Discussion in 'Other Builds' started by Black Wolf, Oct 29, 2021.
  1. May 31, 2022 at 5:58 AM
    #121
    Black Wolf [OP] Chillin' in Alamosa
  2. Jun 2, 2022 at 3:55 AM
    #122
    Doing its job! Nice catch....see what I did there?:rofl:
    Having a CC on a DI motor is a really good idea.
  3. Jun 2, 2022 at 4:01 AM
    #123
    It was $160 well spent!
  4. Jun 2, 2022 at 6:16 AM
    #124
    Wahayes
    Will
    2017 tundra limited *sold*
    So someone school me on the catch can thing. Do DI motor just try to purge themselves of oil or what? I don't get it
  5. Jun 2, 2022 at 8:23 AM
    #125
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Congrats on the Frontier. I used to have one and loved that little truck. It was heavily modified and carried my FWC. If you take care of them, they last a long time.
  6. Jun 3, 2022 at 10:32 AM
    #126
    Direction Injection is just that. Gas can cleanse the valves somewhat with port injection. Catch cans "catch" blow by and prevent it from fouling the valves on a DI motor over time.
    ColoradoTJ and Wallygator like this.
  7. Jun 3, 2022 at 10:36 AM
    #127
    Wallygator
    I know that motor has been around for a few years now. Have you heard of when the valves are needing to be blasted at some point? Is it in the owners manual? I couldn't find anything on it, just wondering if you know. The catch can would probably push this service out a ways I'm guessing.
  8. Jun 3, 2022 at 10:39 AM
    #128
    king.cong.1119
    king.cong.1119 New Member
    I will chime in on the frontiers, rented one when I was in hawaii for 2 weeks and man it was a comfortable, quiet and nicely geared (power) truck. I too would take that over a new tacoma just because I am not a fan at all of the new tacoma AT's gearing. Enjoy!
    Wallygator and Black Wolf[OP] like this.
  9. Jun 3, 2022 at 10:40 AM
    #129
    Motor is pretty new. 22 is 3rd model year with.. With top tier fuel and a catch can, I'm guessing 100K+ easy before walnut peening needed.
    Wallygator[QUOTED] likes this.
  10. Jun 3, 2022 at 10:41 AM
    #130
    king.cong.1119
    with that rear bed extention, id say its more of a 6 feet bed lol
  11. Jun 3, 2022 at 10:43 AM
    #131
    This new Frontier is the quietest truck I've ever owned. Cab is crazy quiet and comfortable. Nissan nailed it with the sound deadening and cab damping mounts.
    831Tun, GODZILLA and Wallygator like this.
  12. Jun 3, 2022 at 10:44 AM
    #132
    Just over 7ft. I measured it.
    Wallygator likes this.
  13. Jun 3, 2022 at 1:24 PM
    #133
    I want to add that Nissan also decided to use laminate glass for the Frontier front driver and passenger door windows to cut down on outside noise. Hard to break though. Rear door window glass is the regular shatter proof. There's always a trade off.
  14. Jun 4, 2022 at 5:54 PM
    #134
    A Prime just literally dropped off my 60W Rockpals solar panel. $140 and a Jackery 240WH. Refurbished for $180 with warranty. The Rockpals panel is wired parallel and comes with a Y cable to add another 60W panel to halve the charging time. Stoked. Perfect to power my F40C4TMP 20qt freezer. Ice cream off grid. Yes, I want to eat ice cream on my off grid property. So does Manny. Life is short.....ha!
    I will review.......
  15. Jun 6, 2022 at 4:10 PM
    #135
    Been messing around with my Jackery 240wh. Didn't bother connecting the 60W solar panel. Afternoon thundercloud bs. Jackery was already at 100% but wanted to try out the charge thru with the 45W max load from my freezer. The freezer will draw 45W in MAX mode until temp hits programmed setting then drops to 1 or 2W. In ECO mode will draw 33W. Tried the 12V connection and then the 110VAC connection. I set the freezer for -0.2 F. Takes a bit of soak time to go that low. I ordered a 2nd 60W solar panel to use in parallel. I'm already thinking about getting a 500W LiFeP04 power station. Lithium Iron Phosphate battery tech. I'm into this now. $$$....kuul beans. Buy your power station according to what you will have drawing off it. Buy solar panels accordingly too. Remember.....power station Watt hour rating X 0.85/ the total max load=run time hours....easy peasy....
  16. Jun 6, 2022 at 4:24 PM
    #136
    Hit -0.5 and freezer load dropped to 5W draw. Keep in mind....placement of the freezer is paramount. Shade is good. I keep saying freezer but it's a refer/freezer and heater up to 131 F. Doubt that I'll ever use the heat function.
  17. Jun 6, 2022 at 5:20 PM
    #137
    I also bought some 5W Onite led lights. A single USB bulb and a dual bulb set that uses a "y" USB connector. Low draw and 5W is actually decent in a tent. Long cables too. Stoked. $10 for the single and $20 for the dual combo set. Each bulb has a metal hanger. Beware of knock offs that have a short cable and a cheesy plastic hanger that will easily break.
  18. Jun 6, 2022 at 5:29 PM
    #138
    I'm warming it back up to 32F. Only drawing 4W. Ice cream and Jolly GG veggies back in my house chest freezer. Jackery been used for only 3.25 hours. Not bad including soak time to hit -0.5F. Real world....I'd pre-soak freezer in house prior to leaving to my property. Switch to Jackery while driving. Switch to solar once I arrive at my property. I'm liking this...
  19. Jun 6, 2022 at 5:47 PM
    #139
  20. Jun 7, 2022 at 2:02 PM
    #140
    Sunny afternoon so the 60W Rockpals solar panel is out and connected to the Jackery which is at 62% charge. Panel is putting out 50 to 52W. Decent. Will see how long a full charge will take....keep in mind the 60W rating is under ideal laboratory conditions. My 2nd panel is on its way.
  21. Jun 7, 2022 at 2:22 PM
    #141
    My 2nd 60W Rockpals solar panel was $99.98. Rockpals gave me a $42 price adjustment on my 1st panel. Kuul beans! Check out Rockpals.com. I'm looking at the new Freeman LiFeP04 battery 500W/panel combo.
    FYI....my 1st solar panel was missing the parallel y cable to connect an additional 60W panel. Rockpals sent me the cable today on their shipping dime.
  22. Jun 7, 2022 at 4:00 PM
    #142
    Update.....started charging the Jackery at 3:05. 62%.
    4:45.....the Jackery 240Wh reached 97% and it's internal MPPT solar panel voltage regulator/controller shut down the input current from the solar panel to prevent overcharge. Input read 0W. Quite pleased. 35% gain in 1.75 hours of solar charging. Not bad at all and very typical with the single 60W panel. Two 60W panels in parallel will halve the charge time. On a sunny day with full exposure I can expect 90W to 100W's from the dual solar panel setup. Nifty!
  23. Jun 7, 2022 at 4:12 PM
    #143
    I'm tempted to start a portable power station/solar panel thread if there isn't one already.....
    Edit....started the thread....
    Mountun Goat, GODZILLA and Wallygator like this.
  24. Jun 7, 2022 at 4:53 PM
    #144
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I was never very good at maths but wasn't your charge time only 1.66 hrs?
    Regardless, it's a very cool setup and I appreciate you posting all the info about it.
  25. Jun 7, 2022 at 5:05 PM
    #145
    I'm also testing beers...math could be off a bit . I use math all day at work....after that....close enough works! Ha! Decent charge time tho....
    Wallygator and 831Tun[QUOTED] like this.
  26. Jun 8, 2022 at 6:54 AM
    #146
    Decided to try out the new Rockpals Freeman 600W power station.....$430
  27. Jun 8, 2022 at 10:04 AM
    #147
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  28. Jun 25, 2022 at 6:37 PM
    #148
    Manny and I went out this morning to look for more petrified wood. Did good. Found some rare palm which is a plus and a real, real nice colorful piece........real nice......
  29. Jul 9, 2022 at 5:29 PM
    #149
    Willard
    Willard New Member
    2024 F250
    I was given a 2019 frontier as a rental when my tundra was in the body shop last month. Some jerk hit my parked truck and drove off. Didn’t get his plates unfortunately. I was pleasantly surprised at the ride, acceleration, and my wife and two kids really liked the smaller size.
    I test drove a loaded sv crew cab today and really liked it. Super quiet on the freeway. Comfortable seats. Even more space in the second row for my kids compared to the rental. I wish it had a telescoping steering wheel.
    There’s a white pro 4x coming in later this month. I’m teetering on taking it.
  30. Jul 10, 2022 at 6:25 AM
    #150
    Not having a telescoping steering wheel is a bummer but certainly not a deal breaker at all. I have over 6K miles on my CrewCab SV and no regrets buying it at all. Not a gas hog. A pleasure to drive actually!
    T-Rex266, Wallygator and ColoradoTJ like this.
