Gas SIPPING mod??
Discussion in 'General Tundra Discussion' started by Rubberneck, May 30, 2022.
  1. May 30, 2022 at 5:24 AM
    Rubberneck
    Rubberneck [OP] New Member
    18 Platinum
    None...yet
    Cant make this shit up. Im currently getting 18-24mpg from my 18 Tundra Platinum Crewmax 4x4 with oversized tires!!! im completely in shock!
  2. May 30, 2022 at 5:39 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    2020 Tundra Limited
    fresh fill up and coasted down hill?
  3. May 30, 2022 at 5:52 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    on a flatbed and idling? :rofl:
  4. May 30, 2022 at 5:55 AM
  5. May 30, 2022 at 6:00 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
  6. May 30, 2022 at 6:12 AM
    I vote Photoshop lol.
    Cpl_Punishment likes this.
  7. May 30, 2022 at 6:14 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Memorial Day miracle!
    Saltyhero13 and Tundrastruck91 like this.
  8. May 30, 2022 at 6:29 AM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    Do whatever trip you did at 24mpg in the opposite direction, and post those results.
    I’m guessing it would all be uphill and a much different story.
  9. May 30, 2022 at 6:42 AM
    dherring256
    dherring256 New(ish) Member
    2018 MGM SR5
    Fuzzy Dice
    Select the correct response:
    A. [ ] no doubt
    B. [x] doubt
  10. May 30, 2022 at 6:46 AM
    Rubberneck
    18 Platinum
    None...yet
    Im bot bullshitting here! I did a brake and rotor job the other day. As always, Toyotas are known for shit parking brakes. When i removed rear rotors i noticed the park brake “shoe”wanted to come with rotor. Had park brake adjusted and this was the result. I drove 20 miles at the 18.4mpg and was all flat. On ramp was a “get up to speed” acceleration then hit cruise at 68. Take it or leave it fellas. It worked for me.
  11. May 30, 2022 at 6:46 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Ahhh, the suspense….Just kidding. Nobody cares.
    Shanet421 and Cpl_Punishment like this.
  12. May 30, 2022 at 6:47 AM
    Rubberneck
    18 Platinum
    None...yet
    Here is the current numbers with approx 15 miles of city driving. Using reg unleaded. Cheapest stuff.
  13. May 30, 2022 at 6:58 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    But does the parking brake work :monocle:
  14. May 30, 2022 at 7:01 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I have the opposite problem. With the transmission in park and the brake set, my truck still wants to roll away.
    snivilous and dherring256 like this.
  15. May 30, 2022 at 7:07 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Coming back down into reality numbers, like my 14mpg :thumbsup::bananadance:
  16. May 30, 2022 at 7:56 AM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
  17. May 30, 2022 at 7:57 AM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    Their just busting your balls man
  18. May 30, 2022 at 8:00 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    My Tundra always gets better MPG after I disconnect the battery for a few minutes...:rolleyes:
    Should I disconnect it once a week? :cool:
  19. May 30, 2022 at 8:16 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    If I kept my 2018 with 34.6" BFGs below 70, I could get 18mpg no problem. 75 or above and she would drop to 15mpg and worse. That DFW gas is shit too. Would get 12mpg from DFW to Amarillo in my Tundra or GX.
  20. May 30, 2022 at 8:21 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Maybe that is why I never get over 14.
    I usually get gas at Kroger, the one time I got it from Fuel City there was a noticeable decrease in MPG.
    Rumor is the feds are going to allow more ethanol in fuel to lower gas prices..:(
  21. May 30, 2022 at 8:35 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    Doesn't going to a larger tire throw off the MPG reading on the truck? Not sure which way it would take it, but I'd be curious what you were getting if you manually calculated it. If that's truly what you are getting though that's awesome.
  22. May 30, 2022 at 8:41 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Edit: this post is a decoy and contains mental flatulence
    Larger tires will make the trucks readings HIGHER than actual.
    Truck thinks it's traveling further than really is on set amount of gas.
    Edit... strike that. Reverse it
  23. May 30, 2022 at 8:48 AM
    COTundie
    Trey
    Pretty things
    Let me try this again.
    Larger tire circumference will travel further on one rotation than a stock size tire... Actual driven miles are more than what the truck thinks.
    More miles on the same gas means the truck will calculate lower mileage than hand calculated
    Nbab23 and Saltyhero13 like this.
  24. May 30, 2022 at 9:21 AM
    Terndrerrr
    Music City
    6UR-FE
    To calculate how far off it really is, go to tiresize.com. Click on the comparison. For size 1, enter the specs of the tire your truck came with (for most of us, it’s 275/65R18…not sure what the factory specs for trucks that came with 20s is). Then enter your larger tire’s size in size 2, and hit compare.
    For example, my 285/75R18s are 8.4% larger in diameter (and therefore circumference) than stock. Therefore, I take my dash readout and multiply by 1.084 to get what the dash would read if it were calibrated for stock.
  25. May 30, 2022 at 9:49 AM
    EmergencyMaximum
    EmergencyMaximum New Member
    That is incredible!! What did you do to her? Downhill on ike gauntlet? Mine's 4x2 regular tires with small v8 and I can't get 23!!
  26. Jun 1, 2022 at 5:34 PM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    That's brilliant. Let's use cropland and our food - and/or the food for our food - to save a few cents on gas (which is a lie anyway due to decreased efficiency). Granted, a lot of us could stand to eat fewer calories (myself included) but this isn't the way I want to do it!
    1lowlife[QUOTED] likes this.
  27. Jun 1, 2022 at 6:33 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Psssh, I got you beat. IYKYK ;)
  28. Jun 1, 2022 at 8:20 PM
    COTundie
    Trey
    Pretty things
    Where'd you get the Guage pod mount? I like this
  29. Jun 2, 2022 at 3:01 AM
    Silver17
    Eastern PA
    It’s a CravenSpeed Flexpod mount. I got mine from URD.
    COTundie[QUOTED] likes this.
