Using OEM rearview mirror wiring
Discussion in 'Electrical' started by Giggles1, Jun 3, 2022.
  1. Jun 3, 2022 at 8:35 PM
    Giggles1
    Giggles1 [OP] New Member
    Robyn
    Tundra SR5
    Brand new to the site and I would like to know if you can use existing mirror wiring harness to wire in an after market backup camera? Figured it would be easier to start and end there. Then again I believe I would still have to run the wire for the camera on the license plate. Don't want to tear into harness and ruin it.
  2. Jun 3, 2022 at 9:22 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    what year truck? Early models (2007-2009) had an optional tailgate camera that had a flip-down screen in the overhead console and/or to a navigation head unit. This was in vehicles with the factory JBL audio only (bluetooth phone and steering wheel audio). In 2010, that changed to being a screen integrated into the rear view mirror (or into the Nav head unit), but most of the wiring didn't change inside the cabin. In 2014, everything went to an in-dash screen in the head unit regardless of nav or not, and the camera feed at the mirror/headliner was eliminated.
    Jeff_5_7 and 1lowlife like this.
  3. Jun 4, 2022 at 8:02 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    I havent seen many of the early trucks that had the rearview mirror/overhead console backup camera. It is possible your truck is prewired for this but in my opinion it is pretty rare.
    I would be starting this project under the assumption you are going to have to add all the wiring for the camera. As @RainMan_PNW mentioned above, the year of your truck is a big factor.
    I am not sure what your exact goal is but if you were just looking for a quick easy way to see behind you when backing up a cheap wireless backup camera might be good enough. I have never used them but install would be alot easier and it might be a simple enough solution to solve your problem. Almost all the ones I see operate on an aux display you mount in the truck.
    https://www.amazon.com/Wireless-Roh...t=&hvlocphy=9027895&hvtargid=pla-570384398113
  4. Jun 4, 2022 at 8:14 AM
    oogabooga289
    oogabooga289 New Member
    It's been awhile, so I don't have the details off the top of my head. But I was definitely able to use the existing wiring harness for the "park assist" flip down screen. My truck didn't come with the screen or camera, but the wiring harness was still there. I got a camera that plugged into the open harness connector on the rear of the truck, and I remember I connected to the other side where it came out in the ceiling liner. Again, I forget the details at this moment. But I did it. And I probably compiled the information from other people's experiences online.
    This was the OEM "park assist". I'm not advocating getting it. It's just reference to show the wiring harness that would be utilized.
    https://www.yotadirectparts.com/oem...2W6QhUeGJO-uP1z5PISeMx9r21v0aQ2MaAnxREALw_wcB
  5. Jun 4, 2022 at 8:21 AM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    If you search this forum you’ll find people who have used adapters that plug in to the mirror and provide a USB port for power.
  6. Jun 4, 2022 at 9:40 AM
    RainMan_PNW
    Casey
    Clark County, WA
    I think in 08/09 it was fairly common in the limited trim. I had it in my 2008 SR5 that had the JBL system, which basically had the truck a prewired for everything that the Limited offered.
