Off Road Bottle Jack?
Discussion in 'Recovery & Gear' started by 2point5seconds, Jun 7, 2022.
  1. Jun 7, 2022 at 10:51 AM
    2point5seconds
    2point5seconds [OP] Wish I didn't have so much money
    Sensei
    Nor Cal
    2019 Tundra SR5 TRD 4WD Double Cab
    Icon Stage 9 lift, 700 pound rated Eibach spring, Sumo Springs (rear), RCI engine skid plate. RCI Lower Control Arm Skid Plates, RCI Transmission Skid Plate, RCI Cat Guards, Rago dash plate. RAM phone holder. Bed rails. Tint. 17x8 Icon Rebound wheels. 315/70/r17 Falken Wildpeaks. AAC Trigger 6 Shooter, midland MTX-115 radio, Chassis Unlimited front bumper, OLB Bar light and ditch lights, Baja Fog lights, Smittybilt winch, Husky floor liners, bed rail, Cali Raised Bed Stiffeners, driver's side grab handle, Wheeler's Offroad front bump stops, Decked Tool Box
    2019 Tundra 5.7l 4WD DC
    Icon Stage 9. 3"lift
    315/70/17 falken wildpeaks
    Trying to see if anyone took a bottle jack and set up a way to use on a lifted truck while going off road?
    Looking for a cheaper set up than Pro Eagle. Although it would be nice to have one.
    I see that Safe Jack has a set up. But the prices are almost comparable to Pro Eagle.
    911 Motorsports has extensions but you also need welding experience.
    Went to YouTube and some guys set up a bottle jack with extensions and a base plate to prevent sinking but they had welding expertise.
    May need to save up for the ProEagle.... but anyone see the gas prices nowadays? LOL. Jk. I know I bought a truck be prepared to pay alot for gas.... also I may need to learn to weld. Seems like you need that if setting up off road vehicles. Or know someone.
    Thanks for the help!
  2. Jun 7, 2022 at 11:40 AM
    Sunnier
    Sunny
    San Diego, CA
  3. Jun 7, 2022 at 11:47 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    The stock bottle jack goes pretty damn high. Jack off the axle or the A arm (I'm sure the frame next to the A arm pivot would be plenty too). Worst case bring some wood blocks. I've never carried any extension or ever worried about lifting anything with stock jacks.
    Or just buy a HF floor jack, ProEagles are nice but how often do you plan to be using your jack?
    831Tun and 2point5seconds[OP] like this.
  4. Jun 7, 2022 at 11:54 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    You can get a HF floor jack and buy the pro eagle extension and you will have essentially the same proeagle setup and save yourself a couple bills.
  5. Jun 7, 2022 at 12:10 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
  6. Jun 7, 2022 at 12:24 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Cruzer mentions in his thread what he brings with him while off-roading. Even made a little case for it. It’s a 2 ton HF aluminum with pro eagle extension. I have the same one. Super light but also fairly capable. Could build a sled for it too if you wanted to use it a ton off-road
    equin and 2point5seconds[OP] like this.
  7. Jun 7, 2022 at 12:26 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  8. Jun 7, 2022 at 12:30 PM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
  9. Jun 7, 2022 at 1:06 PM
    Sunnier
    Sunny
    San Diego, CA
    2point5seconds[OP] likes this.
  10. Jun 7, 2022 at 1:12 PM
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    I have the 3 ton one, love it used it several times.
  11. Jun 7, 2022 at 1:13 PM
    2point5seconds
    Sensei
    Nor Cal
    Yeah I have a bottle 20 ton bottle jack and wood blocks I always carry. Keep it cheap. Lol. I haven't used they set up yet and it's been a few years since I thought of it. I was in the middle of no where and needed to jack the truck higher and luckily I found a cinder block. After that I got the bigger bottle jack and wood blocks.
  12. Jun 7, 2022 at 1:13 PM
    king.cong.1119
    king.cong.1119 New Member
  13. Jun 7, 2022 at 1:14 PM
    2point5seconds
    Sensei
    Nor Cal
    Anyone worry about the bottle jack sinking in mud, sand, snow? I know safe jack has a wide base plate you can buy to prevent that.
  14. Jun 7, 2022 at 1:15 PM
    2point5seconds
    Sensei
    Nor Cal
    Did yours come with it leaking? Some of the reviews says theirs arrives with oil all over the place.
  15. Jun 7, 2022 at 1:15 PM
    king.cong.1119
    I had a wood board and now have the safe jack plate, its a huge plate that also use a stabilization when you have to use on uneven ground.
  16. Jun 7, 2022 at 1:16 PM
    2point5seconds
    Sensei
    Nor Cal
    Yeah. I was looking at getting the plate.
  17. Jun 8, 2022 at 9:17 AM
    2point5seconds
    Sensei
    Nor Cal
  18. Jun 8, 2022 at 9:23 AM
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    I know your not talking to me but I’d get one it’s a great tool to have and not that expensive either.
  19. Jun 8, 2022 at 9:27 AM
    2point5seconds
    Sensei
    Nor Cal
    Did you get the 3 ton? Did yours leak in the.box when you received it? There's some reviews that some people received it like that. Thanks!
  20. Jun 8, 2022 at 9:28 AM
    Wahayes
    Will
    2017 tundra limited
  21. Jun 8, 2022 at 9:44 AM
    gladecreekwy
    J
    Jackson Wyoming
    Mine did not leak. There is a bleed valve that if shipped open and the box gets tuned upside down it would leak some oil.
  22. Jun 8, 2022 at 10:01 AM
    Wahayes
    Will
    2017 tundra limited
    Nope, also if you're concerned with that the sell it at tractor supply as well.
    Sunnier and 2point5seconds[OP] like this.
  23. Jun 8, 2022 at 10:22 AM
    2point5seconds
    Sensei
    Nor Cal
    The Powerbuilt jacks, do they raise 18 to 21 inches above the height of the jack, or is the 18 to 21 inches counting the height of the actual jack?
    JODOOR likes this.
  24. Jun 8, 2022 at 10:49 AM
    Sunnier
    Sunny
    San Diego, CA
    Actual height, including the Jack base. I got mine at TS, great option if you have one nearby.
  25. Jun 8, 2022 at 4:20 PM
    I keep a 3 ton bottle jack in the truck along with accessories from Safe Jack. I bought the jack separately from Home Depot. I think I have around $120 invested in this setup.
    Edit- 6 ton!!
    AggiePhil, DarkMint, junior and 5 others like this.
  26. Jun 8, 2022 at 4:36 PM
    Sunnier
    Sunny
    San Diego, CA
    You able to fit this in the OEM storage compartment below the seat of your 1st gen?
  27. Jun 8, 2022 at 5:59 PM
    Yep. It all fits.
  28. Jun 8, 2022 at 6:10 PM
    Cthulhu
    I did a good bit of research on this, trying to keep costs down, but keeping safety a priority. I was about to pull the trigger on the Safe Jack starter kit, but then I found a video by that Robmotive dude, and even though he kind of gives the OEM jack some grief, I “stole” an idea of his. It was meant to only be temporary if I ever get a flat, but shoot, when I put a socket and screw gun on the crank stub of the OEM jack coupled with my homemade base, it’s lighter and quicker than my 3-ton floor jack, so I just use this with jack stands when I’m at home working on the truck. The second stage only comes 1/2 way up when the front tire clears the ground, when jacking on the frame rail close to the front tire. I consider it stable and safe for my needs. Running Coachbuilder TRD Pro set-up (3” left front 1.75” rear) and 275/65/R20’s (34.1” tall).
    (3) 2x6’s screwed and glued together, I used two bolts (instead of Robmotive only using one) with wing nuts to secure the jack to the base. Topped with Rustoleum Bedliner paint.
  29. Jun 8, 2022 at 8:08 PM
    Sunnier
    Sunny
    San Diego, CA
    Hey, looks like that’s a 6 ton, not a 3 ton :muscleflexing:
    AND it fits in the storage space on the 1st gen… should fit in a later gen, no problem.
    So, OP, it may be a better move to find a Jack with a small base, instead of this type, that I have to carry in the truck bed:
  30. Jun 9, 2022 at 6:14 AM
    Yes good call. Brain fart on my part. It's a 6 ton.
