  1. Jun 1, 2022 at 7:25 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    This is super awesome.
    Voss[QUOTED] likes this.
  2. Jun 1, 2022 at 7:27 PM
    alb1k
    Left Coast
    It's good
    Tack that as is before it gets disturbed. Then mount it to the hood. Or use them as gussets...lol.
  3. Jun 1, 2022 at 7:29 PM
    alb1k
    Left Coast
    It's good
    #sogood
  4. Jun 1, 2022 at 7:40 PM
    alb1k
    Left Coast
    It's good
    Consider some supports/gussets for side to side as well as front to back, if you haven't. I'm saying that because I recently learned that the side to side is violent at times. I stretched some metal and a Taco threw his shell off to the side of the road in the whoops.
  5. Jun 1, 2022 at 7:53 PM
    alb1k
    Left Coast
    It's good
    Continuing my love/hate relationship with Morimoto mini-pods and mod-pods, I made a change. One of my 4 minis failed up front due to factory defect. My attempt to fix it failed eventually. So, I emailed them and told them what to do better, and bought more shit from them. So lame. But - I like the new mod-pods up front better than the minis. And repurposed the minis for a chase light. I need to get some different colored lenses all around. But, it occurred to me that if I can get a small piece of yellow plexi or lucite, I can make the chase light retro Toy colors.
  6. Jun 1, 2022 at 7:59 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    Appreciate the input brother and if I hadn’t just came back from Coyote Flats after accidentally taking the challenging path to Funnel lake, I’d want as much support as possible. After that run, I don’t think the gussets I’m planning to weld on are even needed. Thing is bulletproof!
    oscardog86 and alb1k[QUOTED] like this.
  7. Jun 1, 2022 at 8:02 PM
    alb1k
    Left Coast
    It's good
    Nothing better than a field test. I'm still chasing down little stuff I want bullet-proof. 10 on the rack :101010:
    des2mtn and Voss[QUOTED] like this.
  8. Jun 1, 2022 at 8:49 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Here is this as well if you want a rocker switch for your light bar that fits that oval cutout.
    Link
  9. Jun 1, 2022 at 9:01 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Question, my last button there seems like for the windshield? I don’t think I’ve ever used it b4 cause there’s an option for it on the 3 AC/heater knobs.
    Am I misunderstanding what this button does or is it truly repetitive? Wouldn’t mind replacing it with something I need a switch for…
  10. Jun 1, 2022 at 9:03 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Side mirror defrosters.
    NUDRAT, alb1k and Voss[QUOTED] like this.
  11. Jun 1, 2022 at 9:07 PM
    Voss
    Valod
    2003 AC TRD 4x4
    What?!? Fancy Tundra option right there.
    NUDRAT, alb1k and des2mtn[QUOTED] like this.
  12. Jun 1, 2022 at 9:11 PM
    des2mtn
    SW
    Tonto cover
    If you had a Ridgeline, this button would also turn on the defroster on your roll-down rear window (mind you our switch is on the center bezel underneath the cargo lamp button). :)
  13. Jun 1, 2022 at 9:15 PM
    alb1k
    Left Coast
    It's good
    Take it easy with the AC guys. Not everyone is blessed enough to drive a Ridgeline.
  14. Jun 1, 2022 at 9:18 PM
    des2mtn
    SW
    Tonto cover
    Deep down inside every AC owner wants the roll down back window.
    NUDRAT, CodyP, oscardog86 and 8 others like this.
  15. Jun 1, 2022 at 9:19 PM
    alb1k
    Left Coast
    It's good
    Ya, so close, yet so far...
  16. Jun 1, 2022 at 10:45 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    deep down... all of you guys want an 8 ft bed
    RCLB LIFE FTW
    txagg, NUDRAT, abcinv and 6 others like this.
  17. Jun 1, 2022 at 10:45 PM
    Vallejo206
    Vallejo206 New Member
    Rob
    Everett, WA
    02 SR5 V6 AWD
    love my AC but I wouldn’t mind a DC with roll down window and a sun roof…One day.
    Voss, 5N0W808 and des2mtn[QUOTED] like this.
  18. Jun 1, 2022 at 10:46 PM
    Vallejo206
    Rob
    Everett, WA
    02 SR5 V6 AWD
    Awesome..more things to buy haha thanks.
  19. Jun 1, 2022 at 11:31 PM
    Voss
    Valod
    2003 AC TRD 4x4
    True. Even thought about getting it till I realized I don’t like the small window open.
  20. Jun 1, 2022 at 11:51 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    I wish there was a RCSB 1st gen. I know they've been made tho.
  21. Jun 2, 2022 at 12:03 AM
    empty_lord
    05 rollover special
    I wish there was more tire options for my mr2 lol.
    Only
    Option for a matches set are toyos aggressive race tire. Front tires are easy. Rear tire being 225/50r15? Yea I’m fucked
    alb1k likes this.
  22. Jun 2, 2022 at 6:53 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Probably just an odd sizing that no one sells.
    Can you go a bit wider and see if that opens up options or will you have to go to 16s and buy new wheels to be able to find decent tires?
  23. Jun 2, 2022 at 8:59 AM
    tokolosh
    tokolosh Serial procrastinator
    J
    SF Bay Area
    05 AC V8 SR5 Phantom Grey
    new driver
    so glad it wasn't just me lol
    bmf4069[QUOTED] and CodyP like this.
  24. Jun 2, 2022 at 9:39 AM
    empty_lord
    05 rollover special
    I’m trying to avoid wheels just because $
    CodyP[QUOTED] likes this.
  25. Jun 2, 2022 at 10:00 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Advans?
    Or just stretch some 205's.
  26. Jun 2, 2022 at 10:01 AM
    Forg
    Forg New Member
    In the process of adopting (i.e.: free!) this old girl. '02 4.7 automatic RWD SR5, extended cab as you can see. It's only up to about 350k miles, timing belt was done at 330k so it's good for a while. She runs good, doesn't burn any oil. Everything works pretty well (except the oil temp gauge), even the CD player. Minor cosmetic issues, some bed rust (see my thread) but pretty good especially with a little preventative care. The paint is mostly ok with a few scratches & the roof needs attention.
    My aunt bought it new in 2001. It's mostly done highway commuting and road trips & has been maintained by a respected local mechanic its whole life. I don't think it's ever really towed or done any heavy duty bed work beyond a little furniture/box hauling maybe.
    Anything you guys would like to know about this truck? I'm thinking I'd like a bull bar or something up front but a lift or new wheels isn't in the stars just yet ;)
    hammeron, Voss, w666 and 9 others like this.
  27. Jun 2, 2022 at 12:55 PM
    @Forg I'd replace those fog lights to match the new headlights. :boink:
    Unless those are just polished waiting to come back to the old haze.
  28. Jun 2, 2022 at 1:28 PM
    Forg
    Forg New Member
    The driver's side is nice and new and shiny due to some sort of minor accident a few years ago that I don't understand- it didn't damage anything but the headlight housing! I might replace the driver's side & the fogs if they're not too expensive, it would look a lot nicer. (Driver's side isn't too bad but it stands out against the new passenger side.)
  29. Jun 2, 2022 at 6:34 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Tried out the cerakote headlight restoration kit I picked up for under 10 bucks on sale. Retrofit headlight coating failed within about a year and a half tops. I'll chalk that up to aftermarket headlamps.
    Turned out ok. The inside has some fogish looking stuff so up close it's annoying but over all I can live with it for now. Probably have to order oem eventually to make my OCD happy..can still see small sanding lines from the kit. I didn't polish or compound because I just lost patience with the whole head lamp ordeal on my truck.
    (Editing due to apparently being period happy. I swear I'm not a ra-tard. Just fat thumbs)
    805Tundra, NUDRAT, KNABORES and 5 others like this.
  30. Jun 3, 2022 at 8:41 PM
    Vallejo206
    Rob
    Everett, WA
    02 SR5 V6 AWD
    same here man. My aftermarket headlights are fogging and peeling from the inside also..about what I’d expect for what I paid.
