  1. Jun 6, 2022 at 7:51 AM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    295/70s
    Just under 35's
  2. Jun 6, 2022 at 8:04 AM
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    Do you have a lift on it? Or leveling kit? Any trimming need to be done?
    Sorry for all the questions just need to get new tires soon and I like the look of your truck
    Thanks
    Edsel
  3. Jun 6, 2022 at 8:06 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  4. Jun 6, 2022 at 8:55 AM
    king.cong.1119
    king.cong.1119 New Member
    DIY'ed my solar setup on top of my LEER cap, free energy that runs my iceco fridge indefinitely.
    RegGex, SAGE63 and Toe404 like this.
  5. Jun 6, 2022 at 9:57 AM
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    2021 SR5 that came with an unlit driver window switch and only auto down feature.
    Previously replaced the driver's window switch assembly to get auto up and down on driver window and lighted switch.
    Then installed 3Wliners auto up/down module kit hoping it would work without running wire to battery. Probably expectedly, it didn't work and at the time I didn't want to take the time to run the wire to the battery. "Spoke" with @COTundie about what a pain it was to run the wire the right way, through the rubber boot that the factory door wiring uses. I didn't trust that I wouldn't jack something up so, full disclosure, I did not run the power wire to the battery through the boot. Instead, I fished it through where the door check and hinges are, into the front fender and up and around to the battery. Going to wrap with a little rubber sheathing to keep it from getting wet where it is exposed between the fender and door. If it lasts, great; if it doesn't I regroup.
    In the meantime, now have the lighted driver side switch and auto up/down on all four windows and got the bonus of all four windows up and down from the remote. Doesn't replace the remote start feature but sure will help on those hot summer days when I can get a head start on cool down before I head out to the truck.
    BlueRibbon4x4 and jhardy1979 like this.
  6. Jun 6, 2022 at 10:31 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    Not *today* but haven't had a chance to post, this past Friday I installed the Valhalla's Shield front and rear cat plates along with newly red powder coated front tow hooks.
  7. Jun 6, 2022 at 12:12 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Thank you John!!
  8. Jun 6, 2022 at 1:18 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    How do you like the Victory winch bumper? Did you have any issues on the installation? What winch did you use? I was thinking about getting one this fall.
  9. Jun 6, 2022 at 1:24 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    That be them as well.
    cartage1 and Tundra234[QUOTED] like this.
  10. Jun 6, 2022 at 1:42 PM
    zasdds
    zasdds New Member
    2021 Platinum Crewmax
    I was considering doing this as well...do you think there is any issue with the components overheating/not having enough airflow?
  11. Jun 6, 2022 at 1:53 PM
    The sensors for 2020 and newer are a different mhz.
  12. Jun 6, 2022 at 2:12 PM
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    So, I just did the carpet to the back of the amp, didn't actually cover the amp proper, for exactly that reason. I think the other sides exposed, and the carpet just being over the cables (so cables are providing some space under it), will leave sufficient airflow.16545499209091986219904435391867.jpg Here's a picture with the seat all the way up, so you can see, maybe that'll help. But, I'm not an expert, so if any pros are seeing a red flag, let us know! :)
  13. Jun 6, 2022 at 2:13 PM
    Actually may have to start driving like Grandma, seat all the way up and hugging the steering wheel, that looks pretty good...
  14. Jun 6, 2022 at 3:13 PM
    BlueRibbon4x4
    Geno
    Dang that’s clean. :thumbsup:
  15. Jun 6, 2022 at 3:18 PM
    BlueRibbon4x4
    Geno
    I love it! I really try to keep the stock lines of the truck. No issues on install, their YouTube video was spot on. I have a Badlands 12k winch, used it twice so far, only using it to respool. I have a large yard on a slope, so it took my truck no problem that 100’. Before every off-road run I check it, and it always works.
  16. Jun 6, 2022 at 4:03 PM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Installed the softopper aka vacation mode activated
    GELCW, Wallygator, raspy87 and 11 others like this.
  17. Jun 6, 2022 at 4:46 PM
    J&ATundra
    J&ATundra |-|/-\\/\//-\| |
    Texas but from Hawaii
    2018 Cement Toyota Tundra
    Installed 3.5 RC lift with 295/70r18
  18. Jun 6, 2022 at 5:01 PM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    So are these plug and play or is there extra wires needed?
  19. Jun 6, 2022 at 5:07 PM
    TBS
    TBS New Member
    2021 SR5 CrewMax 4x4 Barcelona Red
    E50 extinguisher, Valhalla Plates, ESP Storage, Chrome Delete, Pwr Tailgate Lock,
    Blowdart likes this.
  20. Jun 6, 2022 at 5:47 PM
    Wahayes
    Will
    2017 tundra limited *sold*
    Set my winch line under load and did a shakedown run of the new bumper suspension and tires
  21. Jun 6, 2022 at 7:43 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    With a 3” OME lift can I run a 35x12.50r20 on scs 20x9 wheels?
  22. Jun 6, 2022 at 7:51 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    20220606_105337.jpg 20220606_213954.jpgGot it installed today. Works good and the blue lights match almost perfectly.
  23. Jun 6, 2022 at 7:54 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Looks good! Is your bumper rubbing the front filler piece? I always forget until I see photos how much flex there is.
  24. Jun 6, 2022 at 8:10 PM
    probably not without significant rubbing
    CaptRussia253[QUOTED] likes this.
  25. Jun 6, 2022 at 8:20 PM
    Wahayes
    Will
    No bumper doesn't rub at alll.
    Yzed608[QUOTED] likes this.
  26. Jun 6, 2022 at 8:23 PM
    Wahayes
    Will
    I just put 325/60r20 which are basically 36s on mine, with a 2.25 dobinsons. It rubbed like crazy. Had to do bmc , pinch weld , and trim the shit out of the bumper plastic (prior to replacing the bumper) I'm on 20x9 +20 fuel
  27. Jun 6, 2022 at 8:35 PM
    CaptRussia253
    Ruslan
    Damn it.
    I currently have 34x11s and there’s so much damn room I figured they’d fit
  28. Jun 6, 2022 at 9:06 PM
    AggiePhil
    College Station, TX
    What sensors?
  29. Jun 6, 2022 at 9:10 PM
    ffdawson
    ffdawson #DBB
    NorCal
    Sandra, Sandy for short
    Rad ass parts, big tires.
    Gotta remind her that while she may be pretty, she’s still a truck!
    GAknight, GELCW, Wallygator and 30 others like this.
  30. Jun 7, 2022 at 2:04 AM
    Bergy24
    Bergy24 New Member
    TPMS
