2016 1794 4WD Brake Job (front/rear)
Discussion in '2.5 Gen Tundras (2014-2021)' started by Vinstinct2g, May 30, 2022.
  1. May 30, 2022 at 9:08 AM
    Vinstinct2g
    Vinstinct2g [OP] New Member
    Alright guys, rear brakes are toast and I am getting the braking wobble when stopping.
    Dealer wants $500+ to do rear (pads/rotors). I’m thinking NO WAY (unless someone here knows a VERY persuasive reason why I should go this route.)
    Searched around, found a good deal on the Centric Premium rotors and posi-quiet ceramic pads. (350 shipped front/rear). It’s simply a daily driver, so no real reason to get carried away with aftermarket parts.
    Now, there is plenty of “DIY How-To” videos on YT for fronts and rears, but I figured why not post something and see what DIY’ers have ran into on the 2.5 gen.
    So, use this thread to post your “Look out for this.” “Make sure of that.” Helpful tips while I either attempt my 1st brake job, or get convinced to have a shop put on my parts. Videos always make it seem easier than it is…
    I do have two unanswered questions though, torque specs on any bolts removed, and jacking points (front and rear please)
    Thanks team
    Tundrastruck91 likes this.
  2. May 30, 2022 at 9:42 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    I jack up the rear axel at or near the shock mount. The only real issue is getting the parking brake pads to release the rotor, other than that its a breeze.
  3. May 30, 2022 at 10:23 AM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Bought all new Toyota brakes and rotors for less than $500. Changing was very easy, the only hard part was removing and reinstalling my heavy 35s.
  4. May 30, 2022 at 10:41 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Was that for all four ?
    Interested in prices for all 4 including parking brake and 1 backing plate.
    Indeed, shop hourly fees won't be cheap.
  5. May 30, 2022 at 10:45 AM
    Funnyguy713
    Houston TX
    All four. I got most of everything on Ebay, they sell Toyota brakes sets on there from Dealerships.
    gkelm and Tundrastruck91[QUOTED] like this.
  6. May 30, 2022 at 11:08 AM
    Vinstinct2g
    That says front, so it does not seem to be all 4, unless I am missing something.
  7. May 30, 2022 at 11:14 AM
    Funnyguy713
    Houston TX
    Just telling you where I got MOST of the parts, you got a search.:pccoffee: Sorry it was done a while ago.
  8. May 30, 2022 at 11:31 AM
    Vinstinct2g
    sorry I appreciate it. I have found all of my parts, was trying to help clarify for the other poster.
  9. May 30, 2022 at 3:39 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Rear caliper mounting bolts 123 ftlb torque, rear caliper slide pin bolts 65 ftlbs. use plenty of slider lube of your choice on the pins. Fronts, I'd get caliper pin kit. replace them use plenty of anti seize on the pins for removal next time. Be sure the wheel hubs are free of rust before installing rotors..
    Vinstinct2g[OP] likes this.
  10. May 30, 2022 at 3:45 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I learned how to do brakes on my truck. Its so easy
    des2mtn likes this.
  11. May 31, 2022 at 8:49 AM
    Vinstinct2g
    In the event there is rust on surfaces on the hubs, are we talking clean or replace?
  12. May 31, 2022 at 9:09 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Brush it off
  13. Jun 1, 2022 at 4:41 AM
    agrestic1
    2016 CrewMax
