What’s happening to me wheels?
Discussion in 'Wheels & Tires' started by WhiteSmoke4x4, Jun 1, 2022.
  1. Jun 1, 2022 at 7:57 AM
    WhiteSmoke4x4
    WhiteSmoke4x4 [OP] New Member
    Phil
    2014 Double Cab SR5 Off-Road 4x4
    Some kind of etching on my stock wheels. I assume they are the original wheels and probably had some etching when I bought it from the dealer and it’s gotten worse. I do live in New England so a lot of road salt. I went through a car wash a few times this past winter but I decided I’m done with that and will only wash the truck myself from now on. Anyone seen anything similar to this?
  2. Jun 1, 2022 at 8:02 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Definitely looks like salt damage. Not sure what can be done for them tho. Try posting it in the detailing section also maybe someone has some ideas. I hate nj winters and salt.
    WhiteSmoke4x4[OP] likes this.
  3. Jun 1, 2022 at 8:05 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Yep, road salt sitting on the finish and the soaps used in auto washes are harsh and can degrade finish over time. Luckily the Tundra OR wheels are easily found and not too costly. Finding a new one or set may be cheaper than trying to fix or powdercoat those.
  4. Jun 1, 2022 at 8:07 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Yup. The finish got damaged and the aluminum is corroding. Only way to really fix it properly is to strip everything down, repaint, and clear coat.
    D4x4TRD and WhiteSmoke4x4[OP] like this.
  5. Jun 1, 2022 at 8:15 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Arrrr, matey! Looks like the ol' sea hag has been rubbing her salty nethers on yer wheels. Set sail for the nearest powder coating shop.
    Arrrr!!
  6. Jun 1, 2022 at 8:20 AM
    PermaFrostTRD
    Northern NY
    crying.
  7. Jun 3, 2022 at 6:53 AM
    frichco228
    Frank
    Virginia
  8. Jun 3, 2022 at 7:09 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    Usually comes from a small chip then salt corrosion under the clear coat. I had a set of Konig wheels I had on a car years ago that got all chipped up at discount tire from their tire iron and the finish went bad on them in one winter.
    I've seen companies all over that will machine wheels and re-coat to make them look brand new. Its usually about $400 per wheel minimum around where I am. Finding a used set like frichco228 suggested above is a better deal.
