Fox 2.5 fitment issues?
Discussion in '1st Gen Tundras (2000-2006)' started by 2uzfe2000, Jun 8, 2022.
  1. Jun 8, 2022 at 4:04 AM
    2uzfe2000
    2uzfe2000 [OP] New Member
    Im replacing some old (15 years) fabtec coilovers on my 1st gen. I want to get something nice that will ride better than these stiff fabtecs. The Fox 2.5 coilovers (880-06-420) seem to fit the bill but I saw that there may be issues with them hitting the brake lines. I can't get a straight answer from any vendors about this. Is anyone aware if this issue still exists?
    I should also ask if there is another coilover that will have a comfortable ride. The truck rarely sees more than gravel and dirt roads, as well as highway use. I currently use SPC UAC's.
  2. Jun 8, 2022 at 8:13 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    There's some info about the Foxes and the brake line situation in this thread. https://www.tundras.com/threads/fox-2-5-with-external-reservoir.86736/#post-2219737
    At the very least, maybe ask the vendor you're interested in purchasing from to send a picture of the lower shock perch. If they have the smaller perch, you'd probably need to contact Fox directly to get it switched out.
    Another shock I can recommend personally is the King 2.5s. I switched to them from another brand, and I've been running them with SPCs for over a year. If the Foxes fit the bill for you, so will the Kings.
    evilrb likes this.
  3. Jun 8, 2022 at 4:01 PM
    2uzfe2000
    Contacted fox and they said if its been made within the last two years that the problem has been fixed with the taller bottom spring perch. However I saw a youtube video posted in 2021 of a guy who installed a new set that did not have the fix. I am still unsure what the best plan is here.
    On a side note, how does Icon compare to King and Fox? I am looking at the Icon 2.5 extended travel.
  4. Jun 8, 2022 at 4:19 PM
    Cummins3500
    Logan
    Been down this rabbit hole lol. Anyways king, Fox, ADS all use a progressive valving. Icon on the other hand uses a digressive valving.
    https://www.tundras.com/threads/let’s-talk-suspension-icon-vs-fox.72357/
    I looked at the options, and changed my mind several times before landing on ADS 2.5s. My wife’s sequoia is on kings. Both setups are great.
  5. Jun 8, 2022 at 7:06 PM
    2uzfe2000
    At this points it's looking like Icons are the only shocks available, the only Kings I have found are not extended travel.
    Another question, if I set the coilovers for a 2.5" lift, could I use a 1/4" top hat spacer to get another 1/2"?
