tundraofnv
    Tundraofnv [OP] New Member
    2020 Cement Crew
    What are you folks paying for used TRD Pro take-off struts and shocks (FOX)?
  2. Apr 18, 2022 at 4:52 PM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    Depending on where you are located I’ve tracked them ranging from 900 to 3,000. Mileage and location play a big factory in pricing.
    Keep in mind sparks parts has them brand spanking new for 3300 right now.
    On the forums they range from; $1100-2000. Good condition with sub 5,000 miles
    eBay they float around 2700-3000
    Facebook marketplace I’ve seen as low as 975, I’m in the arm pit, deeeeeep south
  3. Jun 8, 2022 at 8:58 PM
    Sierra_Nevada
    Sierra_Nevada New Member
    Kansas City
    2020 Magnetic Gray Platinum
    TRD Pro Fox Suspension, SCS Ray 10 Wheels, BFG KO2 275/70 R18
    I bought the FOX setup brand new tonight from Sparks and paid just under 3k delivered. I googled discount codes for Sparks and found a 5% off, which their website took.
    Tripleconpanna likes this.
  4. Jun 8, 2022 at 9:01 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    If you find them for $1000/$1500 in like new condition (which I've seen), that's a great deal. As mentioned above, new for $3300 right now is not bad, plus you know the condition of your purchase.
    I may be reading into this a bit much... But, if someone is pulling suspension off their Pro w/low mileage it's probably to put lifts/better suspension on. To me that means they're probably into off roading, which means they may have hammered their OE suspension parts. Just something to consider!
    ToyoMafia and jgullace like this.
  5. Jun 9, 2022 at 12:47 PM
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    Ya if you steal a set for like $900 they can be rebuilt by Fox for $115 (2.5 piggyback's) each so they would be basically new after that. I would go that route if your worried about past abuse. Still a huge savings over new.
    Tripleconpanna and Sierra_Nevada like this.
