What grease do you use?
Discussion in 'General Tundra Discussion' started by Gfgneo, Jun 7, 2022.
  1. Jun 7, 2022 at 7:00 AM
    Gfgneo
    Gfgneo [OP] New Member
    California
    2021 tundra platinum
    For those that have SPC UCA what grease do you use on the boot? Mine are squeaking like crazy so its time to grease them up. (Should have went with uniball, less rubber=less squeaking)
  2. Jun 7, 2022 at 8:28 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Probably cant go wrong with Lucas red and tacky
  3. Jun 7, 2022 at 9:10 AM
    Gfgneo
    California
    Have you used lubriplate 3000 or 3002?
  4. Jun 7, 2022 at 10:25 AM
    MadMaxCanon
    I have not. I am still on the stock UCA, but I have used the lucas on UCA and suspension components on previous vehicles. I also use it for greasing trailer bearings.
  5. Jun 7, 2022 at 9:28 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    You have to use what their recommendations are.
    I used the Valvoline Moly 3% when I installed the SPC UCA.
  6. Jun 7, 2022 at 9:30 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Did you grease them when you installed them? Suppose to grease every oil change.
  7. Jun 8, 2022 at 7:33 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    The best NGLI 2 grease I've ever used with a 5% moly content is Schaeffers 238. It's the tackiest grease I've ever come across (other than prothane ngli 3 or energy suspension grease, different application for those those)
    The 238 isn't good for high speed bearings, but for ball joints, etc, it's unbelievably good. Give it a Google. People on Bitog love the stuff.
    Retired...finally likes this.
  8. Jun 9, 2022 at 6:51 AM
    Gfgneo
    California
    I didnt the fist oil change i did the second. According to spc they claim there is no need to grease for the life of the joint which is why i went with them over camburg or total chaos.
  9. Jun 9, 2022 at 6:54 AM
    Gfgneo
    California
  10. Jun 9, 2022 at 7:25 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Not sure where they posted that, but those sealed ball joints should be greased or checked every oil change. Doesn’t hurt though, regardless it’s a moving part.
    MEWaters likes this.
  11. Jun 9, 2022 at 6:04 PM
    Gfgneo
    California
    Luckily Amazon has it in stock so i purchased it. Ill try it out on Sunday
  12. Jun 9, 2022 at 6:29 PM
    Sumo91
    TN
    They usually have it there, but it's pricey. You can search for a Schaeffers Rep near you. They get way better deals and sometimes give you freebies of different stuff.
    Toyotoholic likes this.
  13. Jun 9, 2022 at 11:14 PM
    Gfgneo
    California
    Good looking out. I only bought one to try it out. If i like it ill look into that
  14. Jul 10, 2022 at 9:34 AM
    Gfgneo
    California
    Thanks for the recommendation. It solved 85 to 90% of the squeaks. It still squeaks over big dips and speed bumps but it doesnt on the small things like pulling out of my driveway anymore.
    Sumo91[QUOTED] likes this.
  15. Jul 10, 2022 at 1:06 PM
    Sumo91
    TN
    Glad it worked out for you :thumbsup:
    Maybe it will work its way around and get rid of the squeaking completely! How long have you had ran it with that grease?
  16. Jul 10, 2022 at 1:29 PM
    Gfgneo
    California
    I want to say early to mid June i think
