Installing new front shocks on 21 SR5
Discussion in '2.5 Gen Tundras (2014-2021)' started by eagleguy, Jun 6, 2022.
  1. Jun 6, 2022 at 6:54 PM
    eagleguy
    eagleguy [OP] New Member
    I know there are different threads out there, but. I am thinking about raising the front of my 21 SR5 to make it level front to rear. . Is replacing the shocks difficult and will a wheel alignment be necessary when I am done?
  2. Jun 6, 2022 at 6:57 PM
    737fixer
    737fixer New Member
    If you live in a climate that EVER gets down to 40 degrees then avoid the Falcon's at all cost. So basically speaking, if your truck build is in south central Bagdad then your good.
  3. Jun 6, 2022 at 6:57 PM
    Front maybe 3-4 hours with proper knowledge and tools for coil over setup. Are you looking at doing spacers or full coil overs
    rear - around an hour
    Yes; would recommend it to save your tires if you’re messing with the front end
  4. Jun 6, 2022 at 7:08 PM
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    Eichbach stage 2 kit adjustable on truck for the money it’s a great deal, obviously better performing stuff on the market, but for the price it’s great. Don’t do spacers/blocks they suck. Alignment is very much needed.
    Tundra234 likes this.
  5. Jun 6, 2022 at 7:20 PM
    The attachment will give you an idea of what is involved.
  6. Jun 7, 2022 at 11:22 AM
    eagleguy
    Perfect, thanks. I see that many where I live just use spacers up front to retain the facotry ride.
  7. Jun 7, 2022 at 11:33 AM
    There are differences in opinions on spacers. I used to run a Readylift spacer kit and blocks on my 2013. It rode rough. It was a night and day difference when I switched to Toytec coilovers and shackles.
