Westcott the only level around for Avs???
Discussion in '3rd Gen Tundras (2022+)' started by Jkwolfe09, Jun 6, 2022.
  1. Jun 6, 2022 at 3:23 PM
    Jkwolfe09
    Jkwolfe09 [OP] New Member
    Jerren
    So is westcott the only level/lift around that’s compatible with the Avs system? They suck at fulfilling orders and would rather not wait 6 months for a kit.
  2. Jun 6, 2022 at 4:28 PM
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    yes, i believe so atm. tension is getting pretty high. saw westcott blow up on someone on fb when that person mentioned the delay. that person could have taken it more private or said it differently but i wasn't expecting that type of response from the vendor. they're clearly spread thin and some stress and/or frustration going on.
    and just to be clear westcott designs, i'm not complaining and am patiently waiting if you're reading this. lol. take care of yourselves over there.
    earlfo likes this.
  3. Jun 6, 2022 at 4:42 PM
    Jkwolfe09
    Jerren
    Yeah I get their frustration but seems to be brought on by themselves to be honest.. I know no one can predict the success of a product but shit I’d have as many shifts working as possible and the shop doing their anodizing would be dropped! Id source the work out to as many shops as needed in order to fulfill these orders since it’s only a matter of time till someone else develops a product and capitalizes on their inabilities.
  4. Jun 6, 2022 at 4:46 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Pro comp has a 3/1 level kit that has AVS relocation bracket. Not as nice as Westcott preload collar though.
    The relocation bracket from instruction manual.
    sensei and KroppDuster like this.
  5. Jun 6, 2022 at 4:56 PM
    brucega7x
    brucega7x New Member
    2022 Tundra SR5 CrewMax 4X4
    It's pretty simple. Be honest with what the real wait times are and people wouldn't be complaining when they're weeks and weeks over...
    sensei and Jkwolfe09[OP] like this.
  6. Jun 6, 2022 at 4:58 PM
    Jkwolfe09
    Jerren
    My concern/ shops concern is the front shocks there is a wire on the top that I assume controls the stiffness for lack of better terms.
  7. Jun 6, 2022 at 5:13 PM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Just don’t call it a spacer lift :crapstorm:
    …and full disclosure have one on my truck so not criticizing but the frustration on both sides are very real.
  8. Jun 6, 2022 at 5:16 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    Hmm. I can see that being an issue too, if there isn't enough slack for the wiring with the spacer installed. Westcott has the spacer on top too with their, but it's only like 1" thick.
  9. Jun 6, 2022 at 5:26 PM
    Jkwolfe09
    Jerren
    I thought the westcott level used a spacer at the bottom of the spring?
  10. Jun 6, 2022 at 6:27 PM
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    '22 Lunar Rock LTD DC TRD-OR
    It's a combo of a preload collar on bottom for 2" lift, and a 1" spacer on top of the strut... At least this is the combo for the 3/1 "lift"... The AVS lift is only 2" up front i think, so maybe its just the preload collar and no spacer on top... I'm not 100%
  11. Jun 6, 2022 at 6:30 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    The wire for the avs shocks is not a problem. I did a rc 1.75in spacer and adjusted the rear air bag lever...Zero issues with avs
  12. Jun 6, 2022 at 6:49 PM
    Jkwolfe09
    Jerren
    That’s what I was wondering! Seems like even rough country doesn’t think it’ll work per their site but I swear I’ve seen a bunch of Avs equipped trucks on here using the Rc spacer. How do you like the ride after lifting?
  13. Jun 6, 2022 at 6:52 PM
    eddiefromcali
    Eddie
    100% Stock
    Rides fine...lil stiffer but I like the new feel
    Jkwolfe09[OP] likes this.
