4hi 4lo flashing abs/ traction control solid.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra1923, Jul 22, 2021.
  1. Jul 22, 2021 at 4:54 PM
    Tundra1923
    Tundra1923 [OP] New Member
    Can anyone help me to why 4hi/4lo lights are flashing and abs/traction control lights are on. I’ve already replaced wheel sensor with oem and wheel bearing and front driver side cv axel with after market autozone/ advance auto parts parts and light are still on. harness is good too
    Could the aftermarket cv axel and front wheel bearing be the reason for it to still have those warning lights? Codes are front not reading driver side front wheel sensor
  2. Jul 22, 2021 at 5:12 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    The axle and bearings wouldn't give you any codes. Did you clear the codes after you replaced the sensors? Also might be a good idea to disconnect the battery for a bit if you haven't done this already.
    Oey12 likes this.
  3. Jul 22, 2021 at 5:14 PM
    Tundra1923
    Yes cleared codes and disconnected battery also cleaned wheel sensor because before it was dirty with grease but now it’s completely clean. comes back one after putting it in drive after a few seconds. You can hear the abs whining and if I brake you can feel this vibration. I took it to Toyota to diagnose they want to replace axel and wheel bearing with oem because they’re aftermarket before they can actually diagnose
  4. Jul 22, 2021 at 5:18 PM
    Tundra1923
    Would could cause the sensor to not read properly? Wheel sensor has been replaced and also tried with new harness
  5. Jul 22, 2021 at 5:47 PM
    TILLY
    Massachusetts
    First off, can you tell us what year truck you have? The ABS whining and vibration adds a new complexity to your problem other then just flashing lights now.
  6. Jul 22, 2021 at 5:52 PM
    Tundra1923
    2016, so when I first start my car, the abs and traction control lights are on. When I start driving I can hear what sounds the the abs starting to go off and when I brake it hits back until I let go and I pick up speed then the 4hi 4lo start flashing along with the abs and traction control light staying solid and drives and brakes normally
  7. Jul 22, 2021 at 6:07 PM
    TILLY
    Massachusetts
    That's very strange. So you're still getting a code for a front wheel sensor, correct?
  8. Jul 22, 2021 at 6:13 PM
    Tundra1923
    Yes all comes to that speed sensor not reading properly but the rest are. Even has code for blind spot monitor and the fault is for that speed sensors. So this is the events that happened previously. 3in lift, no issues, bigger tires that’s when I found that cv axel and wheel bearing where bad. Replaced both. Drove fine for a week then this happened ever since
  9. Jul 22, 2021 at 6:25 PM
    TILLY
    Massachusetts
    I know you said you replaced all the sensors with OEM, but maybe you got a bad sensor. Are the sensors interchangeable right to left?
  10. Jul 22, 2021 at 6:28 PM
    Tundra1923
    No, but I can swap with a rear one and see what happens.
  11. Jul 22, 2021 at 6:33 PM
    TILLY
    Massachusetts
    That's what I would do, swap the sensor, clear the codes, and that will rule in or out a bad sensor.
  12. Jul 22, 2021 at 7:16 PM
    TILLY
    Massachusetts
    Let us know how you make out, if its the same code, we can take it from there. Good luck.
  13. Jul 22, 2021 at 7:22 PM
    Hanzo
    Hanzo New Member
    I had the same problem, turned out to be a broken wire leading to abs sensor. Follow the wires back and see what you find.
    Ely010606 and TILLY like this.
  14. Jul 24, 2021 at 10:11 AM
    akarkie
    akarkie New Member
    Terry
    2014,16, and 19
    Yep, I am dealing with this on my 2016 as well. Mine started with the "trailer brake controller error" and started making noises in the dash eventually switched to the ABS/ Trac Control light flashing. I figured it was a speed sensor, hooked up my diagnostic and it said left rear ABS sensor. Bought a denso sensor at Napa and it still is acting up, taking it to a shop next week to see if they can figure it out. I am going to switch the front and rear sensors on driver side. I may have a faulty wiring harness but this truck has been treated easily, no hard off roading or mudding. It does see lots of dirt roads, a rock may have flew up and hit something.
  15. Sep 17, 2021 at 9:22 AM
    Andersong1
    Andersong1 New Member
    Greg
    Hey man, I have a 2015 tundra and this started happening. Same issues you are having. Did you find a solution? Thanks in advance !!
  16. Jun 3, 2022 at 9:57 AM
    Grneyes0425
    Grneyes0425 New Member
    I have 2012 Tundra no mods and it started this two days ago any new info on fixes? is it ok to drive like this for a few days as we are on vacation 600 miles from home ?
  17. Jun 3, 2022 at 10:32 AM
    Wallygator
    Sounds like an ABS sensor
